Question about Singer 4411 Sewing Machine
How do you remove the bobbin case on a singer 4411
My bobbin is not threading and think the case needs to be cleaned because I have tried everything else and it is not working....
  • Singer Master
  • 7,365 Answers
Here is a free manual is if the information is in the manual
http://www.singerco.com/uploads/download/1230_4411_heavy_duty_esf.pdf
Posted on Jan 21, 2013
    New Friend:
I need to remove the bobbin case and am having a tough time......4411 Singer.
Posted on Aug 27, 2013
  • is there a thread jam in the bobbin area? if so, try taking the needle plate off and see if you can access the thread jam from there.
  • 3 Answers
SOURCE: skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Posted on Feb 27, 2008
SOURCE: Bobbin won't p/u thread Singer 478
i have no idea how to thread this machine ?
Posted on Aug 16, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 69 Answers
SOURCE: bobbin case and threading singer 6423
This machine has a black plastic bobbin case. You drop the bobbin down into the case with the thread coming off in a clockwise direction. If you look close you will see a slot in the bobbin case where there is the metal pieces. The thread will slide into that and as you pull on it it will work its way through and come out on the other end of the metal. Lay the thread over top of the bobbin case and turn the handwheel to pick up the thread. (make sure you close the slide plate)
Posted on Feb 07, 2009
miket756
  • 2702 Answers
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
How to wind bobbin on model 4411
Do you mean the Singer 4411 Heavy Duty sewing machine? If so,
first place the spool on the spool pin with an appropriate sized spool holder, if you are starting the project. Snap the thread into the thread guide to the left of the of the spool pin. Wrap the thread clockwise around the bobbin winder tension discs (slightly to the left and forward of the thread guide). Bring thread towards the bobbin spindle. Thread the bobbin (put the thread through the hole in the bobbin). Place the bobbin on the spindle with the hole up. Move the bobbin spindle to the right. Hold onto the thread above the bobbin and step on the foot control pedal. When the bobbin finishes winding the thread, cut the thread at the top of the bobbin and the incoming thread from the spool. Move the bobbin spindle to the left and remove the bobbin. If you have already threaded the machine for sewing, you will need to remove it from the various guides and tension discs that are used in sewing. Then after winding the bobbin, re-thread the top thread.
The directions to wind the bobbin are in the manual on page 12 (page 19 of the PDF). You can find many Singer manuals at the Singer support page: https://www.singer.com/support . The 4411 support page is https://www.singer.com/search/support?lp=support&title=4411 . The current link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%204411%20Heavy%20Duty%20Sewing%20Machine.pdf .
I hope this helps.
Apr 30, 2018 | Sewing Machines
I use a BLR3.The upper thread wound around the bobbin,bunched up and jammed.I cleaned the bobbin case,put in new bobbin,now the upper thread is not picking up the bobbin thread.tension at 2.5.
Try a brand new needle in case the needle is bent. Might rethread everything from the beginning. If you've verified it is all threaded correctly and it's still not working, then it could mean the machine has been knocked out of time (needle & hook are out of sync). You can search for sewing machine timing or take it for service.
Feb 28, 2018 | Sewing Machines
Thread bunches up into a knotted mess on bottom. Bobbin doesn't sit flat inside the bobbin case but spins with a tilt, lower on the left and higher on the right. Bobbin touches plastic cover plate.
Usually, thread bunching under the fabric is an upper tension issue. Be sure to ALWAYS RAISE the presser foot when threading the upper thread.
With the bobbin case operating at a tilt, there is something mechanically wrong with the machine. It may be best to take it for service.
Aug 30, 2016 | Singer 4411 Heavy Duty Sewing Machine
The hand wheel does not move. removed the needle, still not working
sounds like you have thread bunched up in the bobbin case. take out the entire bobbin plus the bobbin holder and clean it. it is worth a try....
May 20, 2016 | Singer 4411 Heavy Duty Sewing Machine
Tried to sew, the threads got mixed up and the needle stopped working. removed the needle, still does not work even when I move the hand wheel.
You could have a bunch of threads wrapped in the bobbin area. Check and see if you can clean them out. Otherwise, service may be your other option.
Having trouble picking up the thread from the bobbin
Try a brand new needle. Verify that the machine is threaded properly--both upper and bobbin threads.
If it is still not picking up the bobbin thread, it is likely there is a needle/hook timing issue requiring service.
May 17, 2016 | Singer 4411 Heavy Duty Sewing Machine
The needle has got stuck and does not come out when hand wheel knob is turned counter clockwise
You probably have a Bird's Nest, as they call it, under the needle plate.
  • You need to release the needle from the machine
  • Pull your work up and about so you can access the screws
  • Remove the needle plate
  • Carefully cut the tangle of threads around the needle with a small scissors or scalpel
Make certain you have turned the machine off first!
I had this issue with all sorts of sewing machines when I was a Workshop Technician at High School. Students were often in tears when they were sewing something special for an exam!
Mar 16, 2015 | Singer 2250 Tradition
I have a "Brother CE5500PRW" machine. I have
1 - Make 100% sure you are threading the top thread correctly.
2 - Make sure your top tension is set at 5.
3 - Look in your book and make sure you have the black plastic bobbin case inserted 100% correctly.
4 - Remove the black plastic bobbin case and inspect it for burrs or needle damage, if so it needs to be replaced.
Oct 02, 2014 | Sewing Machines
How to oil a singer 4411 sewing machine
you oil it in the center of your bobbin case, also theres a small pad like thing just above your needle , there as well as inside your threading area where the spring is
Aug 13, 2014 | Singer 4411 Sewing Machine
Why won't it pick up bobbin thread
Try changing the needle--make sure the needle is inserted correctly
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 11, 2014 | Sewing Machines
Singer 4411 Sewing Machine Logo
515 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
