I am trying to connect a Cinego Projector to a laptop for a PowerPoint presentation. I don't know how to get the laptop to use the Cinego for image.
Describe the connections available to you on the projector.
Describe ALL the connectioms available to you.
VGA should have worked I would have though unless you have the incorrect reolution set.
Check Projector Manual/ for that
Check also your Laptop Manual for Keyboard commands
I seem to recall that there is a special key to press on the keyboard
usually marked in blue on they Key edge
but it can vary - check the manual.
Or go to the Laptop Technical Support site.
Thank you for thanking me
But what was it that solved the problem from the those I suggested
Sub out
Audio out
Audio in
Video in
VGA in
I used the VGA connection from the projector to the laptop. It is a Win XP Pro machine and not recognizing any new hardware attached.
Thanks.
Thank you! That is what I needed to do! It now works perfectly!
Have a great day!
The laptop keyboard commands to switch the output to the projector.
Thanks!
