Question about Skilsaw 5380 Circular Saws
Skilsaw 5380 blade installation problem.
I just got this for Christmas and am trying to put the blade on, but can not get the bolt out. I have found a lot of information on how to change a blade, but none of it applies to putting the first one on. I have read through the instructions but they are no help either. Any advice would be welcome. Thanks
Don't know exactly, but on amazon you can find user manual. here Skil Circular Saw Model 5350 Owner Manual Operating Guide Paperback 1988 . Hope this was helpful. cheers Skilsaw 5380  blade installation problem. - skilsaw-5380-blade-installation-problem-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Posted on Nov 25, 2014
    Champion:
  • 304 Answers
In theory. All you have to do is push the lock bar, undo the blade clamping screw, remove the outer flange and fit the blade onto the back flange (make sure the bore size is correct for the flange. Sometimes you have to use a reducing ring) refit the outer flange and refit the blade locking screw.
Posted on Jan 29, 2013
4 Suggested Answers
SOURCE: Where is the blade lock button on a skilsaw 5150 2
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Posted on Nov 12, 2010
  • 15 Answers
SOURCE: How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Posted on Jun 08, 2010
hondo73162
  • 132 Answers
SOURCE: Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Posted on Nov 09, 2009
How to change blade on skilsaw 5380
on a circular saw
pull the power lead from the plug
using a screw driver , place the blade between the teeth and turn until the screw driver is jammed under the plate
use a ring spanner and undo the nut that holds the blade on
pull the blade out and fit the new blade with the direction arrow in the right direction
replace the plate and the bolt do the bolt up tight
rotation will tighten it up
some blades have a hole in the blade in which to insert the screw driver to hold the blade , or a lock lever behind the cover to hold the armature shaft while changing the blade
Dec 21, 2016 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
Table saw motor burning
Sorry, but my advice is to throw it away. With the 5380 anything more than a cord is not worth repairing.
My recommendation is to buy a Makita 5007 series and stay away from Skil.
Jul 12, 2014 | Skilsaw 5380 Circular Saws
Center bolt spins freely
There was probably a hole in the flange that you discarded that was used to put a pin/ nail/ bolt/ etc in from the body of the saw to hold that flange from turning while you did the nut up. Unless that hole is there you will have no way of holding the shaft to tighten the nut.
Jul 27, 2013 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skilsaw 5380 Roller Pin Removal
To remove a rolled pin you need to use a punch tool like a small chisel with a constant diameter and a flat tip. They sell these in chisel sets at Sears and other places. Or you might be able to use a bolt of the right diameter and tap it with a hammer. Don't use a nail though, too soft, it will just jam in there. Good luck.
Aug 28, 2012 | Skilsaw 5380 Circular Saws
How do you tighten the blade bolt on skilsaw model 5150? Thw shaft just turns and won't tighten.
There is a button on side that lock blade . Push on button turn blade by hand till you feel button engage now you can tighten bolt left hand threads
Jan 26, 2011 | Garden
How do I replace a skilsaw blade?
The saw has a bolt in the center of the blade. The saw blade will have to be held in place, (so it can't turn), while the bolt is being loosened. Pay attention to the rotation direction, as your replacement will need to rotate in the same direction. Once you have removed the bolt, there is a centering spacer that fits between the bolt and the blade, remove it paying attention to how it fits..you will need to put it on the new blade in the same manner. You can now remove your blade and replace. Good Luck. I hope this is very helpful!
Nov 14, 2009 | Craftsman Saws
How to I change the blade on a skilsaw cicular saw?
The blade is USUALLY held by a LEFT HAND thread bolt. Sometimes they have a diamond insert in the blade that must be removed if the saw has a matching boss on the arbor. If the saw has that, you punch the insert from the blade and engage the diamond over the boss on the saw then put the clamp washer on top and then install the bolt.
OFTEN there is a button near the blade are to push in to "freeze" the arbor so the bolt can be removed/installed. These are USUALLY left hand threaded bolts.
Sep 14, 2009 | Bosch Saws
Where is blade lock for my Skilsaw 5150 located
look for the button on the right side of the handle. Other models require you to put a phillips head screwdriver into a hole in the blade to hold it against the body of the saw.
Jul 13, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
How do I change the blade?
use a hard board to hold blade tight
rem: unplug power cord... thats how i've had to do it
at times
May 08, 2009 | Saws
Skilsaw 5380 Circular Saws Logo
1,975 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
