Question about HP Pavilion dv6-1030us Notebook
I have HP Pavilion dv6 and i think my HDMI port is wore out and broken. Is there another way to connect to my TV?
    New Friend:
  • 11 Answers
You can connect if both devices are synced and Bluetooth enabled If not... Try a local computer repair shop. GeekSquad is great but costs lots.
Posted on Jan 25, 2013
SOURCE: HDMI connection on HP Pavilion dv9000
try going to windows mobility center & click connect displays
Posted on Jan 09, 2009
  • 72 Answers
SOURCE: driver for HP Pavilion DV6 for Inbuilt webcam Driver
Go to cyberlink.com download driver, you can also use Skype. Just remeber to check what version you have, this should be found in the manaul. Hope this helps
Posted on Feb 21, 2010
catwacker
SOURCE: Repair manual for HP Pavilion dv6 1245 dx
Go to hp.com. Click on support and drivers tab. Select "See Support & Troubleshooting Information." Enter your laptop model number. dv6-1245dx. Click on "GO". See: "What Type Of Support Do You Need?" Choose MANUALS. Scroll down the page and select "HP PAVILION DV6 ENTERTAINMENT PC - MAINTENANCE AND SERVICE GUIDE". Download that PDF format. It is relatively easy to get to the ribbon cable that connects the touchpad to the motherboard. It is connected via a ZIF connector. I had a dv1331se and the touchpad stopped working. I just reseated the cable in the connector and all was well. Hope your solution is as easy as mine was. You'll have to remove the trimplate just in front of the keyboard. Be careful with the connectors there. The manual is well laid out and the diagrams easy to follow. Good luck. HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
Posted on Mar 16, 2010
  • 341 Answers
SOURCE: Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
Posted on Mar 21, 2010
etaf
  • 779 Answers
SOURCE: HDMI, and VGA on HP Pavilion dv6 1359wm, S-Video
you need something like this http://www.amazon.co.uk/VGA-to-S-Video-RCA-Adaptor/dp/B000P3UB24 - but you may also need to see if the VGA display adapter supports the output, sometimes this also needs to be enabled to get it to work - other times it works just by using the VGA output switch - which will be one of the F keys look for a symbol of a screen and then use that F key and the FN key together to toggle the output from <laptop only><laptop and VGA output><VGA only>not necessarily in that order. The HDMI is a digital signal out and to convert to analogue for the TV will need an expensive convertor
Posted on Apr 22, 2010
Testimonial: "Thank you, they are digital TVs, just not HD, So still gotta go VGA."
Henches problem in hp pevilion dv6
Chandanipraj,
1) Hinges example,
http://www.ebay.com/itm/New-LCD-CCFL-Screen-Hinge-Set-Left-Right-for-Hp-Pavilion-DV6-15-6-Series-USA-/261104644529?pt=US_Laptop_Screens_LCD_Panels&hash=item3ccb0cb1b1
2) HP Support > Pavilion dv6-1050us Notebook PC > Main Supoort page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3860586&lc=en&cc=us&dlc=en&lang=en&cc=us
Manuals >
Click on -
It's a Service Manual,
Pictorial guide in replacing the LCD screen, and also replacing Hinges,
http://www.insidemylaptop.com/replace-broken-screen-hp-pavilion-dv6-laptop/
Just to add;
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6-laptop/
For additional questions please post in a Comment.
Regards,
joecoolvette
(Hi from the USA)
Oct 18, 2012 | HP Pavilion dv6-1050us Notebook
Can't seem to get my HP pavilion dv6 something to connect to my TV. HDMI cord i know is all right, but still it doesnt seem to connect. I get a "no signal" on TV, and no video or...
With the laptop connected to the TV, push the Windows Key and the P key at the same time. You will see a windows pop up, see the attached image. You want it to be on the Duplicate or Extend option. You can also try the Projector Only option.kiddfroster.jpg
Aug 18, 2011 | HP Pavilion dv6-1030us Notebook
I have the hp pavilion dv6 1355dx before...i could connect the hdmi cord flawlessly..but now i tried recently nothing comes up on the television...please help
Turn the pc on and boot it up with the HDMi cable connected. Sometimes you need to have them preconnected before you boot other times windows (vista/7) will recognize it. If this still does nto work try a new cable and or port on the tv. if still nothing then you probably damaged your hdmi port on the pc from either shock or wear.
Jun 29, 2011 | HEWLETT-PACKARD Hewlett Packard Pavilion...
When i connected my pavilion dv6 hdmi port to an hdtv noting happend neither my lnotebook felt any connection or the tv.
Try this..
* Check i've cable is connected properly.
* Look for a setting named " external monitor ".
More info can be found at:
http://www.computerhope.com/issues/ch000801.htm
Jun 19, 2011 | Computers & Internet
My Hp DV6 3129 laptop get overheated everytime and also the hdmi port got broken within 3 months. Have sent HP for replacement/fix twice. However none of them were fixed and they are asking for half the...
HP Dv6s are notorious for overheating and it is most likely a defect on the manufacturing side of things. Either request a different model of laptop or have a professional dissemble the laptop to reapply cooling gel to the processor properly. Be warned, the latter option will void your warranty, which I assume is still in effect if you are able to return the laptop for repairs.
May 09, 2011 | HEWLETT-PACKARD HP Pavilion dv6-3129nr...
My hp pavilion dv6-2028es all usb port stops working.....what can i do...
CHECK THE BIOS SETTING --IF CONNECT THE OPTIC MOUSE THE MOUSE IS LIGHT MEAN THE USB IS BROKEN GET THE PCMCIA TO USB ITS ONLY 10$ ITHINK
Mar 21, 2011 | HP Pavilion dv9000z Notebook
Connected laptop to tv, but sound only come from laptop. How can I make the sound come out from tv?
If your laptop has a HDMI output, and your TV has a HDMI input, then use a HDMI-to-HDMI cable, which carries both "audio" and "video" signals.
Otherwise, you need a cable from the "headphone" output from your PC into the "RCA" stereo-audio inputs into your TV.
Dec 20, 2010 | HP Pavilion dv6-1030us Notebook
I want to know and identify the parts of my laptop
On the right hand side starting from the front to the back, the ports are
1. (2) USB Ports
2. TV/Cable jack if applicable, some models don't have.
3. RJ-11 Modem Jack
4. Security cable Slot
5. Power Connector
On the Left side Starting from front to back. the ports are.
1. Express Card Slot
2. Digital Media Slot (below the Express Card)
3. 1394 (firewire) slot (some models don't have)
4. USB Port
5. E-Sata Port
6. HDMI Port
7. RJ-45 Ethernet Port
8. Expansion Port Type 3 (attaching docking station etc.)
9. External Monitor Port
Oct 10, 2009 | HP Pavilion dv6-1030us Notebook
How do i hook up my hp dv6500 LT to my hdtv?
for connectin it to TV u need a cable for it. like say HDMI cable. It comes very costly. and u should be havin a LCD tv..
Sep 03, 2009 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
HP Pavilion dv6-1030us Notebook Logo
272 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
