Question about Mitsubishi WD-C657 TV Lamp with Housing
I have a wd c657, light engine 938p075a20 with a scratched lens. i also have a wd 57734 light engine 938p07540, with bad dlp chip. can i take the lens Assembly off the wd 57734 light engine and put it on the wd c657 light engine ? or can i take the dlp chip out of the c657 and put it in to the light engine of wd 57734 and then put that light engine in the wd c657 ? thank you for your help pete.
4 Suggested Answers
yambo
  • 230 Answers
SOURCE: Looking for a ballast part number and price Mitsubishi WD-C657
encompass.com or parstore.com is a good store parts.
Just provide model number tv.
Thank you
Posted on Aug 07, 2009
  • 8457 Answers
SOURCE: i have white spots and
This tv is it the DLP projection light engine block main board itself is the problems,not easily to go into the tv itself and replacing the IC chip itself.Must take out many mechanical parts to get u the Light engine block it self.U can replaced IC but somethime the IC chip it replaced,will not solved the problems,because the tv problems now the it is spreading and going on beyond the IC chip itself.If want to keep this tv very exspensive repair,i would reconmend hire a bound qualify tv tech replaced the whole Light projection block itself,but first call Mitsubishi for some kind of deal,they might help with the repair amount cost.
Posted on May 13, 2011
SD Tech
  • 14553 Answers
SOURCE: White spots on screen Need DMD
This is something of an urban myth....The "DMD chip" is actually the LCD display IC for the set; yes I have seen some listed on EBAY---still a myth----they are replaced (when a light engine is rebuilt in a space age lab or environment) under exacting conditions----if positioned a micron off in any direction picture will be tilted in some way---this is also not like changing spark plugs in a car, if you have a optical engine issue like spots etc, either get a rebuilt engine from Mitsubishi or buy a new set.
They usually require some parts for old engine (mounting brackets etc) be installed on new or rebuilt engine.
I did see the "chip" for another model listed on ebay today.(100.00 PLUS)
I understand the engine is expensive, I replaced a lot of them when the sets were in warranty---more Mitsubishi than any other brand with Samsung a distant second.
I am sure Mitsubishi does not offer the part for sale--they want to sell a tested rebuilt engine only.
I wish you luck but have little hope you will find a "part" other than the whole engine.
SD TECH
Posted on May 14, 2011
Dlp chip after replacing
you will need to pull the chip out & clean out the dust & other foreign particles that were allowed to fall in & lightly brush off the chip (with a very soft brush, again to remove dust & foreign particles.
Apr 28, 2015 | Mitsubishi Tv Dlp Lamp 915p061010 For...
How to clean blue lens in the optical engine
Hello, this set does not have a "blue lens". A Mitsubishi uses a different type of system than like the Sony dlp's that use a 3 lcd system. the Mitsubishi uses a video chip on the video processing board (the DM board) and a color wheel to produce the image and a lamp to light it up. The chip is most likely the issue a fairly costly repair. tks
Apr 07, 2014 | Mitsubishi WD-62531 Projection Television
How to clean mirror and optics mitsubishi 73 dlp
You have to remove the lower panel on the back of your tv, then remove the light engine. Unhook the wires attached to the DMD board. Remove the DMD board. Remove the heat cink from the DMD board. remove the optical lens but don't touch the lens. There is a video on shopjimmy.com that shows the entire procedure. Takes 2 hours. The optical lens can be cleaned with an eyeglass cloth, same for the DLP chip lens. no wet solutions on lenses. Remove dust from other internal parts with compressed air in a can. Your picture will be clean and clear. Wear latex gloves and make sure you are grounded to prevent static electricity.
Feb 23, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
White spots
Its a display chip in the Optical lens unit and yes it is soldered in and tricky to replace correctly--seen several people try this and have real problems---light engine needs to be replaced to really correct this.
Dec 01, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I need the shematics to install A DMD chip in my Mitsubishi Model WD-C657
When you take off the back cover you are pretty much looking at the chip. Right in front of you in the middle of the light engine is a little fan.
Remove the fan and you will see a big metal heat sink / shield. remove the sheild and you will see a circuit board. in the middle of the board is the dmd chip.
Aug 19, 2012 | Mitsubishi Televison & Video
White spots on screen Need DMD chip for Mitsubishi WD-C657 DLP
SD TECH
May 14, 2011 | Mitsubishi WD-C657 65" HDTV
I have white spots and black spots on right side of Mitsubishi WD-C657. I've done research online, and have heard its the dlp chip. Is that true, and if so, is it something that I can replace myself,...
May 13, 2011 | Mitsubishi WD-C657 65" HDTV
I have a Mitsubishi WD-C657 with white spots all over it, its just over 2 years old (25months). I called Mitsubishi and they do not have a authorized tech in my area. They need an estimate before they can...
I have the same tv with the same problem and have found it to be the dmd chip which controls the mirrors. Once the chip begins to go it just gets worse and eventually will have to be replaced. Unfortunately you can't just go out and buy one and replace it yourself. It is mounted on the light engine circuit board and I got an estimate on the light engine from an authorized service representative and the cost for the part alone is about $900.00. The white spots are when the mirrors get stuck in the on position and if they get stuck in the off position they display a black dot, which I also have some of them. In a month's time my tv has gone from no dots to over 100 now. I have been searching to see if there is anyone who repairs the light engines instead of buying a new one, as this would surely be cheaper and I found a company that does this, but they will not do business with consumers only repair services. They are Hong Video Technologies, so if anyone out there knows how to get these engines refurbished and what it would cost, we both would be very appreciative.
Thanks
Jul 08, 2010 | Mitsubishi WD-C657 65" HDTV
I have a Mitsubishi DLP WD-57734 and white spots just started appearing I have owned the TV for 2 years and only one person in family uses it and not video games have replaced the lamp on time
The projection engine have problems,it the cause.Two years tv shouldn't have this problems already.Call talk to mitsubishi,might get some help the cost of the repair.
Jul 03, 2010 | Mitsubishi WD-57734 57" HDTV
Thank you
Aug 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-C657 TV Lamp with Housing Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
