Question about Whirlpool Washing Machines
Hot water barely trickles into my whirlpool imperial seventy washer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Jan 20, 2013
  • 1314 Answers
SOURCE: GE Washing machine cold water barely dribbles in
well the first thing i would do is take the cold line loose from the washer get a large bucket and open the cold line with the hose off and see what kind of pressure there is if very little need a plumber or in crese your well pump pressure check your screen while you have the hose off if all of this is ok id replace the washer water valves
Posted on Jan 19, 2008
docjohn174
  • 943 Answers
SOURCE: replacing spin belt whirlpool clothes washer
hi thanks for the question this problem can be a lid switch also if the lid switch is bad , it wont send powerdown to the wig wag solenoid . the spin solenoid is mounted on top of transmission , when plunger on solenoid is activated it drops the clutch and spins , if the solenoid is bad then it wont activate the solenoid , to test to see if you have a bad solenoid disconnect power , on the solenoid you see 4 wires just the red on the left and yellow on right reverse these 2 wires plug in washer . select spin .activate washer if the washer starts to wash on spin the solenoid is ok then i would change the lid switch thanks fr the question THE APPLIANCE DOC
Posted on Sep 11, 2008
duby1990
  • 367 Answers
SOURCE: Kenmore 90 series washer no hot water
CHeck to see if the screens in the water valve are plugged. If not the hot water side of the valve went out. Replace the water valve and it will fix both the hot and cold problem.
Posted on Nov 19, 2008
jmgldsmth
  • 1869 Answers
SOURCE: leaking tub on whirlpool washer
replace the main (under tub) seal
Posted on May 04, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
Posted on May 23, 2009
My Whirlpool Duet washer is making a loud squealing noise when filling with cold water, and/or the water is reduced to barely a trickle. It does not make the noise/reduce cold water flow every time.
Hi.
Try to remove the sand filter(s) from the inlet hose. Both on the valve and on the water crane(tap) end. Common problem.
Usually this is the problem, but not always.
/ Geir
Technical Engineer
Sep 27, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Top loading washer
well first check for kinks in the cold water hose and also see if there is anything blocking the water flow from the hose.
If all looks find, then try replacing the solenoid valve for the cold water intake
Please let me know of anything you find or have questions on
Sep 29, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool lbr5232eq1
assuming you have a decent flow rate and pressure to the machine from the fill hose I would suspect the hot water valve is faulty
Mar 04, 2014 | Washing Machines
Cold water trickles into the tub while it is being filled up
The hot and cold water supply hoses that connect the washer from the water supply faucets on the wall to the water connections on the back of the clothes washer usually have filter / sediment screens within there connection fittings at the end of the hoses, these will collect dirt,sand, calcium deposits, etc.,when they trap enough of these materials they will plug up and restrict the flow of water into the clothes washer. Turn off the water faucets at the wall, and you should do this for both hot and cold hoses, disconnect the hoses from the washer and the water faucets, look into the hose ends and pull out the screens and clean them out by running water and what ever you can use to clean them completely!!!!!
Now look inside the water connections on the back of the clothes washer,where you screw the hoses on the washer, and check to see if there are filter screens in there, if there is, remove them and clean out completely also, then reverse the removal process and reconnect the hoses, makeing sure to connect the hot and cold hoses to the right connection on the back of the clothes washer!!
Try filling the washer with water to see if you have corrected the problem.
Make sure hot and cold hoses are correct on the back of the washer!!!!
GOOD LUCK !!!!!!
Aug 03, 2010 | Whirlpool Washing Machines
Hot water barely trickles into washing machine
Check the hose at the end where it connects to the washer (the inlet valve unit). There may be a screen there also that needs to be replaced or cleaned. If not then the hot water solenoid valve is probably gunked up with the same type of stuff you found in the filter screen. You may be able to clean it enough to get it to work but replacing it is just as easy and not very expensive. (Even cheaper see if you can salvage one from an old machine at the dump or that someone has left at the curb--the units are very standard across many manufacturers in the tU.S.) Both the hot and cold water valves are in the same unit.
Jul 23, 2009 | Admiral AW22 Top Load Washer
Washer wont allow cold water
Mixing valve should lock out the hot water when on the cold water setting. Either your hoses are crossed, or the mixing valve is flipped. To see if one of these is true, try it on a hot water setting to see if cold water comes in, or try just swapping the water hoses.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Whirlpool LSR8233EQ0 Hot water (only) trickles
you need to replace the hot cold inlet water valve on the back of washer,the solinard for the hot water is not opening all the way,this is a common problem on all washer,if you go to sears .com click on parts put in your model number you can get the part and it shows you where it goes,hope this helped you-mike
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
