Question about Maytag 21.8 cu. ft. Side-by-Side Refrigerator/Freezer
My maytag gz2626gekb zigzag ,is not freezing ,fan running for first few minuits when switched on , then cuts out , open the door and fan runs on conpressor then compressor cuts in shut the door all tu
Been fine last few wks ice cream soft in freezer , last nite had to empty freezer all going soft , fridge not cold , i have checked compressor fan runs ok compressor hot on top , i have cleaned condenser , took back of freezer off evaporator not freezing , then open fridge door and fan and then compressor cut in , leave to run with doors open evaporator freezing , shut doors all cuts off , any help please thanks
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Posted on Feb 04, 2010
  • 91 Answers
SOURCE: I have a Maytag 3
Either, the defrost timmer has had it, or the freezer defrost element has failed, the element is the most common cause of this type of problem. You have ice build-up in the freezer cores because it cant defrost, all frostfree units rely on cold air from the freezer to blow into the fridge, if the freezer cores become blocked, air can not pass to the fridge side. I bet you, if you left the unit off for 2 days to defrost totally,,,,with the doors open...then plugged it back in, it would work like new for 2 weeks.
Timmer or defrost element needs to be replaced...do not fall for the trick that the fridge mech. has to take it away, you tell him that this is the problem and you will save yourself ALOT of cash.
Dont forget to vote for the solution...regards Russ
Posted on Mar 08, 2011
Commercial fan on evaporator cuts off after starting
There is an overheat klixon on the evaporator that stops the fan running until the coil gets below -11c This can take some time after startup. if the freezer runs more than an hour before the fan starting, check the klixon isn't faulty, and you have power to the fan. Also check the condenser grille is nice and clean as it will slow down the freezing process.
Apr 17, 2014 | True Freezers
Fan does not come on nor does door light. Also will run to cold temp when it cycles off cabinet warms up very quickly
have you checked the door switch for each door? the lights should still work in defrost mode but not fans or compressor.
Jan 08, 2014 | True T23F Commercial Freezer
Ec 08
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Dec 03, 2012 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
Fan is not running in my True T49F Freezer
There is a switch above the door; check you have power from it when closed, then check the evaporator is cold enough as there is a thermistor that stops the fan until it is beginning to freeze. Lastly check the fan blade isn't stuck and the motor is ok.
Jul 02, 2012 | Freezers
It is running but is not freezing the food
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
Regards.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
My whirlpool chest freezer runs but does not freeze?
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Best regards.
Apr 07, 2011 | Whirlpool Freezers
Freezer not freezing properly. Keeps things frozen but new things put in do not freeze as they should.
Is the internal fan running? you should hear it after you close the door, or push the light switch on the door.
Apr 19, 2010 | Freezers
Evaporator fans do not come on, why would evaporator is not cool enough?
There are three main reasons the fans would not come on.
1: A bad door switch. There are switches on the top part of door frame. They turn fans off when door is opened to prevent warm air from being drawn into unit when door is open. If a switch goes bad the fans will never turn on.
2: Refrigeration problem. The fans are tied into a temperature switch called a fan delay. The fans will not come on until the coil is well below freezing. This is to prevent water spray after a defrost. If unit is low on gas or has any other cooling issue the fans will not come on.
3: Bad fan delay switch. If the fan delay switch becomes "stuck open" the fans will not be energized.
Feel the back of your evaporator coil, if it is very cold and frosted you probably have a bad fan switch, or a bad door switch. ;)
Oct 10, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Traulsen GLT232NUT double door freezer
Hi palmer
Happy to help you!!
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 24, 2008 | Traulsen 46 cu. ft. Commercial Freezer...
Open Questions:
Maytag 21.8 cu. ft. Side-by-Side Refrigerator/Freezer Logo
62 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
