Question about Acer Iconia Tab A50010S16u Notebook
Whats the solution for BMR compressed? - Acer Iconia Tab A50010S16u Notebook
  • Acer Master
  • 27,725 Answers
The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Posted on Jan 20, 2013
Is my radio suppose to be connected to my blower motor resistor?When the bmr was replaced,the radio came back on.94 Cadillac Fleetwood
the correct radio wiring layout
1994 Cadillac Fleetwood Stereo Wiring
before doing anything make sure you have traced all the wires and colors and are sure your facts are right
radio operation not part of that modules function
bmr repaced . ok thats great and it works
if in any doubts ring them back and ask the questions
.take it back to the workshop for clarification
Oct 13, 2016 | Cadillac Cars & Trucks
Why is my Makita bmr102 not working off 18v battery
There could be a number of reasons for this.
The battery is flat. Charge battery and try again.
The Makita BMR102 is not turned on. Turn on.
The terminals on the battery or BMR 102 are damaged. Have you tried using another power source such as a plug pack or different type of battery.
There is an internal fault. Take to a service agent.
Aug 31, 2014 | Drills
My lenova laptop BMR is compressed, what's the solution for it?
b>
Jan 20, 2013 | Lenovo 3000 G530 Notebook
Hi I have a Makita BMR 100, the clock display is working but everything else is not. The original battery is a 18 v ni cad, also tried a 14.4 lithium iron but still no luck. am about to have a look...
Check the black DC connection on the small supply board. Bypass it. Put external 12V DC on the supply board (white and blue wire, I thought).
Sep 07, 2011 | Makita BMR100 Radio
It is not showing me my BMI or BMR! How do you get that to show?
BMI + BMR do not show up when the scale is set in child mode. It's possible you have it set on child, instead of male/female. I have the manual uploaded on photobucket if you needed it.
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
Dec 29, 2010 | Taylor 5568 Fat Scale Stainless Steel ()
Which adjustment is used to riase and lower the on BMR R1200RT 2009?
What are you trying to raise/lower?? Need more concise information about your problem before I can help you.
Aug 08, 2010 | BMW R 1200 RT Motorcycles
2002 chevy cavalier ac fan does not work on high,only on bi level
Most probable cause is a bad BLOWER MOTOR RESISTOR (BMR). This part is located underneath the right side of the dash mounted into the blower motor housing. The BMR has a circuit board that is suseptible to corrosion and moisture damage because it is in an enclosed area with much condensation. After replacing it a couple of times, the 3rd time I dipped the circuit board in TOOL DIP - the stuff you rubber coat screw drivers with - have not had a problem since (3 years).
Chris Musanté
Jul 30, 2008 | 1988 Chevrolet Cavalier Z24
Netbackup Admin
you can go to hp help .com
Sep 11, 2007 | Computers & Internet
Acer Iconia Tab A50010S16u Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
