Question about Marley HBB1004 Electric Baseboard Heater
Thermostat not working properly
We have a thermostat in bathroom that was making a sound like it was Shortening we purchased a new one but when we set the thermostat At 70 the temp. Went up to 85. We thought we may have installed it incorrectly?
Keeps running hot. Even with the proper amount of coolant.
First, feel the top radiator hose (after engine has been running) - if the hose is not hot, but the engine is, then the thermostat is stuck closed. Also check the drive belts and make sure they are sufficiently tight. You should be able move them (pushing with fingers) less then a 1/4 of an inch. If you suspect they are loose, tighten them up. I also recommend purchasing, or borrowing a service repair manual.
If your van keeps running hot, and you have no leaks, then it sounds as though you need to replace the thermostat. Follow the top radiator hose to the engine. Where this ends is where the thermostat is. You will need to do this when the engine is cool. There should be two bolts that hold this to the block. Purchase a new thermostat (roughtly 8-10 bucks, and the gasket, if it does not come with it), and make sure to check the box; if it doesn't have one, request one from the parts associate. They are usually less than a buck.
When removing, make note of how the thermostat comes out, so that you put the new one in correctly. If it's put in upside down, you'll end up having to take it out again. So...with that said, once you replace this, you will be good to go.
Now, if for some reason the van shows it's reading hot again, make sure first you are not leaking water (anti-freeze). Watch for drips and water under the car, as well as around the water pump (passenger side engine, behind drive belts). If there are no visible leaks, and the van still shows it's reading hot, the thermostat (new) is installed correctly -then you may just have a bad sensor. This is the thermostat sensor which should be located on the bottom passenger side of the radiator. If so, you will need to drain the radiator (plug on either this side, or other, on the bottom; remove cap for faster drainage) - If you have a clean tub or container for which you can drain into, and reuse the fluid, do so - if not, simply purchase a new gallon of (un-diluted) anti-freeze (preferred, not necessary - 50/50 will work); and put into ridiator after installing new temp sensor.
For safe measure (as I recommend and do myself), when purchasing the new thermostat and gasket, purchase the temp sensor as well, this way you have covered both of these and know they are both good.
Please let me know if you need further assistance.
carsandcomps
Aug 19, 2011 | 1991 Dodge Caravan
WHIRLPOOL FRIDGE FREEZER MODEL ART 201. REPLACING
It is often the case that if the thermostat is not working, the best route to take is to replace it rather than try to fix it, unless you have the necessary knowledge to do so. Most of the time, these are not as expensive as you would think and can be easily installed into the refrigerator. Here are some steps to follow to find out what the best route for you to take is in repairing or replacing your thermostat.
Good luck.....
Locate the thermostat and get all necessary model numbers, serial numbers and model codes. This information should be available for the refrigerator itself as well. Use this information to find and purchase the correct thermostat for your refrigerator.
Next, remove all power from the unit. Unplug the unit completely and make sure that it is not running before moving forward. Then, remove the old thermostat by cutting through the wiring.
To install the new thermostat, trim the lead wires to the right length. They are generally too long to start with. Terminate back into the circuit. The device will act as if it is a switch. This means that the direction or the coloring of the wires is not important. So long as you can cut off the current moving through them to the main defrost element you have no problem.
Make sure to properly dress the wires to insure that no part of them comes into contact with the defrost elements as this can cause them to melt.
Replacing a thermostat doesn’t have to be a lot of work, when you know what the problem is and can get easy access to the parts you need. Determine if your thermostat is bad by running through those tests first. When you do replace it, make sure to test to make sure it is working properly by allowing the unit to cool for several hours and testing the temperature within it.
Jul 30, 2010 | Whirlpool Refrigerators
My AC unit is 3 years old. its set at 72 but wont go below 78 degrees. im in Las Vegas...Help
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the AC manufacturer or a service person to verify the cooling system is operating correctly.
Or call the techline 18002842925.
Jul 18, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Its not cooling down even though I can hear the motor running
Jul 17, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Its saying MO in the upper left hand corner and AC won't turn on
Diagnostic: Set SYSTEM Switch to COOL and lower the setpoint below room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. Ifthe thermostat does not click, try the reset operation .If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks,contact the AC manufacturer or a HVAC service
person to verify the cooling is operating correct.
MO stand for MONDAY.
Jun 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Auxiliary light was lite on my white-rodgers 1f82-51 thermostate and i have no heat?
follow this guide:
Diagnostic: Set SYSTEM Switch to HEAT and raise
the setpoint above room temperature. Within a few
click, try the reset operation. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating is operating correctly.
Mar 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Heat will not come on.
No heat troubleshooting
Diagnostic: Set SYSTEM Switch to HEAT and raise the setpoint above room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation listed above. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a HVAC service
If you need further support call the techline 18002842925.
Nov 16, 2009 | Honeywell Electronic Programmable...
Kenmore elite refrigerator
It sounds like the fan is not circulating the air from the freezer to the fridge. Since it's new then you should contact the store where you purchased it for exchange or repair immediately.
Jul 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Marley HBB1004 Electric Baseboard Heater Logo
19 people viewed this question
Top Marley Heating & Cooling Experts
paulcarew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
