Question about Tools & Hardware - Others
Trying to find a replacement blade that holds battery in place for my Black and Decker FS240BX
My orange blade clip that holds the battery in place broke, need to see if anyone knows where I can buy a replacement
    Top Expert:
  • Tools & Hard... Master
  • 42,979 Answers
Black and Decker might be able to supply it
Posted on Jan 20, 2013
How do you change a blade on a black and decker Rota-twin GR101 mower
my search shows that up as a
black and decker /flymo electric mower type
no picture on the parts list
of the rotating part being metal
two types of blade sets ...says its plastic and just clips on
is that for real ....plastic clip on mower blades
will this work
pull to the larger slot to release the old blade and back to the smaller slot to hold the new blade in place
Jun 15, 2016 | Cars & Trucks
How to hold shaft when replacing blade
You should hold the blade while loosening the bolt that holds the blade.
Jim
Aug 05, 2011 | Black & Decker Black and Decker Mm575 18"...
I am trying to install a blade on a circular 18 vold cordless circular saw and cannot remove the bolt that holds the blade in place. Is there a way to lock it down.
some saws have a button to hold down that will lock the blade in place. if yours doesnt have the button, try putting a screwdriver in one of the cutouts or on the blade tip itslef and lock it in position. your problem may be that the screw on the saw is actually reverse threaded. they usually are reverse threaded.
Dec 24, 2010 | Black & Decker Saws
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
PHS550B saw blade change
MOST TIMES THERE IS A ARBOR LOCKING BUTTON ON THE HOUSING NEXT TO THE BLADE HOUSING.YOU HAVE TO HOLD THIS DOWN WHILE TURNING THE BLADE SECURING NUT TO LOOSEN OR TIGHTEN THE BLADE,OR YOU CAN DO IT THE OLDFASHONED WAY FIND A VENT HOLE IN THE BLADE,STICK A SCREWDRIVER IN IT LOCK THE SCREWDRIVER IN PLACE THEN TURN THE NUT(WHILE UNPLUGED OF COURSE)HOPE THIS HELPED
Apr 24, 2009 | Black & Decker Saws
Replacing Black and Decker 18" lawn mower blade
Black and decker has a web page and 800 number which I can't locate rigth now
Sep 20, 2008 | Black & Decker 19" Electric Lawnhog...
Black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
May 19, 2008 | Black & Decker 19" Electric Lawnhog...
Tools & Hardware - Others Logo
50 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
