Question about Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus manual washer model number 110.47532602 unlock child lock
Hi there, I woke up this morning wanting to do my sunday laundry...and I'm not able to. My washer is a Kenmore HE2 Plus Washer with the Model #: 110.47532602. The washer will not start, but I know that it is being powered as the 'Controls Locked' light is currently on. After a few hours of research, it appears to be a child safety lock. I have tried holding down the pad locked button on the right hand side (even for over a minute; praying it would work). I am wondering if this could be a potentially serious issue with the washer and if I should have someone in to repair it or if it is an easy fix? The washer is about 2 - 2 1/2 years old.
SOURCE: Kenmore HE3 CONTROLS LOCKED
Apparently there is a child lock on the machine and by holding down the spin and drain button for 3 to 5 sec. this will unlock the controls
Posted on Mar 31, 2009
vickygomar
  • 460 Answers
SOURCE: no manual ...no power- how do I work this machine? I'm able to lock/unlock it
THIS IS THE ONLY THING YOU CAN DO
Check that the unit is plugged into a working outlet and for
blown fuses.
This must be done by a THECHNICIAN SPETIALIST
Unplug washer or disconnect power.
Check continuity of line cord and line fi lter.
Check harness connections to CCU.
Plug in washer or reconnect power.
Check the touch-pad/LED assembly by selecting different
cycles and changing the modifi ers and options available to
confi rm the touch-pad/LED is responding.
Unplug the harness to UI and check with a DVM or VOM on
Connector UIP3 if correct voltage is present.
Pin 1: -5V
Pin 2: 0V (connection to Line or neutral is present in
normal operation).
Pin 3: -12V
If voltage not present and CCU is powered correctly (line
cord and linefi lter has continuity) the CCU is broken.
Disassemble the UI and check harness to UI and
Interconnection on UI between Center and Right Board.
Was this helpful?
Posted on May 12, 2009
SOURCE: HE2-plus washer will not start. error, status light shows "F-24"
I had a similair problem . Turned out the wire plug for the water temprature sensor had come unplugged. Plugged it back in near the lower rear of the drum and it worked!
Posted on May 29, 2009
  • 5 Answers
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Posted on Oct 10, 2009
mgprice
  • 744 Answers
SOURCE: kenmore he2 plus washer, controls locked on panel
Hi hit and hold the volume button until the control lock goes out. You should be all set. Mike
Posted on Dec 20, 2009
Testimonial: "That worked THANKS!"
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
My HE2 frontload washer will ot unlock hepl!!
Hi.... you have something in your drain pump or your pump is bad... if it locked you out
Mar 25, 2011 | Kenmore HE2 Plus Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
HE3 front load washer has "control Blocked" light is on. No button works on control panel.
You have locked the control via the "Child Lock." Look for the button with a small padlock icon on it, press and hold for about 4 seconds to unlock. That should fix ya!
Sep 11, 2010 | Kenmore HE2 Plus Front Load Washer
Washer flashing F22 and dooris locked and will not open. How do you unlock the door to reove the clothes?
This error occurs if the touch-pad/LED assembly is not able to
transmit/receive data to/from the central control unit (CCU).
Sample tech sheet for HE frontloada
Get your tech sheet by removing your bottom panel or posting your model number here
Duet manual and more here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 10, 2010 | Kenmore HE2 Plus Front Load Washer
My washer say f28 it is a kenmore HE2 plus
"F28" means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thank you!!
Jul 18, 2010 | Kenmore HE2 Plus Front Load Washer
Very loud spinning cycle
was the shipping bolts removed when it was delivered there are four in the back
Mar 29, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
471 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
