Question about Gateway NV5215u Notebook
How do i remove power switch on nv52 laptop - Gateway NV5215u Notebook
  • Gateway Master
  • 5,660 Answers
A) Remove the LCD Assembly (Display Assembly)
B) Remove the LCD Panel Bezel. (Display Bezel)
C) Remove the LCD Panel. (LCD screen)
D) Remove and replace the Power Button Board.
(And Power Button Spring, if needed)
The Gateway NV53 series of Notebook PC, is close to the NV52 series of Notebook PC.
(Along with the NV54, NV56, NV58, and NV59 series)
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
On this page go down to Gateway 400. (400 in Blue)
Drop down to the second line, go across, and click on the blue -
NV53.
Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (NV53) it may take up to 30 seconds, before the first page comes up.
(The file is downloading in the background, and will not show until fully downloaded)
The page number box located at the Top, and the actual manual page are Not the same.
(Page number box is located to the Right of the Down Arrow)
When I refer to a page it is for the Adobe Reader page number box, at the Top.
There are three ways to get to a page.
One is to use the Down Arrow, and go page by page to the one you want.
Two is to go to the Bookmarks menu to the left, sort through the main headings, until you get the subheading you want. Then click right on the heading name.
Three;
If you know the page number you want simply do this;
1) Put your mouse cursor in the Adobe Reader page number box.
Left-click once.
2) Type the page number you want.
3) Press the Enter key.
Moving on
Go to Page 111 - Replacing the power button board
Underneath the subheading, -> To replace the power button board:
.you will see the assemblies you need to remove, and in Blue.
Using number 2 - "Replacing the LCD panel assembly", for an example, just click RIGHT on it.
This will take you to this step of the procedure.
Then put 111 in the page number box at the Top, and press the Enter key; to go back to the main page - Removing the power button board.
Next step in procedure? Click on it. When finished go back to Page 111.
Preparing the Notebook: Goes from Page 53 to 54.
(Removing the Battery is really part of it. AC adapter [ Charger ] too.
Also Anti-Static Precaution information)
Replacing the LCD panel assembly; steps 2 through 15:
Goes from Page 70 to 73.
Replacing the LCD: Goes from Page 106 to 108.
Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
The areas you're going into are not that Static shock sensitive.
If you remove the Palm Rest Cover, or Bay Cover on bottom; then you would be. (In a Static sensitive area)
For this reason you do not need to wear an ESD wrist strap, and have it's alligator clip attached to a good ground source.
HOWEVER, be aware that your body carries Static electricity, and Static will fry out (Short Circuit), the delicate hardware components inside your computer.
Wearing an ESD wrist strap, connected to a good ground source; would alleviate any worries about possibly Static shocking your laptop.
Cost averages around $3 to $6, and the peace of mind is priceless.
Going back through the sections you will be in, and adding tips;
Replacing the LCD Panel Assembly:
1) IF you have a Wireless Card (Wireless Module) you WILL be removing the Bay Cover on the bottom. You have to remove the Wireless Antenna wires from the Wireless Module (Wireless Card)
(Page 58)
I <- would be wearing an ESD wrist strap.
If you are not, be sure you are working on a table; and not a bed, couch, or directly on a carpet floor. (High areas of Static)
If a carpet floor do not swing your feet across the carpet.
Handle the Wireless Card by the body, and refrain from touching the gold plated contact pins; when removing.
Note the color of the wires, and what terminals they connect to; on the Wireless Card. May be a two terminal/two wire, or
three terminal/three wire Wireless Card.
(802.11n wireless card has three terminals/three wires)
Make a note, and if needed a small drawing. Those wires MUST go back to the original terminals they were installed on.
Also note the Channels and Latches they go through.
The Wireless Antenna wires MUST go back through the same original route of Channels, and Latches; or the laptop will NOT go back together correctly, and there is chance of pinching a wire, and damaging it.
The Wireless Antenna wires are fed up through the bottom of the laptop, through a cavity. Out of their Channels, and Latches, then they lay on top until you remove the LCD Panel Assembly.
->To replace the LCD panel assembly, number 2;
and the separate sentence underneath;
"If there's no wireless card installed, proceed to Step 5"
Either they are on Crack, or I am.
You HAVE to remove the Keyboard to access the Webcam, and Microphone Cable's motherboard connections!
Look at Page 71.
The Microphone and Webcam cables, also go up into the LCD Panel Assembly you are going to remove!
They go WITH the LCD Panel Assembly when it is removed.
Sheesh!
Go to Page 64 - Replacing the Keyboard Cover. Must be removed before Keyboard can be removed.
Battery removed, you can see the 3 Philips head screws you need to remove; in order to remove the Keyboard Cover.
DO NOT use a butter knife, flat tipped Jeweler's screwdriver, or other metal tool to remove the Keyboard Cover!
A) One slip, and you'll cause more damage than you can believe.
Kiss the speaker goodbye, and the tiny wires underneath that cover.
B) You'll deface the plastic of the laptop, and it will look like this was done by a noob, instead of a professional.
(Yes. I can find the marks done by 'Pros', if they use a metal instrument. Hence why the marks on Pros above. They AIN'T)
Use a thick guitar pick to ease in-between the parting line of the Keyboard Cover, and Base Enclosure. (Bottom Cover)
Then use your fingertips to ease that cover up, and off.
I suggest starting on the Right side. Get the right side popped up a little, then use your fingertips of both hands on the top, and bottom edge of the Keyboard Cover.
Keep popping loose, and move towards the Left side.
BE aware that there are tiny wires going to that cover!
Do NOT lift too far up, or get aggressive with the cover; when removing.
Disconnect the wires, lay the cover aside.
Keyboard:
The Keyboard doesn't actually have to be removed all the way.
After removing it from the Palm Rest Cover, and Keyboard Cable STILL attached to the motherboard connector; the Keyboard is rolled over, and laid with the bottom -> Up.
Top edge of Keyboard (LCD screen side), is rolled towards you, and the top of the Keyboard is laid on the Palm Rest Cover.
The LCD screen side is lifted up at a slight ANGLE, then the Keyboard is slid a little towards the LCD screen.
There are Tabs on the side of the Keyboard facing you, and they go into the Palm Rest Cover.
Lifting the Keyboard straight up at a 90 degree angle, when first removing; will break the tabs off, and/or damage the Palm Rest Cover.
If you would rather just remove the Keyboard and get it out of your way:
Be aware of the following;
The Keyboard Cable STAYS attached to the Keyboard. It removes from the motherboard connector.
The Keyboard Cable is a FFC. Flat Flex Cable,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
As you can see it has flat terminal contact pins, and NO plug connector.
Twisted, flopped over, or going to Hawaii for vacation, (What?); the cable MUST be reinstalled in the ORIGINAL position it was in.
For this reason, you may wish to make a mark on one side of the cable, and a matching mark on the same side of the motherboard connector. (Sharpee?)
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is rectangular in shape, and composed of two pieces.
A smaller top part, and a larger bottom part.
HOWEVER it DOES NOT come completely apart, when unlocking.
(Opening)
The bottom larger rectangular part is the BODY. It is stationary to the motherboard.
The top smaller rectangular part is the Locking Bar. It is movable.
(The Locking Bar wedges the cable into the Body, when locked)
IF, the Locking Bar is broken, or the Body; you are looking at MOTHERBOARD REPLACEMENT, and why I have been so detailed.
Service Manual photos are not clear enough for me to determine, what style of Locking Bar is used.
There are two types of motherboard ZIF connector, this could be;
Sliding Locking Bar, or Flip Up locking bar.
So I will detail info for both.
(Also can apply to other ZIF connectors on motherboard )
Sliding type;
Closed, (Locked),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-10.jpg
Open, or Unlocked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-11.jpg
Use your thumbnails to EASE those tabs, of the Locking Bar.
Ease up on one side a little, then the other side. Then all the way up with both tabs/sides.
How far is the limit? Usually 2mm. That is a little larger than 1/16th of an Inch.
Use a metal tool? NO. One slip.............remember?
Flip-Up style;
Closed, Locked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
Open, Unlocked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
More in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 21, 2013
  • 3 more comments
  • joecoolvette
    joecoolvette Jan 21, 2013
    Remove the two screws at the Top corners, and Bottom corners. Remove the LCD hinge cover screws. I suggest cutting a piece of thick construction paper, or similar; to fit just inside the inside edges of the LCD front panel, and cover the LCD screen. Protect from the LCD screen from accidents, and your fingernails; as you remove the LCD front panel. The LCD front panel is flexible. Composed of space-age plastic, and pretty tough stuff. It has TABS going around the inside perimeter, that snap into matching Latches on the Display Cover. (Gateway? LCD Assembly Lid = Display Cover) Suggest come to the inside edge, at the middle/right of the LCD front panel. Using your fingertips lift up on the inside edge. (Your fingernails are now resting on the LCD screen. Hence the protective cover of construction paper) Now use a fingertip of the other hand, and moving over a little, lift up the inside edge of the LCD front cover. Once you have enough of an area lifted up, you should hear a Tab/Latch release. Snap. Move towards the Bottom/Right, then along the Bottom. Go towards the Left side, and up. Most of the time when the LCD front panel is 3/4th removed, the entire LCD front panel pops off. (I HAVE had them fight me all the way, until every Tab/Latch was released) (The Webcam wires, and Microphone wires are on Top. Hence why I think you should head towards the Bottom, with the Top being last. S'up to you)
  • joecoolvette
    I wouldn't disconnect any cabling from the LCD screen. After removing attaching screws just lay the LCD screen assembly up a little, on the Display Cover; so you can access the Power Button Board Pictorial guides that have information, and show you procedures; 1)http://www.insidemylaptop.com/disassembl... 2)http://www.laptopinventory.com/LaptopInv... Sorry about the length of this solution. A lot of reading. For additional questions please post in a Comment. Regards, joecoolvette Break a hinge pin on the Body? Replace the motherboard. A) Webcam, Microphone, LCD Cable, AND Power Button Board cables removed from their Channels, and Latches; B) BOTTOM (base) screws removed from Hinge Covers; C) Carefully lay the LCD Panel Assembly all the way back, and Webcam, Microphone, LCD Cable,
  • joecoolvette
    ND Power Button Board wires moved away from the Top hinge screws; remove the Top Hinge Screws. When removing steady the LCD Panel Assembly with one hand. Once the last screw is out it will fall if you don't. Replacing the LCD front panel - Page 101 This is what I referred to as the LCD Bezel. (Also known as Display Bezel, Display Mask, etc) The thin plastic frame in front of the LCD screen. The 'rubber inserts' are Screw Covers. Usually synthetic rubber, or plastic. THIS, requires a metal tool. I use a computer pick. The bottom edge is pried up on, and the screw cover removed. They are usually held on by a type of rubber cement. IF careful you may be able to reuse them, without adding a fresh, tiny dab of rubber cement. I LIGHTLY stick them to the LCD front panel, for safekeeping. (Yes. They like to stick to the removal tool, your fingers, and it seems passing satellites. Sticky little critters!)
  • joecoolvette
    EDIT: AND Power Button Board wires moved away from the Top hinge screws:
  • joecoolvette
    Messed that up! The second paragraph is the LAST paragraph. Plus after my signature those sentences connect to the last paragraph above. (Which is number 2 paragraph) Ran out of room in the Solution box, used OpenOffice, (Like MS Office), and this is what happened.
Gateway nv52 laptop cays corrupt registry stuck in recover mode
start computer and lunch startup repeir. you see windows is loding files and you see blue screen read and click next computer will start now
May 31, 2013 | Gateway Computers & Internet
Gateway NV52 won't wake up.
Is it clean? fan and vents? Unplug, remove battery, leave battery out, plug in, reboot. If that fails, Re Boot and try a System restore/recovery to a date before this issue. OR, Boot to Safe Mode, use this procedure to select Normal Boot: http://www.netsquirrel.com/msconfig/msconfig_win7.html When/If you get a Normal Boot, Open Control Panel, Power Options, select High Performance, select Change Plan settings, set plugged in both to Never, set advanced setting to your preference. Use this procedure: http://windows.about.com/od/customizingwindows/ss/set_power_options_all.htm Always shut down and unplug your laptop when not in use, remove battery when you use on AC, your Laptop/components will last longer, and will not be subject to possible power surge damage and the battery, IF it malfunctions will not cause a fire hazard.
Mar 01, 2013 | Gateway NV5214u Notebook
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
Nv52 has the power light come on but no display or hdd light
cmos battery being charged. You can keep the laptop on to fully charge it or replace it with a new cmos battery.
Mar 15, 2012 | Gateway Computers & Internet
How to retrieve files from a hardrive on laptop that will not work
One way to do it would be first remove the hard drive:
http://support.gateway.com/s/notebook/2009/gateway/nv/nv52/NV52faq4.shtml
Then use a hard drive dock such as this one (http://www.newegg.com/Product/Product.aspx?Item=N82E16817153071) to connect via USB to a working computer where you'll be able to access your files.
Jan 13, 2012 | Computers & Internet
All of a sudden, my gateway laptop nv52 screen dims on AC and brightens on battery power. It must be a key combination because I suspect my cat walked across the keyboard.
Try this,press function(Fn) and the power up button/down button. that will fine tune the middle setting your laptop. the middle setting is one of 3 settings, you need to press function and f8 to switch between lowest, middle, and high. the middle setting can be any setting you like and will be the default setting when you use your computer with a chord or without it.
Thank You
Jan 04, 2011 | Gateway Computers & Internet
Gateway nv52 won't turn on
I also had this problem. I turned it off and it would not turn on. I found the solution. First, extend the laptop screen as far back as it will go. Don't just stop the screen at a ninety degree angle. My laptop screen pulls back to about 135 degrees. Now press the power button. It should start up.
Why do I think this works? Well...I used to own an older model thinkpad that had a short "male" connector on the screen, that when the screen was folded down would enter into a "female" connector on the base of the unit and trigger sleep mode on the unit. This is how the system could automatically hibernate when the screen was closed. The little male connector broke off, and I couldn't get the system to wake up, because the connection to tell the laptop that I had the screen up or down no longer worked. I couldn't even power it up. I had to take an ink pen and push the connector through the female end to indicate to the motherboard that I'd opened the screen before it would even turn on.
It appears that the same type of mechanism is built into the long BAR under the screen of the NV52 and somehow it can't determine when the screen is open or closed. If it detects that the screen has not been opened, it won't power up. This safeguard prevents the laptop from being turned on mistakenly while closed up in your laptop bag. Extending the screen back resets the mechanism and it should turn on. Sorry for the long explanation...
Jan 15, 2010 | Gateway NV5215u Notebook
My brand new Gateway NV52 laptop with Win 7 OS won't power up
Yes, i think the best solution would be to tech it but because it sounds like a technical problem.
Take it back and they will work on it.
Jan 04, 2010 | Gateway Computers & Internet
Nv52 sound card drivers for XP does not work
This problem is listed under MT3705 notebook, which doesnt use NV52 drivers but sigmatel
http://support.gateway.com/support/drivers/search.asp?st=pn&param=1014142R
If all else fails remove the drivers restart PC and get windows update to try and solve it.
Aug 02, 2009 | Gateway MT3705 Notebook
Gateway NV5215u Notebook Logo
106 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
