Question about Home
Hansgrohe shower valve leaks
Shower drips when closed
    Scholar:
  • 72 Answers
If the shower drips constantly after you turn it off you will need a volume control cartridge of some sort. Without being abe to properly identify your valve I do not know what type of cartridge you will need. Feel free to contact me at Hansgrohe Tech. 1-800-334-0455 press 2 for tech and ask for David Scarborough. I can help identify the valve and if it is ours I can get you the part numbers you will need to make repairs.
Posted on Jan 21, 2013
  • 44 Answers
SOURCE: leaky posi temp shower valve
coming from the uk it sounds that when you mention it leaks at night its a possibility thats when the water pressure increases & the valve starts to drip?
i know its not a solution but it may help you understand why its dripping at night.
Also the seals might be damaged in which case thats why its dripping check them for damage. make sure when you put the new cartridge in that you put some silicone grease around the seals as this helps the insertion & helps protect the seals from damage.
Kindly
Richie
Posted on Dec 15, 2008
  • 35 Answers
SOURCE: dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Posted on Feb 01, 2009
Bati99
  • 88 Answers
SOURCE: Shower valve leaking
here is the link to the pdf file http://www.plumbersurplus.com/pdf/07606.pdf
If you cant get directly to it from the above link, go to plumbersurplus.com/prod/danze-D51001BNT then click on "documents"
Posted on Apr 17, 2009
muralme
  • 20 Answers
SOURCE: shower leak is it possible from Moen diverter to shower head
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
Posted on Jul 30, 2009
  • 50 Answers
SOURCE: Moen shower head drips. Single lever shower only.
Probably need to remove and replace the cartridge. Often sediment will tear part of the o-ring or seal on the cartridge and cause this problem...
varies by model, but generally, remove the cap on the knob, unscrew the knob, remove the keyed sleeve, remove the round trim plate & shut off the service stops (verify they are fully closed by pulling out on the valve stem) next remove the retaining clip (needle nose and be gentle) that holds the cartridge in place, then pull the cartridge straight out with vice grips or similar (or get a puller). clean the cartridge, flush out the valve body by slightly opening both service stops, reinstall cartridge and clip, open service stops and see if it still leaks. if it does, take your cartridge to the store (any reasonable HW or plumbing store should have a replacement) and get a new one. then reverse the process to reinstall.
If you send me the model I'll get you more specific instrucitons and pictures...
Posted on Oct 11, 2009
Hansgrohe shower only gets Luke warm
Depending on model, age and type of valve there could be several solutions. In order to give the most correct answer I will need the model number of the mixing valve/trim in question. If you need help identifying or servicing the unit feel free to contact me at Hansgrohe 1-800-334-0455 press 2 for tech and ask for David Scarborough. I'd be happy to help.
Jan 23, 2013 | Hansgrohe Home
Hansgrohe PB shower cartridge (brand new) passing water thru cold side with valve turned off. Six-year old cartridge replaced the other day. Removed side filters and cleaned. O-rings ok. Applied silicon...
What is the model number of the unit in question? What color was the old cartridge in the valve and the new cartridge that you replaced it with? If no model number do you have any pictures of this valve/trim in question? It could be that you got the wrong replacement cartridge or something is not properly aligned within the valve. Feel free to contact me direct at Hansgrohe. I'd be happy to help. 1-800-334-0455. Press 2 for tech and ask for David. Or email me at david.scarborough@hansgrohe.com
Jan 07, 2013 | Hansgrohe Plumbing
Hansgrohe shower head leaking
If the shower head is constantly dripping and not shutting off it is most likely the valve in the wall not the head itself. How is the head leaking? Where/when does the water show up? Feel free to contact Hansgrohe Tech at 1-800-334-0455. Press 2 for tech. We would be happy to help.
Dec 01, 2012 | Hansgrohe Home
Adjust hot water on hansgrohe metro shower
The hand shower and wall bar does not control temp. The valve in the wall would control the temperature of the water going to the shower. I would need to be able to identify the model number of the valve in the wall to be able to give accurate instructions on temperature adjustment. If you need help identifying this valve feel free to give me a call at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough
Oct 13, 2012 | Hansgrohe 06496 Croma Hand Held Shower -...
How do I change a hansgrohe thermostatic shower cartridge
Different valves have different techniques for replacing thermostatic cartridges. Without knowing specific model numbers I cannot give accurate instructions for the procedure. If you need help identifying the valve feel free to contact me at Hansgrohe Technical. 1-800-334-0455. press 2 for tech and ask for David Scarborough. I'd be happy to help.
Aug 30, 2012 | Hansgrohe Home
Hansgrohe shower head water leaking out of connector
Is it a Grohe or Hansgrohe shower head? If it is a Hansgrohe shower head the first thing to check is if the self sealing filter gasket is installed at the connection to the shower arm. Hansgrohe shower heads have a black self sealing filter gasket in the head that some people remove assuming it is a flow restriction device. It is only a filter and does not restrict flow unless clogged with debris. Next make sure the flow restriction device below the filter gasket is still installed. On some models removing the flow restrictor will cause water to be expressed from the air injection ports near the pivot ball. Feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for Technical and ask for David Scarborough
Aug 20, 2012 | Grohe Home
I have a Hansgrohe interaktiv shower panel. The shower head keeps dripping. I have had a handyman change the washers and clean the filter. The dripping stops for a week or a month then starts again
After eight years of service it is likely the cartridge has worn out. The Interaktiv shower panels use a ceramic cartridge that do not have seals or gaskets that can be replaced. You will most likely need to purchase a replacement shut off diverter unit through your local dealer or online dealer. If you need help with part numbers feel free to call me at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
May 22, 2012 | Home
Hansgrohe clubmaster shower head is dripping
First step is usually just taking off the shower head and apply a descaling solution but make sure you read the intructions for which material it can work on eg brushed nickel.
May 15, 2012 | Hansgrohe 28496821 Clubmaster Shower Head...
One of Two bodyjets not working
there is a strainer in the valve body and the head if you remove head and look inside you should see strainer remove and clean. if it is in valve you made need plumber familiar with grohel
Feb 23, 2009 | Hansgrohe Shower 28466 Bodyvette Bodyspray
Home Logo
5,111 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
