Question about Acer Aspire E360 PC Desktop
Acer Aspire E360 is staying in power saving mode
Whenever I turn on my computer it's only saying Power Saving Mode where the login screen should be. Please Help! This have been going for a couple of days and I have tried everything that i could!
  • Acer Master
  • 27,725 Answers
Click on "Start" in the lower left-hand corner of the desktop. From within this menu, select "Control Panel." Double-click on "Power Options" located inside the Control Panel. Turn off the power saver plan by selecting one of the other power plans listed inside the Power Options dialog box. If there are no other power plans available, you can create one. Create an alternate power plan by clicking on the "Create a power plan" link on the left-hand side of the Power Options dialog box. This will open another window allowing you to create a power plan of your own. Select the type of power plan that you want, and enter a customized name for this plan. Once you have done this, click "Next." You will then be able to edit the plan's advanced settings to include how it handles the display, sleep mode and brightness settings under the battery and when it is plugged in. Hope this helps.
Posted on Jan 20, 2013
5 Suggested Answers
  • 10 Answers
SOURCE: problem
i think its your operating system that has a problem.. try reformating your computer.. hope it can help
Posted on Nov 07, 2007
  • 1019 Answers
SOURCE: My srceen goes Blank
first try booting the laptop and pressing the Fn key with the numerical ( numbered key ) that has a picture of 2 screens on it. This is for booting to an external monitor. you could also try adding an external ( pc monitor ) this will eliminate any motherboard Faults.
Secondly, the graphics chip driver may be corrupt or not installed correctly. if you have a restore cd, you could try booting the laptop, with the cd in the drive.
you can then try, to see if the settings in the bios are all correct, by booting/starting the laptop and pressing esc or F2 or delete immediately as the laptop starts. ** Be-Careful** what you adjust.
My suggestion is to look for. ** default settings tab** or load setup defaults.
these are the obvious things to try, before assuming that you have a faulty graphics chip or motherboard fault.
Mike @ compurepair.
Posted on Jun 12, 2009
  • 166 Answers
SOURCE: we have an acer aspire M1640. won't respond
unplug everything for a few hours and let it drain. then go into bios and turn off all power save settings.
Posted on Aug 23, 2009
vinzen
  • 217 Answers
SOURCE: computer screen comes on for a few seconds and
Try this ..Control Panel, Power Options, Look for how your PC is set up.There are choices you can change to correct this.Good Luck.
Posted on Sep 14, 2009
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
My computer screen says 'in power save mode' what
Is your computer switched on? Is it connected to the monitor? If the answer is "yes" to both of these, then just move the mouse or press a key on the keyboard. It should all work now. It was saving power because you weren't using it. If not contact me with more info and I will try to help.
Jan 12, 2012 | Dell Computers & Internet
Whenever i turn my pc on it says entering power save mode
Check the cables running from your computer to your monitor. This sounds like a problem with a cable connection. If you see your bios screen and then it says "Out of range" or something else, then you will need to go into safe mode and reconfigure your display resolution.
Jan 06, 2011 | Computers & Internet
Before Windows can boot-up the screen turns solid blue & a Dialog Box state "Entering Power Saving Mode". The screen then appears that the sleeping mode has occurred.
just switch off and switch on the monitor or press any button on keyboard to bring monitor from power saving mode thats all
Sep 23, 2010 | Dell E207WFP LCD Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Monitor goes into power saving mode. How do I
Go to desktop properties>screen saver option>power option & select the turn off monitor never.
Oct 15, 2009 | LG Flatron L1718S LCD Monitor
Analog power saving mode?...
I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
May 13, 2009 | LG 22" FLATRON LCD Monitor
External monitor says laptop is in power save mode and goes blank
hey jkep
this has nothing to do with power, here is what to do
right click your desktop->
properties->
click the settings tab->
click the advance button->
click the display tab->
depending on your graphic card there should be 2 or 3 different monitors being displayed switch them on and automatically your TV will turn on then you can change the settings to your likings
Feb 13, 2009 | Acer Aspire 5610 Notebook
Digital Power Saving Mode
Go to your monitor power settings and turn off Hibernation and other monitor power schemes.
If this problem persist, request for more technical assistance from the manufacturers website
Nov 30, 2008 | LG W2252TQ Monitor
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Acer Aspire E360 PC Desktop Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
