Question about Black & Decker BDL170 Bullseye Auto Leveling Laser With Anglepro
Auto Leveler Could you tell me how to use the auto-leveler feature.
Need instructions for BDL 170
Posted on Apr 22, 2010
How to disable the auto leveler on a 1990 Cadillac deville?
You can pull the fuse for the compressor or slide under the car and disconnect the wire harness to the air pump.
Jan 27, 2016 | 1990 Cadillac Deville
Pool overfilled, I thought because of rain. This wknd I backwash drained it to the proper level. 2 days later it was overfilled again...no rain. I don't know, but think I have an auto fill.
look for a smaller cover and open it up until you find something that looks like this one or even one that could look like a toilet fill... I've seen it. Thats the auto fill and they're relatively cheap, but to save you some money look for a little outlet (1-2" hole) in the pool right near the auto fill and plug it up with a rag. if water starts coming from the top of the fill area then it could be the filler or the fitting it connects to. Once you've determined if its the auto fill then shut the water off, most times it can be shut off with the landscaping but not always, you might need to shut off the water supply for a bit. then it just counter-clock screw out put in the new one and play with the levels you want it at. DONE!
http://www.amazon.com/Water-Leveler-Valve-Restrictor-Fountains/dp/B005SVW4UU
http://www.amazon.com/Korky-528-Quiet-Toilet-Valve/dp/B00002N6MY/ref=sr_1_2?ie=UTF8&qid=1448043014&sr=8-2&keywords=leveler+fill+valve
Nov 12, 2015 | Hayward Pool & Spa
Just bought a new 2013 thor hurricane and the auto leveling jacks wont go down. The motor is running, the parking brake on, but the auto leveler wont turn on but all the buttons to the left are flashing...
Is it a Lippert (LCI) system? If so, it sounds like the system needs to be calibrated. You can go to LCI1.com and they have a support section where you can find your leveling system with instructions to re-calibrate.
May 24, 2014 | RVs
The auto leveler in my 96 aurora continues to run even though there is no leak in my rear shocks. it will shut off for a few minutes then come back on. How can I get it to stay off after the car is level?
Your going to have to look at the level position sensor. It's on the driver side of the car, visible from the rear wheel well. The sensor may be damaged or broken. But is any case, its the device that tells the system the car is level.
Oct 26, 2013 | Oldsmobile Aurora Cars & Trucks
Which is the fuse for auto leveler?
You can look that up in the owners manual.
Jul 22, 2013 | 1995 Buick Riviera
What does the leveler light on dash mean?
Its part of the auto load leveling system. It pumps air to the rear shocks until you reach level condition. Usually only when you first start the vehicle.
Jan 23, 2013 | 1998 Mazda MPV
I have overloaded the washing machine and now it is off balance and i need to know how to fix it
Kenmore top loaders are equipped with an auto-leveling system on the back two feet of the washer. Typically, what happens when the washer becomes off-balance it's a simple matter of the auto-leveler needing to be readjusted. This is a very simple process that requires no special tools. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The rear auto-leveler should be periodically checked from time to time to ensure the washer maintains level. Any excessive vibration may cause the rear of the washer to become mal-adjusted. This is normal. Once the rear feet are properly leveled, make sure the front feet are adjusted so that the washer is level front-to-back and side-to-side. Use a level across the top of the washer cabinet (NOT the lid! The lid on most washers is slightly bowed.) to check.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Oct 06, 2010 | Kenmore 24032\24036 Top Load Washer
Where is the auto leveler located and should it run for more than 30 seconds?
if it keeps running, or runs a lot, your rear air shocks are leaking. monroe has them.
Sep 21, 2009 | Oldsmobile Aurora Cars & Trucks
1995 olds.aurora
This part is called the auto leveler or air ride compressor. If it has air ride then it is the compressor, If it is constantly running it is possibly the leveler switch that is mounted on the lower control arm that detects the ride height and tells the compressor to kick on.
Sep 21, 2009 | 1995 Oldsmobile Aurora
Looking for the wire to disconnect auto leveler or 88 oldsmobile
it will be in the trunk under the area were your speakers in the back seat are you should be able to pull it down and there will be a body control module there don't unplug the big harness but there should be leads for each of your lever servos.
Sep 01, 2008 | 1988 Oldsmobile Delta 88
Black & Decker BDL170 Bullseye Auto Leveling Laser With Anglepro Logo
221 people viewed this question
Top Black & Decker Measuring Tools & Sensors Experts
Vuk B
Dennis
frankrome
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
