Question about Linksys EtherFast 8-Port 10/100 Auto-Sensing Hub (Desktop) [ EFAH08W ] (104832)
Auto-Sensing Hub - ' Router? '
I am using a ''Linksys EtherFast 10/100 8 Port Auto-Sensing Hub#EFAH08W'' and I cannot connect my two PC's together in order to sharefiles and the internet. I keep getting an IP error. It says somethingalong the lines of ''IP conflict''.
I asked around a bit and was told I needed a router.
The thing is I thought what I had was a router of sorts and it has worked in the past through other high-speed ISP's.
The ISP I use now provides HS access through a CABLE modemn as previously I had connected a HS ISP through the phone line.
My question, therefore, is ''Am I merely doing something wrong in the connection settings or do I need to replace the hardware?'' I have had it work for me in the past through other ISP's.''
Regards,
Steve
  • 41 Answers
Hello Steve,
A hub will work to hook two PCs together, but you will need a router to get any data transferred. You can set up your XP computer to act as a router in the Network Connections section of Control Panel. Be aware that one of your computers must have two network cards. One must plug in to the DSL and the other must plug in to the hub. If that's the case, click the "Set up a home or small office network" on the left side of the window and a wizard will pop up and help you the rest of the way.
If you don't want to deal with it, you can just purchase a router.
Let me know if you have questions - I'll monitor this thread.
Jason
Posted on Jan 26, 2009
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
Only one port works
Open ports.
(portforward.com will help)
Feb 16, 2010 | Linksys EtherFast 8-Port 10/100...
Though this is called a 'hub' it appears to actually be a switch as I cant packet capture traffic of other connected devices. Am I right about it being a switch? linksys etherfast efah08w 8x10 100 mbps
Despite the fact that the product bills itself as a "hub" in the product description Linksys mentions "Internal store-and-forward switching for effective traffic reduction" which is only used in switch gear.
I think you have a switch on your hands. Otherwise, you may have a problem with your packet capture software.
Oct 30, 2009 | Linksys EtherFast EFAH08W (73P2325)...
I have a Linksys 5 port workgroup hub. I have 2 computers and a printer on it and it all works well. I have a satellite connection with the modem coming into the hub. That works well too. I now have...
have you tried simply disconnecting the router from its power and data source, remove the power source from the modem, connect the router back to the modem,(with all the systems allready connected to the router), restore power to the router, then finaly restore power to the modem. after a few min the router should automatically sense multiple requests for dns and ip services and asign addressess accordingly.
If that makes no diff, watch the led light on the router that corresponds to the port that the non-functioning system is docked with. when attempting to access the internet, does the led blink? if it blinks fast and you also see that the "modem link" is flashing then there is a connection, and any lack of access to the internet has to be a firewall setting.
simply go into your router settings by typing 192.168.1.1 in your web browser and using "admin" as the username and leave the password blank(that is unless you have changed all that)
you should be able to view all the computers currently active on your network and the ip assigned to them. you may see that port 5 has been restricted, in which case the easiest way from the very beginning would have been to simply take a ball point pen and hit the reset button on the back of the router.
on the other hand, try that first then the other options above as you may save yourself lots of time and headache
GOOD LUCK!!!
p.s. dont forget to rate this post!! :D
Mar 16, 2009 | Linksys EtherFast 10/100 5-Port Auto...
Can't get two computes to run internet at the same time
If you login to your router and make sure DCHP is enabled, and then go to Services (services.msc) on your computers and make sure that the DCHP Client is running, it'll automatically assign IP addresses for your computers and they'll both connect okay.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Linksys EtherFast 10/100 5-Port Auto...
Help
First, FYI, I hope you mean Switch and not Hub and I am to assume your Router's LAN ports are all in use as to why you want or need the 5 port Switch and that you have Wireless Access Points or maybe your Router is a Wireless Router.
Next, you have to connect your 5 port Switch to your Router LAN port. Next you need a Wireless Access Point device to plug into your 5 port Switch. It would be helpfull that all your devices are of the same name brand also.
Now you have a Wireless network.
Thanks,
podum
Sep 11, 2008 | Linksys EtherFast 10/100 5-Port Auto...
Hub
There could be a power problem going on with the hub. Are you able to connect fine to the linksys?
Jun 14, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
EZXS55W 5-Port Workgroup Switch
This is a wired network switch your inquiring about. Is this plugged into a wireless router?
If so what brand is the router.
Jun 10, 2008 | Linksys EtherFast 10/100 5-Port Auto...
Linksys EtherFast 8-Port 10/100 Auto-Sensing Hub (Desktop) [ EFAH08W ] (104832) Logo
200 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
