Question about GE Profile Wizard DPSE592EAWW Electric Dryer
When warm button hums but tub does not spin - GE Profile Wizard DPSE592EAWW Electric Dryer
    Top Expert:
  • GE Master
  • 9,472 Answers
With the door open, have someone hold thedoor switch in and spin the tub by hand while you press the start button and see if it will run. Post back the results.
Posted on Jan 20, 2013
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Twin tub washing machine
change the brushes on your motor
Jan 24, 2014 | Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Will not spin
The humming sound is most likely the pump running. Try this: Open the front panel by using a putty knife to push in the clips (2) at the seam where the front panel meets the washers top. With the washer in the spin cycle (you hear just the humming) pull the little hose off the left side of the outer tub, near the bottom. The washer will most likely begin to spin immedeately. If it does, this would indicate that the hose and the nipple it connects to need to be cleaned out. Gunk builds up there some times and then the air cannot escape back out, so the washer thinks it is still full of water, and thus will not spin. After cleaning those out, replace the hose with the tub empty of water. If the washer did not spin after pulling the hose, check the lid switch.
Mar 29, 2010 | GE WBSR3140DW Top Load Washer
Replaced motor,now won`t spin
Something is locked in the transmission--can you turn the inner tub manually? Also, try to turn the driven pulley (the motor and belt driven). The problem could be anything from a seized bearing to a broken gear. Don't keep trying the motor while things are locked up, you could burn it out.
Aug 18, 2009 | Washing Machines
Whirlpool washer won't spin
Drainage is easy, Either lay the hose down low to the ground, or if your hose is a high mount model use a shop vac to begin suction and let it run out of any nearby outside door.If you have a wet/dry shopvac you can also draw a little out at a time as your vac permits and drain into a toilet. Your problem seems to be a coupling and not a belt. Use JSrocks guide for removal and replacement (http://www.fixya.com/support/r3574231-replacing_a_motor_coupling)
Mar 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine will not go thru it's spin cycle.
I just replaced the 4 rubber straps on the tub. Washed a load and it worked fine. Washed a second load and it did not spin on the rinse cycle. Checked the wiring on the switches. All OK. What do I check next. Did I mess up something around the tub ?
Nov 13, 2008 | Washing Machines
GE Profile Wizard DPSE592EAWW Electric Dryer Logo
215 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
