Question about Brother CS-6000
How to fix the needle on a brother cs-6000
I took my machcine apart and now the needle is out of line..it is now hitting the presser foot.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
Timing or Needle swing issue....look HERE
Posted on Apr 01, 2013
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
JeremySew
  • 65 Answers
SOURCE: need presser foot holder
Here are the parts you need:
Brother Sewing Machine Presser Feet & Shanks
Posted on Jan 05, 2009
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
SOURCE: Brother CS-6000 E1 error message - my presser foot is not up!
Did you take this machine apart? If so, then the lever that extends from the thread tension wheel is to the right of the raised presser foot switch plate (inside the sewing machine), keeping the switch from being unpressed.
Take the machine apart again, raise the presser foot, and put the machine back together. This will ensure proper alignment of the plates.
Posted on Aug 20, 2009
  • 980 Answers
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Posted on Nov 04, 2009
Needle hits the quilting presser foot
Needle may be slightly bent. Needle may not be properly or fully inserted into the needle clamp or holder. Needle may even have a burr on it or be too dull. Needles must be changed fairly often, especially with many of the modern synthetic fabrics. They do not last forever.
Change the needle first, for a new one, be sure it is properly inserted. Then, make sure you have not accidentally set your stitch width incorrectly. I've done that myself after using a zig zag stitch mode and forgetting to change it, or not change it all the way back to straight stitching.
Some machines will allow the needle to be set at centre, left of centre or right of centre, so be sure it's in the correct place for the stitch and foot you are using, or you will hit the foot.
Hope one of those turns out to be the right tip.
Oct 16, 2016 | Brother Sewing Machines
I am trying to find out how to put part of a sewing machine back together that was taken apart. It is a cs 6000! computer sewing machine Brother. The rod that goes up an downthat holds the needle has
There are three types of CS 6000 they are CS 6000B, CS 6000i and CS 6000T
You can download the service manual and parts manual from this site
http://www.nodevice.com/manual/Brother/page2.html
One file costs 4.95 Euro, or a 24 hour download (better value as you can get the parts manual too) costs 7.95 Euro to download
Oct 02, 2014 | Brother CS-6000 Computerized Sewing...
Service manual
https://www.manualslib.com/manual/451089/Brother-Cs-6000i.html
Apr 04, 2017 | Brother CS6000i Computerized Sewing...
Needle not lined up with hole in presser foot
Is it also hitting the needle plate? if so then you need to move the arm the adjustment is internal and you\'ll have to disassemble the clam shell case of the machine. May be best to have a pro fix it for you.
Jan 14, 2014 | Brother CS6000i Computerized Sewing...
What should I do when error message E1 hapend
An "E1" message appears on the panel. Description: The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
Mar 02, 2010 | Brother CS-6000
I have a problem with the needle shaft. It seems to be overextended by about 1/8" to the front of the machine. My needle is hitting the forward part of the presser foot.
Remove the foot - does the needle hit the needle plate?
Is the needle bent?
If the answer is no to both questions, it could be the machine needs to be taken in for repairs.
Feb 24, 2010 | Brother CS-6000
Jun 25, 2009 | Brother CS-6000
I took my maching apart to clean the lint out and when I put it back to together the needle is hitting the feed dogs. what could be causing this!
most likely the bobbin case is not aligned correctly .Insert the bobbin case so that the projection on the boobin case aligns with the spring.
Feb 23, 2009 | Brother CS-6000
I can't sew on my machine
crystal morg
try lowering the presser foot and then hitting the start button again hope this helps you out if not I will look into it for more
Jan 26, 2009 | Brother CS-6000
Brother CS 6000
With the foot pedal disconnected from the machine, push the button with the - and upward arrow. to stop sewing use the same button. It is the first button closest to the needle.
Jul 29, 2008 | Brother CS-6000
Brother CS-6000 Logo
70 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
