Question about Jl Audio E1200 Car Audio Amplifier
Where i find the high lever input conector? - Jl Audio E1200 Car Audio Amplifier
  • 356 Answers
It is a plug located to the left of the RCA inputs on the opposite end of the amp where the power and speaker outputs are. You will need a plug with pigtails (most likely available from JL Audio
Checkout this link for a picture.:
http://www.sonicelectronix.com/pictures_new.php?id=2789&picture_id=111453
Posted on Jan 20, 2013
Cable tv
if its not coax..it must be hdmi..if not you can use rgb connectors..or component..what is the tv input?..and what is the tv input?
Mar 25, 2014 | Televison & Video
Fuel lever sensor circuit high input
replace fuel level sensor on fuel pump in gas tank.
Aug 03, 2012 | 2001 Isuzu Rodeo
My samsung m8800 pixon mobile touchpad is not functioning and battery is worst what to do i have just bought two maonths ago at high price
clean the conector battery or clean the conector of charging by contact if not solved remove the little batery in the mother board and if not solved flash the phone
Jun 28, 2010 | Cell Phones
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
Hdmi to vizio tv not support!
hdmi conector in the tv is a connector really fragile. this is high technology soldering, meaning: the tiny connections around this small rectangle can unsolder from the printed board really easy specially when the consumer plug in and out really often the hdmi cable on it (or not often), the scenario gets worst when you have to change the main board (this board holds the hdmi conector) only because this failure. OPTIONS:
the component input is equal to the hdmi.
Apr 15, 2009 | Televison & Video
Hd channels not showing
Your tv has a input named COMPONENT to make work this input you need three RCA conectors (RED GREEN BLUE) plus two audio RCA Conectors red and white. If you have another set that can be plug in in this input and that set (dvd recorder, in ex.) has a digital tuner then you got it, But the Magic about the decoder box is that only cost 40.00 +- dllrs and send the signal to your antenna connector or RCA analog conector. Good luck!
Mar 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Installation
First you must determine if the mic's output from the receiver is low or high impedence. Tip: high imp. is usually a 1/4" jack , low imp. is a 3 pin XLR Conector. It also depends on your amplifier input jacks.But really you should connect the mic to a mixing console and then connect the console to the amp.But you could connect a high imp. mic via a 1/4" to 1/4",cable into the 1/4" jack on your guitar amp.
Mar 23, 2009 | Naxa Electronics NX984 Professional...
Wireing
I believe that this model Sony amp includes High Level inputs. Those allow you to connect the normal speaker wires coming out of the factory stereo to the amp. If for some reason it doesn't include the inputs you can buy a high level to low lever converter that will give you rca from the factory unit.
May 06, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Oct 17, 2006 | Polaroid FLM-2632 Television
Jl Audio E1200 Car Audio Amplifier Logo
53 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
