Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold Dishwasher Model GU2400XTP
I started a cycle on my dishwasher and went to work outside and when I came in my dishwasher had stopped. There were no lights on and all the water had not drained out of it. The dishes were clean however. I could still feel heat I guess from the water. Now it acts like it has no power, and I have checked the breaker, whenever you press a button nothing happens and I can't get it to finish draining. Please help.
  • Amy Goode Jul 18, 2007
    Thanks jsrock516, I found the fuse but can you tell me how to get the darn thing off. It's in a awkward place that is hard to get ahold of. For some reason I do not have a tech sheet inside the kick panel.
    Thank you
    momofthree
  • 5,911 Answers
There should be a thermal fuse located inside the console on the control board. Most dishwashers have them mounted this way. It's a white square plastic piece, or silver component with two wires connected to it. If the thermal fuse is bad it will give the same symptoms you are describing. To check, you need to turn off the circuit breaker to the dishwasher and remove the screws holding the console in place. This should be the four or five screws at the top of the door (with the door open). Carefully lift the console off the door (support the wires) and flip it over so you can see the control board. The thermal fuse should be mounted somewhere on the control board. The fuse will read a SHORT if good, an OPEN if bad. The fuse is not resettable (meaning you can't reuse it) and must be replaced. If you need further assistance let me know. I hope this helps you. PS There should be a tech sheet located inside the lower kick panel under the door. This includes all the schematics and troubleshooting tips. You may use this as a reference too.
Posted on Jul 18, 2007
  • Jeff Rockwell
    Jeff Rockwell Jul 18, 2007
    Kinda hard to tell without seeing it, as all dishwashers aren't manufactured the same. However, most that I am familiar with are attached to the control board by a plastic tab. If you take a small flat blade screwdriver you can slide it under the tab that is clipped to the side of the control board and lift slightly. The thermal fuse should come off fairly easy. Let me know if this helps.
Whirlpool gold dishwasher is NOT getting any water on start cycle
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
We have the Whirlpool Gold quiet partner III dishwasher and lately have noticed residue on the dishes after the cleaning cycle is complete. Where is the trap to clean?
Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
Hope this helps! Ken
Jan 06, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher GU2400XTP stalls during cycle
Sounds as if you have a faulty timer. These should be covered under warranty. Check you documents for duration of warranty.
Nov 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Quiet partner acuwash
BEST YOU GET THE ASSISTANCE OF A WHIRLPOOL TECHNICIAN.
GOODLUCK.
MOHAMED
Jun 26, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
359 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
