Question about Samsung Computers & Internet
Samsung series 3 350v5c disc c error
New listed laptop,over past few days keeps stating scanning and repairing c drive 41%completed.i have not been able to use laptop over 4 days.
  • Samsung Master
  • 27,725 Answers
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. also download the registry cleaned cc cleaner
http://download.cnet.com/ccleaner/
You can also run a free registry scan using utilities from http://re7.info
http://www.download3000.com/showarticles-182-0-date.html System Utilities. http://www.download3000.com/showarticles-178-0-date.html Optimisers and Diagnostics. http://advanced-systemcare.soft32.com/ One-Click Free System tool for PC tune-up and maintenance. Registry repair.
Hope this helps.
Posted on Jan 20, 2013
  • 324 Answers
SOURCE: CD drive casusing problems
Since the CD drive is not being recognized, here are my suggestions:
1-Reseat the CD drive. In other words, remove it from its docking bay and plug it back in.
2-If that doesn't work, reload the driver for the CD drive.
3-If that doesn't work, replace the drive.
4-If that doesn't do it, you probably need a new motherboard.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating.
Thanks you, and have a super day!
Ron-
Posted on Nov 12, 2007
tparsenault
  • 170 Answers
SOURCE: dvd/cds will not burn past 85%
Try burning at a slower speed and try +r if using - R or visa versa on the dvd disks. My better half burns all the disks here and this is what she reccomends.
Posted on Feb 05, 2009
  • 94 Answers
SOURCE: Vostro laptop dvd/cd player not seen by system.
Try to get into the bios settings to make sure the device is enabled there.
Posted on Jul 31, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: My son has a Dell Inspiron 1525. When he switched
try to turn off your computer again, then power it ON, after pressing the button to power it ON, press the "F12" key and choose the drive for your cd rom and press ok, you should put your cd on the cd rom drive, when a message came up "boot on CD" press enter, let it run then, It will ask you, Install or Repair. CHoose repair, then just follow instruction until it finished
Posted on Nov 05, 2009
  • 309 Answers
SOURCE: Faced with following message/s:
Without an original OS installation disk, you are probably at an impasse as far as trying to repair the problem yourself. You might try this option to see if you might be able to get into the computer.
Try this first:
You can try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message "Please select the operating system to start" or hear the single beep, immediately press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
Failing this, you will probably have to send / take the computer to a repair facility to get the machine back online. I fix this kind of issue on a regular basis.
Posted on Jan 23, 2010
Why does my new HP Win 7 Pro notebook crash on sleep and hibernate?
You may have a registry error.
Advanced Computer User Solution (manual restore):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Error 41) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Jan 23, 2014 | HP 650 Notebook PC
My samsung Q45 notebook tells me to insert the windows installation disc and restart my computer. I have not got this, can anyone help?
First disconnect any external devices connected to the computer except the mouse and keyboard.
This error usually happens if the hard drive is not getting detected by the operating system or due to bad hard drive.
First check if all the physical connections to the computer are set correctly.
If it is a laptop remove the laptop battery, wait for 5 minutes and then connect back the battery, check if it works.
If the above step does not work then you will need to run CHKDSK tool to check if there are any bad sectors on the hard drive would suggest running chkdsk which would scan for any bad sectors on the hard drive and if those errors are repairable if would repair and if it cannot at the end of the chkdsk scan you would see a message "found one or more unrecoverable error on the hard drive" which means the hard drive is damaged.
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
1. Insert the installation disc.
2. Restart your computer.
Click the Start button, click the arrow next to the Lock button , and then click Restart.
3. If prompted, press any key to start Windows from the installation disc.
Note: If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computer's BIOS settings. For more information, see BIOS: frequently asked questions.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click command prompt and in the command prompt typechkdsk /f and wait till the scan is completed and later restart the computer and check what happens.
http://windows.microsoft.com/en-US/windows-vista/Make-system-repairs-from-the-Windows-Recovery-Environment-from-Windows-Vista-Inside-Out
Important: While performing chkdsk on the hard drive if any bad sectors are found on the hard drive when chkdsk tries to repair that sector if any data available on that might be lost.
Hope this helps!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 09, 2012 | Samsung Q45 Notebook
Hi guys, I have an acer aspire 9300 series, i did noy get a recovery disk with it because its supose to be on the hard drive.the problem is that when i try to restore to factory default it keeps booting to...
if you want to recover your laptop to factory setting, juat press Alt+F10 at acer logo displayed
you will directed to acer recovery management, from there you can recover your laptop
Mar 12, 2011 | Acer Aspire 9300-3642 Notebook
Today I tried restore my computer to a previous state using HP recovery manager. After the restoring process ended a sign appeared saying that the restoring couldn't take place due to some 0xc000022 error....
before restoring the computer run a through scan on the harddisk all the drives in the hard disk should be throughly scanned the error you reciving is due to the hard disk problem first scan the hard disk in windows then restart your computer press f8 and click safemode command mode you will see files running wit for few minutes till the comand prompt comes in the camand prompt type chkdsk /all after the scaning is type exit then restart the computer and try restoreing
Jan 29, 2011 | HEWLETT-PACKARD HP Pavilion DV7-4190US
Please Help! My Samsung R610 Computer says Windows is Activated but it is not working. Microsoft have validated my product key number but clearly this is not working. Can you please help me?
Try booting with the windows disc, let the windows files load and when it is finished it will give a few options. Choose repair, then choose the listed windows installation...it will be the only one so highlight it and click next. Windows will scan itself for errors and repair if necessary, then it will reboot itself, when it does remove the disc, just dont hit any key when it flashes "hit any Key" on the screen the second time, the first time you want it to but that is the only time you do it. Windows should boot up and operate fine.
Nov 27, 2009 | Samsung R610-64G Laptop
My son has a Dell Inspiron 1525. When he switched it on a few days ago it came up with Windows Error Recovery , launch startup repair (recommended. I selected this and went through the instructions as...
Nov 05, 2009 | Dell Inspiron 1525 Laptop Jet Black
Recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
May 09, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Atapi dh20a4p problem
OK... see if this:
Toshiba Satellite Pro C50 Laptop Optical DVD Drive Bezel Assembly K000888950 will work for you?
See eBay: 272402441049
$20 NEW ~ Including shipping from Denver.
The ONE thing that does bother me about this Auction is the word "BEZEL"... is it just the BEZEL without the actual drive? Please MESSAGE the seller and ask!
Final note: Be VERY careful about DVD Drives that are listed as "NEW" (other) ... MOST times that decodes to USED!
Anthony
Toshiba Satellite Pro C50 Laptop Optical DVD Drive Bezel Assembly...
Nov 01, 2017 | Toshiba (K000816870) for Satellite 1100,...
Laptop
A blue screen is an operating system error. this can be caused by either a corrupt operating system or a failed hard drive. What you will need to do is run a system repair with your recovery or operating system disc. If the repair doesn't take then reformat the hard drive and install a fresh operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced.
Jul 26, 2008 | Dell Latitude D800 Notebook
Computers & Internet Logo
46 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
