Question about Epson Stylus Nx415 Color Inkjet Printer 34ppm Pcs Photo Black C11CA44231 Eps
My epson stylus nx415 printer will not use cardstock
It uses plain paper ok but quit taking cardstock
  • Terri Thompson
    Terri Thompson Jan 22, 2013
    it starts to load then either stops or runs it right through. it will loadregular paper with no problem
SOURCE: I Have An Epson Stylus DX6000 Printer Problem
Yes I had the same problem. Well we looked online and found the answer. Pick up the printer and shake upside down (Carefully) and an EPSON badge fell out. On reboot of the printer the error E-04 solved. Printing happily. Well it worked for us.
Posted on Jul 24, 2008
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
  • 36 Answers
SOURCE: I just bought an Epson Stylus NX415 and the it
Sounds like you have either a defective cartridge but if both cartridges are not being recognized it's likely a problem with the printer.
Take it back to the store you bought it from for a refund or replacement.
Posted on Oct 25, 2009
pineworks
  • 4041 Answers
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
tech-agent
  • 83 Answers
SOURCE: loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper Follow these steps to load paper: step_1.gif Slide the edge guide to the left. ha5280001h.gif step_2.gif Fan a stack of paper, then tap it on a flat surface to even the edges. step_3.gif Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly. ha5280002h.gif ha5280003h.gif mark_no.gifNote: Leave enough space in front of the printer for the paper to be fully ejected. Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures. Make sure the paper stack fits under the fon4_99.gif arrow mark inside the left edge guide.pls vote for me
Posted on Mar 16, 2010
How do i get compatible cartridges T069 to be recognized by the nx415 Epson printer?
i found out a site that offers cheeper compatible ink cartridges... try to check out this site: http://www.swiftink.com/Epson-Stylus-NX415-Ink-Cartridges-s/3544.htm. they do offer warranty should these inks dont work.. and they are safer to use because they do have quality control even thought its remanuctured.
Jul 14, 2011 | Epson Stylus NX400 InkJet Printer
I am printing a collage of photos on cardstock (for a calendar) using an Epsom Artisan 810. White vertical lines appear evenly spaced along the landscape format. My wife says it is due to the poor...
When you print photos, in Preferences you have to set up the quality of the print to either Best or Photo whichever is the highest one in the list. Hopefully this will increase the quality of the printing, although this is not a photo printer. And you are correct, it's a printer problem.
Nov 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
HOW TO CLEAN ROLLERS FOR EPSON RX680 PRINTER
Follow these steps to print the nozzle check:
  1. Make sure plain, letter-size paper is loaded in the sheet feeder.
  2. Make sure the CD/DVD tray is not inserted in the Epson Stylus and the CD/DVD guide is in the paper printing position.
  3. Press the Setup button.
  4. Press cp_button_41_er.gif or cp_button_42_er.gif to select Maintenance and press OK.
  5. Select Nozzle Check, then press OK.
  7. Press cp_button_6.gif Start to print the nozzle check.
Oct 28, 2010 | Epson Stylus RX680 Color All-in-One InkJet...
How do I change the cartridges in my Epson Stylus Inkjet Printer NX415
here is the link for your epson stulus NX415 manual
you need to download this file from there
click where you find this written on the page
start here
PDF file
This document contains quick setup instructions for this product.
and here is the link
Click to Download
then a pdf file downloaded check on install ink cartridges page.
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 23, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Epson NX415 Paper jam. I took paper out but it's
Check for other bits of ripped off paper stuck in your machine.
Try turning off your printer for 30 secs and turn it back on.
Mar 11, 2010 | Epson NX415 All-In-One Printer
I cannot get my epson stylus nx410 CD to load my driver. Went to epson centre no listing for printer
Epson does not make a NX410, They only make a NX400 and NX415.
Check the back of the printer for the exact model number. If when you check you it is for some strange reason it is a NX410. I would try one of the drivers from the NX4000 or NX415 as drivers for printers typically don't vary too much between similar models and may provide a good temporary fix to your problem.
You can also call epson US (562) 276-4382 6am to 6pm PST mon-fri
Driver link to NX400
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=106004&prodoid=63075469
Driver link to NX415
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=128287&prodoid=63083741
Jan 08, 2010 | Epson Stylus NX400 InkJet Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Paper feed problem if not using plain paper
Check if you are selecting the correct type of paper on paper settings. If yes, delete the existing printer driver. Then install printer driver. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14082&prodoid=24875245&infoType=Downloads&platform=Windows
Apr 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus Nx415 Color Inkjet Printer 34ppm Pcs Photo Black C11CA44231 Eps Logo
292 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
