Question about HP LaserJet 1012 Printer
Printer won't print. I had to move the desk and everything was unplugged and now it won't print. It is on, checked as default, on-line, I think it may be the port.
What port should it be connected to?
  • 314 Answers
  1. Background
    • HP provides details of the problem on its website. The problem usually occur on PC laptops or when printing across a network. HP offers several fixes for the problem.
    Software
    • First, check your Windows print queue and ensure the printer is not set as "Paused" or "Working Offline." This can often clear the problem and resume your printing.
    Resolution
    • The problem can also be caused by printer driver issues. Try uninstalling and reinstalling the printer driver. Connecting your printer directly to your computer using a parallel cable may solve the problem, but this may not be practical in all cases as many modern laptop computers do not have a parallel port.
Instructions
    • 1 "Power Cycle" Your printer. Shut down the printer, unplug the power cord from the socket, give it 5 minutes, plug it in again and turn it back on. Try to print.
    • 2 If the printer still won't process a job, shut down and restart your computer.
    • 3 Check your printer cable connections to the computer.
    • 4 Check the printer for any paper jams, check the trays, and also pull out the toner cartridge and/or remove any paper jam, if you find one. Put the cartridge back in. Then try to print.
    • 5 If after completing the steps above, the printer is still not working, click "Start," then "Settings," click "Printers," and the printer folder will open. Make sure your HP LaserJet 5 is selected as the default printer.
    • 6 Double-click your printer, and delete everything from the print queue, canceling all the print jobs. Close out the queue.
    • 7 Right-click on your printer icon and make sure it's not offline. If it is, then click "use this printer online."
    • 8 Right-click your printer, and click properties. Make sure the right port is selected for your LaserJet 5 Printer. If you are using a parallel cable, you are most likely using an LPT port; if USB, then look for a USB connection in the list. If the port connection is correct, try to print again.
    • 9 It's still not printing? Click "Start," then "Control Panel." Double-click "Programs and Features" or "add or remove programs," uninstall your Laserjet printer software, and restart your computer.
    • 10 Insert your Laserjet software and driver disk. Proceed to reinstall your printer software and drivers. Then test the printer again. If it is still not working, you probably will have to seek professional assistance.
Posted on Jan 20, 2013
  • 24 Answers
SOURCE: HP Laserjet 2300 printing 5 copies
Friend,
There shouldn't be any need for a parallel-to-USB device, since your printer has both ports - and you could use ONE of the ports for printing. One, since two ports does NOT mean that the printer can serve two PCs simultaneously. On startup, it determines which port is active and "forgets" the other.
So I would have gone for either a parallel cable (IEEE 1284 standard, no longer than 10 feet) or a USB cable, running the cable directly from PC to printer.
If there's a need for several users to access this printer, I would either have shared it from my computer (where it's physically attached) to the other users in the network - or, purchased a jetDirect network card for the printer. With a JetDirect card the printer is accessible for all users over the network regardless of which computer is switched on.
Hope this clarifies and gives an answer to your question.
//Al
Posted on Mar 10, 2009
SOURCE: I installed a USB2 to Parallel adaptor to connect
You need to change the port settings of your printer from the printer properties,
Go to printer >Right Click and select Properties Go to Ports> and select USB001 port
and select apply and then ok, now restart your printer and give the print command it should print now,
If you require more assistance, feel free to reply to this post, Regards-BA
Posted on Jan 15, 2011
Isaac25
  • 40 Answers
SOURCE: My Printer (HP LaserJet 1020)
I suppose that this is a mere software controversy. Try to do a system reset of the printer.
I mean, follow the steps.... First disconnect the printer, then uninstall all the printer's associated utilities from your laptop. Then install the latest driver for you HP Printer. You can find it on the HP's official website.
Then reconnect the printer and try printing. This will surely. Also check the if it is working on any other usb ports.
Thank You.
Posted on Mar 06, 2011
decso
  • 20 Answers
SOURCE: blinking/flashing lights(orange & green) &
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
Posted on May 29, 2011
  • 199 Answers
SOURCE: My printer doesn't print word documents (it
try the following
1.power on your peinter
2.while press and hold the power button ,open and close the top cover times.
printer pick the paper and print the test page and alignment pattern for black and color.
if any of the black or color alignment pattern is not print ,then u have to change the cartridge accordingly.
Posted on Aug 01, 2011
Windows Live Mail won't print on Windows 7 64bit
Try to check if your printer is set to Default.
Go to Control Panel > Devices and Printers> Under Printers and Faxes, locate your Printer name then Right click> Set as default printer.
Then try to print again.
Hope this helps.
Regards,
Charvin
Oct 15, 2012 | Brother MFC-5840CN All-In-One InkJet...
Epson Stylus CX5800 on my desk chimes, but won't print
Check first the connectionmake sure everything are connected properly, Then check if your printer is still installed properly and do a test print...Also turn off the printer for 10 seconds..
Hope that helps........
Jul 31, 2008 | Office Equipment & Supplies
How do i get my hp1200 printer to print, is on a off line mode
Hi Joy,
Disconnect the printer completely from the PC.Unplug its power cable too.
Reboot your PC.
Connect everything again from scratch but use a different USB port to connect to the PC.Make sure everything is well connected.Try printing now.Cant print?
Under printers and faxes,check whether 'work offline' is checked by right clicking on the printers icon and 'Uncheck.Still cant print?
Uninstall the printer driver on your PC,reboot the PC and install software again.If you don't have the installation disks,install from this Hp Support site making sure you select the driver that corresponds with your Operating System[Windows 7,Vista,Windows XP etc]
Hope this helps.Thanks!
Please rate this answer.
Dec 02, 2011 | Office Equipment & Supplies
How do I get A920 All-in-One to connect?
Hi Doris,
Please make sure the Operating System you are using corresponds with the printer driver.In other words,make sure the driver you're installing is compatible with the Operating System on your PC.
Check out your Operating System's compatible drivers for downloads from this Dell support site.
Make sure you unlock the scanner bed by pushing the scanner lock down.
Check the USB cable connections and make sure its secure.
If problem persists,return the product if still on warrant.
Nov 11, 2011 | Dell A920 InkJet Printer
My hp desk jet d1520 won't work at all!
What type of photo are trying to print?Is it just the photo or its all printings?
Check the settings on printing preferences.
Make sure the paper's correctly loaded.
Re-check the printer connections.
Make sure you've set it as the default printer.
Turn the printer off and on.
Nov 01, 2011 | Office Equipment & Supplies
Hello..just moved my desk top to new desk..everything is fine..but mouse won t work..while it was unplugged i cleaned keyboard..monitor with soft cloth..can u tell me why my mouse won t work
IF it's a serial mouse (meaning green round connector) it's probably not plugged in correctly. Now these are not plug and play so you need to reboot your system in order for it to work. Try that.
Jul 10, 2011 | E-Machines eMachines Desktop PC
I hae come back from holiday to find my printer is'nt working. Its a Kodak ESP3200 Series and I have had about two years. The on/off switch is on all the time and the LCD screen is blank and nothing...
Try to reset your printer to factory default settings. But before you do that, I'd like you to do this first.
  • Open the printer access door.
  • Remove and install the print head two times.
  • Close the printer access door.
  • Wait until the printer is ready to use.
if this won't work.
reset all defaults to the factory default settings:
1. Press Home. 2. Press "arrow down" to select Printer Settings. 3. Press "arrow down" to select Reset All Settings, then press OK. 4. When you see the message, "This will reset printer settings to factory defaults," press OK
Hope this helps.
Jun 17, 2011 | Kodak Office Equipment & Supplies
Printer will not print e-mails
Once you give print command of an email, your email program should ask you to select printer.
If you are using MS Office, by default One Note printer might be selected.
Please check which printer is assigned when you click print.
I hope this information helps.
May 11, 2011 | HP LaserJet 1020 Printer
I recently had to move my desk, unplug
Please check the pins at both ends of the VGA cable.
May 12, 2010 | Soyo DYLM1788 Monitor
HP LaserJet 1012 Printer Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
