Question about Samsung WF410ANR Washer
Wf410 drain pump
Drain pump makes a grinding noise and won't drain; filters are clean, as they have been every month since the washer was new.
  • 177 Answers
SOURCE: LInt filter
Find you owners manual, it should say how to clean the button trap on your pump
Unplug the machine FIRST!
Get some towels, you will have water coming out.
if the tub is full of water you will need to bale it out!
Remove the lower front panel, usually two screws,
look for the pump it will have hoses on it. now lay some towels around, expect water.
Unscrew the end of the pump, if it has a button trap or lint filter.
it will be on or near the pump refer to your owners manual
If you dont have an owners manual you may find it at Samsung.com?
Posted on May 03, 2008
SOURCE: NEW SAMSUNG WASHER WONT DRAIN.
Try clean debris filter locate in front of the machine.
Posted on Jun 23, 2008
SOURCE: Kenmore 90 washer won't drain
How do I operate it? which program should i use for regular laundry?
Posted on Jul 08, 2010
  • 343 Answers
SOURCE: How come it will not drain water after running a
First place to check is the drain pump filter. Low and to one side on the front panel is the access to the pump filter,, A small hatch or maybe behind the kick panel.
Unplug electricity to machine.
Make sure the machine has as little water in it as possible, because when you open the drain pump filter any water in the machine will run out.
Lean the machine back against the wall will help contain any water left in the machine.
Unscrew the filter cover and clean. Check that a hairpin or bra wire or coin is not jammed in the pump impeller.
Replace the filter cover and test.. If you aren't able to do this or the pump still won't work, you probably need a serviceman to check it out.. You may need a pump motor replacement
Not a big job
Good luck....Nomess
Posted on Aug 07, 2010
SOURCE: My Samsung WF218ANW/XAA front load washer will not
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Posted on Jan 22, 2011
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out
Oct 11, 2012 | Washing Machines
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
My HE2 front load wouldn't drain & spin and was making noises below. i called Affordable Repair and they said the control panel had to be replaced for $200 + labor. i said the noise is coming from u
Hi.
The noise coming from underneath is symptom of a problem with drain pump or drain line.
The standard procedure consists in accessing the drain filter to check if it is blocked, then testing drain pump. Most of the time the noise is caused by blockage at drain filter. In some case the pump is gone.
The control panel gets replaced only after checking drain filter, testing drain pump and also after testing the water pressure switch that determines when to start or stop the pump.
Bye.
G.
Dec 08, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool washer dryer has been making a grinding noise for a while and now won't drain
Hi.
The grinding noise was probably being caused by objects stuck in the drain filter. Disconnect power and check the drain filter. On Whirlpool front loaders the filter is accessed from the front of the machine. You will need to unscrew the filter cap and to remove blockage With top loaders the access is underneath or at the back. You lean the appliance on one side and disconnect the hose directly connected to the pump. Disconnect power before starting maintenance.
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 10, 2011 | Washing Machines
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
My washer will not spin, it sounds like it's trying to spin but it won't spin and if i turn the barrell by hand it spins so it's not frozen or anything. Any suggestions?
Hi mwilczewsk,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
Jul 18, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Got an OE error, now it will not finish rinse and spin, sounds like it is grinding in the spin cycle and the timer is stopped at 27 minutes remaining. What is wrong?
The problem is in the drain system as what error code OE stands for.The grinding noise is coming from the drain pump. Loose change, hair pins and the likes can get into the pump filter and sometimes into the pump impeller causing a grinding noise during the spin cycle because the pump works while the machine is spinning. The pump impeller may also be broken causing the grinding noise.
Disconnect power then open the filter door on the bottom left of the cabinet.
Remove the drain plug and drain the water out completely into a shallow basin or the likes. Once drained, lay a piece of towel under the filter then turn the filter knob counterclockwise and remove it. Clean the filter and reach in the pump impeller to check it if blocked or broken. If cleaning the filter does not solve the problem, you need to access the drain pump assembly and check the pump particularly the impeller thoroughly. Click on the link below for the detailed procedure in accessing the drain pump assembly.
LG Front-Load Washer Drain Pump Access
Dec 30, 2010 | LG WM2277H Front Load Washer
OE error message washer fills with water then just makes a grinding noise.
It is a long drain error. The washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Drain pump filter The filter maybe clogged with foreign objects, clean it. If the filter is damaged, foreign objects may get into the pump impeller and clog it. Keys, coins and pins in the impeller maybe causing the noise.
  2. Drain hose The hose maybe frozen, kinked, twisted or crushed. Repair or replace if necessary.
  3. Connector The connector may disconnected or disassembled. Reassemble or repair if necessary.
  4. Drain pump coil
    Check pump coil resistance between the terminals using an ohmmeter. Resistance should be between 10-20 ohms. If the resistance is too high or too low, replace the drain pump.
  5. Voltage Check the voltage between the connector in step 3 during spin. The voltage should be 120Vac, else replace the main board assembly.
Regarding the grinding noise, run the machine while the cabinet cover is open and check or observe where is the noise coming from. If it is coming from the motor:
  1. Check if the bolts are loosened. Re-tighten it loose.
  2. Replace the motor stator and rotor assembly if still noisy.
Nov 05, 2009 | LG WM1814CW Front Load Washer
Samsung WF410ANR Washer Logo
200 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
