Question about Sony STR-DN-1010 7.1 Channels Receiver
Sony str 1010
Please help...where i can find source power for this receiver,
My girlfriend put receiver directly to socket 220v...and blow up !!! prime transformer,after that i check fuse but passed over it.
Me i used with a professional transformer 220v-to-110v.
I buy this receiver from US to used in Europe.
Please , from where i can buy this spare part's of receiver...
regards
Leo
5 Suggested Answers
  • 5 Answers
SOURCE: sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Posted on Mar 19, 2009
SOURCE: I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Posted on May 01, 2009
SOURCE: Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
Posted on May 27, 2009
rogrrabbit
  • 986 Answers
SOURCE: I HAVE A SONY STR-KG700 5.1 SISTEM, AND SOON I`LL
I would just buy a transformer for the unit 220 to 120. That way when you move back your good to go.
Posted on Jun 14, 2009
Sony AVR STR-DN1040 didn't support 220v and broke
in some devices bring a swich for 220 and 110, the problem is that you connected in a line of 220, and We will probably be hurt the transformer internal fuse, you have to open it to bypass it or change it after that you have to protect the device with unfoco in series just in case you have a short.
Sep 07, 2013 | Sony STR-DN1040
Speaker Imedance Matching - Sony STR DE 997 receiver with 120Watts - 8 ohms output with Benz 6 ohms..Tower Speakers
hi pawanh75,
thanks in advance for a very informative setup that you have.
Here are some of possible mods , only if you like and can DIY
( or have someone to help you )
• Using a 6 ohms impedance for an 8 ohm impedance amp clearly
denotes that it heats up the output stages.
(please forgive my very technical words)
• One way to lessen the heat is to install a blower .
Use a 220V blower on top of the receiver.
( air should be in going up direction ).
• Before I proceed further please indicate if having the speaker
connected and having a zero volume , and just letting the receiver
in an "On" state deliverately produce heat on the receiver, or just
when the volume is at medium to high level.
If it s running hot at zero level with speaker , please post.
If it is running hot even without speaker, post also
• It may also helps , if you have a powered subwoofer ( for the low's),
and set settings on your receiver to "small"
Let me know what you find to help you further.
Sep 11, 2012 | Sony STR-DE997 7.1 Channels Receiver
Sony STR-DN-1010
What is the problem with this device?
Apr 29, 2012 | Sony STR-DN-1010 7.1 Channels Receiver
Have a da555es stereo receiver. Fuses blow as soon as you plug it in to wall socket. Receiver is approx 10 yrs old and just started doing this. Any ideas?
If fuses blow out imediatelly its a sign that its something wrong in the imput area eg the power pcb or transformer pcb. try to see is there in its supply some electronical parts broken or some bad wire isolation.
Feb 18, 2010 | Sony STR-DA555ES
I have a Sony STR DB930. Something happend and it
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Feb 08, 2010 | Sony STR-DB930 Receiver
Apr 04, 2009 | Sony STR-D565 Receiver
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
Sony STR-DA5000ES 7.1 Receiver
its for digital decoding of the sound source. You need to connect a digital cable (ie optical) from the DVD player to the optical input in the receiver. The receiver should then decode the source into multichannel components ie 5 channels for example
Jul 23, 2008 | Sony STR-DA5000ES Receiver
Protector mode..
Cambiale los IC de audio que esten dañados.
Oct 13, 2007 | Sony STR-DE825 Receiver
Sony STR-DN-1010 7.1 Channels Receiver Logo
22 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
