Question about Hunter Ceiling Fan Light Switch Control
Bought anew controller for my hunter fan, but when i hook it up to the wall the fan works but not the light. what did i do wrong
I used the cooper dual control fan and light
    Genius:
  • Hunter Master
  • 1,617 Answers
I would check to make sure your light wire coming out the top of the fan is connected to a hot wire.
Posted on Jan 23, 2013
5 Suggested Answers
  • 140 Answers
SOURCE: quit working
first turn it off, then rotate the fan, half turn and try to turn if on again. if it start running again you have a faulty motor, and need to replace it. or if the problem continue, try replacing the switch in the wall.
Posted on Nov 25, 2007
SOURCE: ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
SOURCE: Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Posted on Mar 11, 2010
I have 2 wall controls for my current fan. One is for the light on the fan and the other is for the fan itself. When I disconnected the old fan, there were 3 wires - black, white and red. What do I...
Both the Red and Black wire are your hot wires. One is probably for the fan side and the other the lights. The white is your neutral wire or common and is used by both. So the wires from each switch are HOT, hook one wire to the black and the other switch wire to the red.
Jun 05, 2011 | Hunter 52" Ceiling Fan With Light And...
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter fan model 21617 remote fan won't turn on light from wall switch
You mean only the light? and the fan is working? Have you checked the light bulb? If it's ok, then checked on the wall switch. If is also ok, then probably there's is something wrong with the wiring in the fan.. It's either a bad or loose connection
Jul 01, 2010 | Hunter Ceiling Fan Light Switch Control
Fan and light suddenly wont work.
May be the receiver Call Hampton Bay @ 18005533199 have your UPC number ready
Oct 27, 2009 | Hunter Dryers
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Remote Chewed Up
i had similar problem with remote , went to home depot to buy a new fan and saw they had new remotes and receivers for the hunter fans , i bought the kit ( which had a remote and a receiver for a non remote ceiling fans) and was working again . salesman was very helpful .thanks.
Dec 30, 2008 | Hunter 52" Ceiling Fan With Light And...
Fan with light (no remote) with wall switch not a 3-way
Unless you want to use pull chains, you will either have to get a different fan with a remote, or you can buy a remote to ADD to an existing fan/light. It hooks up under the base of the lamp. They seem to work better than the factory fans with the built in remotes.
Dec 04, 2008 | Hunter 52" Ceiling Fan With Light And...
Quit working
Nov 24, 2007 | Hunter 23852 Classic Original Ceiling Fan
Dryers Logo
250 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
