Memory replacement v5535
I have ordered a 1gb memory upgrade and would like to know how to put it in the spare slot? Many Thanks.
    Problem Solver:
  • 16 Answers
Most of the laptops come with 2 memory slots . Hopefully one is left empty . It is situated at the back of your laptop the cover of which will be having the sign of a memory module. A single or 2 screws will be holding the cover in place. The memory usually is held in place with 2 clamps. Just slightly push claps in outward direction and it should pop up the module. Just clamp it back in place.
Posted on Jan 26, 2009
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
Dec 31, 2010 | Compaq Presario Notebook
I have a 512 mb 667mhz sdram on D102Ggc2 i decided to up grade memory. Can i upgrade system memory without lose this 512 mb.
Yes you can. but make sure that you buy the exact same type of RAM stick that you have and put it in the other RAM slot so the Dual Channel feature will be active (dual channel makes data transmission/processing faster) and making your systems memory 1GB. However, your motherboard can utilize or handle up to 2GB or RAM so you can put also a 1GB RAM stick which will make your systems memory a total of 1.5GB (that will be the case if you really dont want to lose the 512MB that you currently have,
Hope this helps.
Jul 09, 2010 | Intel D102GGC2 Motherboard
I wanted to upgrade the memory from 1Gb(in two 500mb slots) to 2Gb so purchased 1Gb Crucial memory. If I put the additional memory in one of the two purple slots computer will not work. If I replace one of...
how may slots do you have??
if @ slots are there then convert your ram or replace it with 2 Gb and the 1 Gb othr......or make the 500 Mb convert it by ur dealer to 1 Gb whole...
Feb 15, 2010 | Evesham Axis 64 3200+ Choice...
Can I add 1GB memory chip in 2nd slot with a 512MB chip in 1st?
You can upgrade by inserting a 1GB PC2100 DDR SDRAM DIMM. I would put the 1MB in the first slot and move the 512MB chip to the second slot.
The 1GB should cost around $40.
Jul 05, 2009 | HP Pavilion 763n PC Desktop
Upgrading Memory on an AOpen MX46-533V
Well yes, in a way the amount of memory should match in each slot. So with two slots you can have two 512MB which will give you 1GB. Or you can get rid of those and use one slot and just put a 1GB stick in it. Finally, you can buy two 1GB sticks, put one in each slot and have is not recommended to put 512MB in one slot and then 1GB in the other slot. That will cause your computer to become unstable..hope this answers your questions.
Please rate this solution.
Apr 09, 2009 | AOpen MX46-533V (91.89U10.061) Motherboard
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Acer L100 memory upgrade
you can open it up and see, take out the ram to see what kind it is
Dec 24, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
