Question about Fluidmaster Plumbing
Toilet wont flush - Fluidmaster Plumbing
    New Friend:
  • 11 Answers
What type of toilet? low level which sits on the pan?
Posted on Jan 22, 2013
Toilet wont flush
If it has a power flush (i.e hole about 1" in size opposite side of flushing direction) that hole gets plugged by minerals from the hard water, when it does the flush will be much weaker. To clean it, use a bent coat hanger and ream out the deposits as far in as you can reach. Then turn off the water supply, flush the toilet, then quickly pour one pail full of water into the toilet to drop the water level to minimum. Get "Lime Away" at H/Depot, pour in 1 cup and let sit overnight to eat the remaining hard water deposits from the bowl and power flush. In morning turn on water flush a few times, should wok good as new. Repeat anytime hole starts to get plugged.
Jul 27, 2014 | Home
Wont complete flush
Could be low water level in the reservoir, otherwise the flapper may be shutting to quickly to allow enough water to properly flush. You could try holding the flapper open or watch it's operation as you flush the toilet to see if it's allowing enough water to drain into the toilet. It's pretty easy to replace the flapper on most toilets and cheap as well.
Jul 25, 2014 | Home
Toilet wont flush
Main 3 (or 4) inch drain under the toilet is clogged. Requires removing the toilet and running a "snake" down the pipe. Alternately, you can (carefully) try manually filling the toilet bowl all the way to the top----to apply pressure to the clog....it may push it through.
Mar 04, 2014 | Home
Toilet wont flush
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
TOILET WONT FLUSH AWAY PROPERLY
I believe what your plumber was referring to are the flushing orifices. Yes they have changed through the years. Unless you have a pressure assisted toilet, the orifices are what makes it flush, by breaking the trap seal and creating a vacuum. Now that being said you can check to see if this is the problem by filling up a bucket with aprox. 2 gallons of water and dumping it straight into the bowl. It should flush right down with out hesitation. If it does then your orifices are not working properly. If this is a new stool, it is possible it is just a bad mold and should be replaced. I hope this helps. Your new toilet should flush for you.
May 08, 2010 | Home
Tilet want flush no pressure when depressing
Take off the top lid and look at the flush handle mechanism. You'll see a not that holds it onto the tank. Tighten the nut so it is snug. Don't overtighten it or you could crack the tank. Next inspect the chain that goes between the end of the flush handle rod and the flapper valve. It should lift the flapper all the the way up when you operate the handle.
Apr 11, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
Grinder wont turn and toilet not flushing
Disconnect the power and pull the pump out and examine the pump. Simple and easy!
May 23, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Plumbing Logo
Top Fluidmaster Plumbing Experts
Jim Goldsmith
Jim Goldsmith
Mack Baxter
Andrew Bugbee
Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
