SOURCE: Hotpoint bearing replacement
remove rear pulley and pull like crazy ..usually have to change rear shell bearing and seal are pressed in be sure to ck spindle on basket for scoring before reassembly if scored replace basket
SOURCE: Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
SOURCE: How to I remove the drum from a Hotpoint WM64
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Testimonial: "Your solution answered my question, but left me with another. How to remove the bearings from the drum. "
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
SOURCE: Replace drum bearings on hotpoint aquarius wf000g
You really don't want to know how but here it is. The bearing is located in the rear shell and is not removable the rear shell has to be replaced which means removing the tub assembly from the machine and completely disassembling. With 30 years of appliance repair the last one I did took about 3 hours.
