Question about Sony Handycam HDR-CX360V Camcorder
HDR-cx360V - E:91:01 - Error does not go even after reset/power off.
I have a sony HDR-cx360v. I am getting E:91:01 error flashing continuously.The camera works just fine otherwise. Tried reset, power off etc still the error does not go.
  • 25 Answers
This is a manufactures melfunction.sony will fix it for about $294 or give 15%of on a new one.buyer be ware.
Posted on Aug 16, 2013
  • 169 Answers
SOURCE: Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Posted on Aug 21, 2007
SOURCE: HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Posted on Mar 30, 2009
  • 149 Answers
SOURCE: ERROR C:32:11
GO TO REPAIRING INTERNAL PROBLEM
Posted on Sep 10, 2009
SOURCE: sony dcrtrv18 model flashes c:31:23 or c:31:22
There´s only that way to fix the problem of C:31:23????? , i cant do something else by myself??
Posted on Jul 07, 2010
sonyspares
  • 89 Answers
SOURCE: My Sony Handycam DCR-DVD403 gives the error
The optical sensor may be defective. First try and clean with a clean white lens cleaning cloth.
Posted on Feb 10, 2011
Tip
50p/60p Converter-Transcode CX360 MTS to ProRes for FCP X Editing
Merge/Edit Sony CX360V 1920x1080 50p/60p AVCHD to ProRes 422(HQ)(*mov) on FCP X with Highest quality <br /><br />I used Sony HDR-CX360V to record 1920x1080 50p/60p AVCHD MTS files, which are not compatible with FCP X. So in order to edit the movies on FCP X, conversion from <b><a href="http://www.aunsoft.com/final-mate-mac/">MTS in 50/60 progressive mode to ProRes</a></b> is necessary. <br /><br />I've tried Clipwrap, Toast and Aunsoft to carry out the conversion. Clipwrap failed because it cannot export 50/60 progressive mode; Toast completed converting but the quality is badly affected. <br /><br />Only Aunsoft Final Mate for Mac successfully converted the 50p/60p MTS to ProRes 422 with no loss of quality. I really want to say that it is the best software to <b>Transcode Sony HDR-CX360V 1920x1080 50p/60p AVCHD MTS footage for FCP X</b> that I've ever used. <br /><br />Here is the step-by-step guide to quickly <b><a href="http://canon-videoconverter.com/2011/07/transcode-sony-cx360-50p60p-avchd-mts-footage-to-prores-422-hq-for-fcp-x-editing/">Convert/Edit Sony CX360 50p/60p MTS to ProRes 422 (*.mov) on FCP X</a></b>. <br /><br />1. Importing 50p/60p AVCHD MTS files to Aunsoft Final Mate for Mac <br />Use a USB cable to Connect Sony HDR-CX360V to Mac. Follow the popup window and wizard to complete the import. <br /><br />2. <b>Merging and converting 50p/60p AVCHD MTS files</b> to what you want. <br />After the MTS movies are imported, select one or several videos you would like to convert and then drag and drop them to Movies tab. You can choose the files to be joined as one whole, or create a single movie for each file. Then click the "set parameter" button. Choose Apple ProRes 422(HQ) (*.mov) under Final Cut Pro as its output format and choose "50" (or 60) for the frame rate. <br /><br />3. Export Apple ProRes 422(HQ) for editing on FCP X <br />After setting the output format and frame rate, click the "Export" button and conversion from <b>1920x1080</b> 50p/60p AVCHD MTS files to Apple ProRes 422(HQ)(*mov) starts. <br /><br />After the conversion is completed, <b><a href="http://www.aunsoft.com/final-mate-mac/">Import and Edit ProRes 422 (HQ) on FCP X</a></b>. <br /><br /><b>Tips:</b> <br />If you want to join/merge Sony HDR-CX360V AVCHD MTS clips and <b>play on WDTV Live with original quality</b>, you can use Aunsoft Final Mate to import MTS files and flawlessly export MKV without transcoding.
on Jul 27, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
5 flasing red lights and no power supply
Five flashes to Sony LCDs inidicates [IKR Error at power on]. This fault is likeley to be with the main board and is very difficult to locate. In most cases, the main board might need replacement.
Jan 27, 2013 | Sony BRAVIA KDL-40V2000 40 in. LCD...
Screen E:91:01 what does it mean?
Most probably the issue is with the lens. Service is required if the issue persists after power resetting.
Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder.
2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder.
2. Disconnect AC power adapter.
3. Remove the battery pack.
4. Move the POWER switch to the CAMERA position for 15 seconds.
5. Move the POWER switch to the OFF position.
6. Reconnect the AC power adapter or reinsert the battery pack.
7. Turn on the camcorder.
If the issue persists after following all the steps service will be required.
Jun 23, 2012 | Sony Handycam HDR-CX360V Camcorder
I bought my HDR-XR150 last year on Sept 2010 in SM Fairview. After 2 weeks I noticed whenever I shoot for longer period like continuous shooting of 30 min, it gets data error. After that the time is...
Slow down. Define the problem. Tell them what you want. Answer their data gathering questions (They are trying to answer YOUR questions--Listen to theirs). Give them concise, to the point, courteous, clear, answers, without complaining or having a whine in your voice or attitude.
Then, accept reality. If a 2010 purchase is out of a warranty, decide if you want to pay for fixing, or pay to replace it. You pay when its out of warranty. That's our society's decision to have the business laws and customs that we do. Accept It.
Think about it, man. Put yourself in the other guys perspective. Look at your question for instance. We don't know what an HDR-XR150 is. We don't know where SM Fairview is (and does it really matter? does that help you?).
Approach an adult situation as an adult, and watch how much further you get towards the result you want.
Mar 17, 2017 | Sony Hdr-xr150 Hd Handycam Camcorder
Have E:61:10 flashing up on screen. cannot find it in manual. can you help. Sony hdr-cx520ve
error code alerts user for malfunctions detected by the camera. the error E:61:10 would pertain to the zoom mechanism malfunction. issue may be with with lens block zoom MR sensor or zoom motor drive circuit. 1st step troubleshooting steps would be to reset camcorder (check manual for reset button location) and power reset (remove battery and leave camcorder w/o any power source for a minute). if still the same then service would be required. hope this info helps. thanks.
Jun 02, 2010 | Sony Video Cameras
I get a error code 30:23 on my HDR HC3 and it won't play or
Sony is pretty secretive about the :23 code. It can't be found anywhere. Sony recommends you do the following:
  2. Remove the battery or disconnect the AC power adapter for 120 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
Nov 12, 2009 | Sony Handycam HDR-HC3 HDV Digital...
E:91:01 in DSC-W80
I can't recall all the Sony error codes off the top of my head, but I believe E:91 is that your flash is not working.
Can you take pictures at all or do you get just the error code? If you can take a picture with the flash off then your flash needs to be replaced.
If you can't use the camera you need to first press the reset button, then reset all camera settings to default.
1-3. PROCESS AFTER FIXING FLASH ERROR
When "FLASH error" (Self-diagnosis Code E : 91 : 01) occurs, to prevent any abnormal situation caused by high voltage, setting of the flash is changed automatically to disabling charge and flash setting. After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the HOME screen.
Method for Initializing the Flash Error Code
Initialize
Initializes the setting to the default setting. Even if you execute this function, the images stored in the internal memory are retained.
1 Select [Initialize] with v/V/b/B, then press z. The message "Initialize all settings" appears. 2 Select [OK] with v, then press z. The settings are reset to the default setting.
To cancel the resetting
Select [Cancel] in step 2, then press z.
· Make sure that the power is not disconnected during resetting.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01
easily just reset the camera with a pencil.
Aug 14, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Sony Handycam HDR-CX360V Camcorder Logo
740 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
