Question about HP Compaq 6710b Notebook
Own a HP Compaq 6710b and does not start when pressing power button
  • HP Master
  • 27,725 Answers
If your laptop won't turn on, you could have any number of problems. The problem might be a genuine power issue derived from either battery failure or simply a loose AC adapter. Conversely, it may only appear to be a power failure, and the problem may lie with another component. Errors in brightness settings and LCD display malfunctions can both make a laptop appear to be powered off, and all these problems will need to be corrected.
Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings. Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet. Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary. Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover. Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced. Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too. Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws. Hope this helps.
Posted on Jan 20, 2013
  • Giosan Jan 31, 2013
    Power supply current passes through it though is defective. A compatible source to solve the problem. Thank you.
  • Brian Sullivan
    Brian Sullivan Jan 31, 2013
    thanks for replying hope it all worked out
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 123 Answers
Try to determine if there is any power going to the laptop (i.e. Power button or other indicator lights lit up). If power is going then try a hard reboot (Unplug laptop, take out battery, hold power button down for 30 seconds, then once done put battery back in, plug the laptop back in and power laptop back up.).
If there isn't power you might need to replace the power cord or try plugging power cord into a different outlet. Also, you could try taking out the battery and leaving the laptop plugged in. Sometimes a bad battery can be the cause.
For more IT tips try visiting my youtube channel at: https://www.youtube.com/user/jrlake2414?sub_confirmation=1
Posted on Mar 22, 2016
  • 239 Answers
SOURCE: HP Compaq 6710b is hanging up in the boot up.
start in safe mode and do a system restore
Posted on Dec 22, 2007
florin_decad
  • 203 Answers
SOURCE: No sound from internal speakers on HP Compaq 6710b
http://welcome.hp.com/country/us/en/support.html
THERE YOU WILL FIND ALL YOUR DRIVER'S
Posted on Feb 04, 2009
SOURCE: Activate Wireless netwerk connection HP Compaq 6710b
have hp computer,unable to switch on wireless connection.im just a novice.HELP
Posted on Mar 16, 2009
FoxSysPCTech
  • 107 Answers
SOURCE: how do you remove the power-on password for
Sadly, you must pull the laptop apart and reset the BIOS...well unless you know the password, then just remove it through BIOS.
Posted on Jul 17, 2009
TheFishGuy
  • 5 Answers
SOURCE: on a hp compaq 6710b where/ how do i switch wifi on?
The wireless button should be located on the top left part of your laptop. It will be the 3rd button from the left.
11bffdfe321d68aa11aa600332bfe03c.png e8721ff914fb66ee83d789398c8a2a31.png e8721ff914fb66ee83d789398c8a2a31.png d44fad740e4749adb4fe5f87725dd44f.png 1. Volume mute button with LED indicator
2. Volume scroll zone with up/down LED indicators
3. Integrated microphone 4. RJ-11/modem port
5. Optical drive 6. Media Card Reader 7. 2 USB 2.0 ports 8. HP Fingerprint Sensor 9. Integrated stereo speakers 10. Touchpad with scroll zone 11. Touchpad Buttons 12. Hard drive activity / HP 3D DriveGuard LED 13. Battery charging LED
14. Power/standby LED
15. Wireless on/off LED
16. Power button with LED
17. HP Info / HP QuickLook button with LED indicator
18. Wireless on/off button with LED indicator
19. HP Presentation button with LED indicator
20. WLAN antennas (with WLAN option)
21. WWAN antennas (with WWAN option
Posted on Jul 29, 2009
How to booting from cd rom on hp compaq 6710b and install ubuntu
Press F9 at startup. This will give you your boot menu. You will then be able to boot from your dvd-rom / upgrade bay etc. 27bd1b34-d4db-4891-9414-81770f593217.jpg
Sep 24, 2014 | HP Compaq 6710b Notebook
Hp compaq 6710b is not powering when i put the powerpack
Does that mean it DOES power up without the battery?
Or by power pack do you mean the AC adapter?
Replace it. either way
Apr 09, 2014 | HP Compaq 6710b Notebook
Hi, I have an HP Compaq Laptop 6710B which
Usually this is cause by a defective battery. Replacing the battery should fix if.
Thanks Tonm
Aug 07, 2011 | HP Compaq 6710b Notebook
My HP Compaq 6710b was fine and then just died, what happened?
First,you should check wether the connected power or Compaq business notebooke 6710b battery is OK.If There are no problem ,then there maybe some strange matter !
Sep 23, 2009 | HP Hewlett Packard Compaq 6710b Notebook...
HP Compaq 6710b
It should be the third button to the right from the top byt the power button. Here is a link to a pdf that shows where everything is on your model.
http://h20195.www2.hp.com/V2/GetDocument.aspx?docid=0900a5a5821030aa&cc=bg&lc=bg
May 23, 2008 | HP Compaq 6710b Notebook
Dec 22, 2007 | HP Smart Buy Notebook
HP Compaq 6710b Notebook Logo
317 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
