Question about GE Spacemaker JVM1640SJ Microwave Oven
1999 ge spacemaker xl1400 not heating has plastic smell emitting
Everything else working just not heating. Have noticed a slight "plasticy" smell when I ran earlier and learned it was not heating
    Top Expert:
  • GE Master
  • 12,223 Answers
Please follow this steps and fix it. God bless you
Microwave Runs, but no Heat OK, get ready, this micrwave oven repair can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
If the proper voltage is coming into your control board and you are not getting voltage at the MW relay, then you need to replace the control board. If voltage is interupted by a thermostat or switch from your testing to the control board, then replace that part.
Now, testing from the MW relay on to your transformer, high voltage capacitor, magnetron, and diode.Do not do any voltage reading from the secondary side of the transformer on, this can be a deadly microwave oven repair if you do not follow directions. This can result in electrocution and the "blowing-up" of your voltmeter, only do OHM testing with the power off and the capacitor discharged. Someplace in this circuit, usually before the transformer, you will have another thermostat to test. It is usually mounted on the magnetron. Do a quick OHM test to see if it is open or closed.
Now to test either the transformer, high voltage capicitor, magnetron, and diode, you must test each part separately. A good rule of thumb, if your capacitor is bad, change the diode also. Another note, if you are working on an OTR model and you have determined to be one of these "heating" circuit parts, you can not test these parts until you take the unit down. If you don't have the parts with you and you have to order them, order the magnetron, capacitor and diode and you will have a 90% chance of solving the problem. If it is an older microwave, order the thermostat also, most times you can return un-used, un-opened parts. Check with your parts supplier. This way you only have to take the unit down once.
To test these parts, scroll down this page and you will see a chart with component tests. Follow the instructions to find which part(s) are defective in 1999 ge spacemaker xl1400 not heating has plastic - 1_23_2013_5_32_46_pm.gifir.
Posted on Jan 23, 2013
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: MICROWAVE IS NOT HEATING
HI, the actual device that produces the heat is damaged or faulty. this device is called the Magnetron. you will need to replace this part in order to restore the heating ability of this microwave oven.
Please rate and have a great day:)
Posted on May 29, 2009
  • 464 Answers
SOURCE: I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Posted on Nov 08, 2009
Testimonial: "Thank you great fast advice"
My 10 year old GE Spacemaker XL1400 microwave has stopped heating the microwave's contents.
probably a magnatron failure
take it to an appliance repair shop for a proper diagnosis and get a quote as repairs can be more expensive than new unit
Nov 24, 2015 | GE SpaceMaker Microwave Ovens
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker xl1400 microwave quit heating. worked fine, timers, clocks and everything else is fine
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
lkkg
Nov 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL1400 appears to be working, but is not
It could be an issue with the diode, high-voltage capacitor or the magnetron itself.
Please try following the steps from this article:
http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Heating Problems
Magnatron or the HV Transformer. Each has a distinct odor, Mag is heavy and thick burning smell transformer is more electrical. Eric
Aug 04, 2009 | Microwave Ovens
May 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemakerxl1400 suddely stopped heating,all other functions are working.is it due to some small problem
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
