Question about Pool & Spa
Want to bypass flow sensor - Pool & Spa
  • 4,340 Answers
You don't want to do that. The flow sensor controls the heater and chemicals. If the water flow stops, but the heater keeps going it can burn out, or melt the exchanger chamber.
Posted on Jan 20, 2013
Can I bypass the shut off sensor on my 1996 jeep
Did you mean fuel cutoff sensor? If you did then bypassing it can be dangerous as it is there to shut off fuel flow in case of a collision
so nobody burns up. A new one cannot be too expensive and you could get one from a wrecking yard if new is to high.
Oct 11, 2014 | Cars & Trucks
How to bypass a flow sensor?
im not sure why you would want to bypass the flow sensor , do you understand what it's purpose is?
anyways the tech side of a flow sensor is a little paddle wheel thats semi metalic plastic (dark) this brushes by a magnetic switch that a computer "counts" the switch open/closes as the wheel turns , faster the flow faster the wheel turns faster the counter counts , to by pass this you have to trick the counter to count up by a different means say like a drill chuck "it's metal" holding it close enough for the magnetic switch to "SEE" while turning is the trick
Jul 25, 2014 | Intex Salt Water Saltwater System Chlorine...
Can you check the mass air flow sensor?
There is 2 kits from lc engineering that will help you bypass a mass air flow sensor. Here is the site. http://209.250.27.45/m1webgear/Produ...artRevisionID=------------------------------------------------------------------------
Car cable & OBD Connector
Dec 07, 2012 | 2003 Pontiac Montana
Gas Dryer Ignition Issues
did you try bypassing the cycling t-stat also?
Aug 25, 2012 | Samsung Dryers
Need to get the check engine light off , mass air sensor is signaling the light , how do i bypass or eliminate the signal ?
No dont bypass it,because you cant,Mass air flow is part of the engine management so do this simple method, do you have mass air flow cleaner,with the engine off key out take out the Mass air flow and clean. according to the product instruction then you would be okay in no time
Apr 23, 2011 | 2001 Oldsmobile Bravada
I receive Lo H20 message at an air energy heat pump. Probable problems?
This is pretty common for LOW FLOW through the heater. Most of the time, homeowners turn the bypass the water away from the heater and this reduces the amount of water flowing through the heater. Check the bypass to ensure that you have enough water flowing through the heater.
There is nothing else that will throw this code unless the flow sensor is bad altogether.
Once you have inspected your bypass, and the code reappears, you will need to have the heater inspected and possibly change out the flow sensor.
Dec 07, 2010 | Jandy Air Energy Heat Pump - 100,000 Btus
What is the air flow sensor ? how it work? can I bypass it?
mass airflow sensor, if you remove it the car wont run
Oct 23, 2010 | 1996 Ford Taurus
1991 toyota pickup dies when you release the gas pedal
There are couple of things I would check out that would cause this problem.
1. The Mass Air Flow Sensor. It measures how much air is going into the engine. Should be located on top of air filter box.
2. The air tube that goes from the Mass Air Flow Sensor to the throttle body. Check for leaks that would bypass air from going through the Mass Air Flow Sensor.
3. The Throttle Position Sensor. Located on the throttle body. This tells the computer what position the butterfly plate is on the throttle body. You control this plate with the gas pedal..
Oct 11, 2009 | 1991 Toyota Pickup
Mass Air Flow Sensor - 92 Buick Century
Remove it and clean with some carb cleaner and a Q tip. Be careful with it so you don't do any damage. 9 of 10 times this will get you running again! Since signal from there is variable low voltage, you cant really bypass it!
Feb 16, 2009 | 1995 Buick Regal
F20 error on vaillant eco28 combi boiler
F20 is a flow sensor error. Can be due to a defective sensor/ not correctly fitted, or you may have poor circulation, a big difference in flow and return temperatures, can sometimes make the boiler think it has a defective sensor, check good circulation through system, or if you have thermostatic radaiators valves on every single radiator, take 1 head off, as if you dont have a bypass fitted, it needs a radiator as a bypass circuit
Aug 30, 2008 | Heating & Cooling
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
