Question about Refrigerators
Samsung rf267abrs refrigerator lights do not come on. bulbs are good. Freezer light comes on ok.
SOURCE: HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
The problem is in the control board. A diode is shorting the relay, also has burned off trace. Looking for diode to replace as I write this.
Posted on Jun 30, 2008
SOURCE: Sub-zero 550 series
I had this problem in the fridge portion last year and replaced the switch at the top of the door. Problem solved. There should be two switches: one for the lights and one to turn off the compressor when the door is open. I don't remember which one was which. Try the link below for the part, but double check to make sure it's the right one. They have an 800 number to call as well. Good luck
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=753971&PPStack=1
Posted on Jul 22, 2008
  • 5 Answers
SOURCE: The light and digital controls on the refrigerator side dont work
I replaced a circuit board that is in the white box at the lower left rear of the fridge. You will need to remove the cardboard cover, then there is two screws to loosen the box. The circuit board is inside. There is a white tab that sticks up push it sideways and it will pop right out. Put the plugs in the new board and pop it back in and put everything back together. Be sure the wires are routed so they do not contact the compressor.
If you want to test it first get a voltmeter one probe to CN1, the white wire, and the other to CN2, yellow wire with red stripe, there should be 120 volts. If not, or when the door is open it drops replace the board.
I did not have a voltmeter but it seems everybody that had a problem the fridge was 4 to 5 years old. So I bit the bullet, around $90.00, and replaced it and it works!
Posted on Dec 31, 2008
  • 32 Answers
SOURCE: Hi my samsung freezer rf267abrs is not freezing
FAULTY COMPRESSOR OR GAS LEAK. IT CAN ALSO BE YOUR THERMOSTAT. YOU WILL HAVE TO SEND IT TO SAMSUNG OR GET A TECHNITIAN TO SEE TO THE FRIDGE.
Posted on Sep 07, 2009
shastalaker7
  • 1515 Answers
SOURCE: refrigerator light doesn't work. switch and bulb good.
If you have an elect. meter, you can tape the door switch closed, remove bulb, and touch your leads, one to the center tab on the socket and the other to the threaded portion of the socket, where the bulb screws in and you should have 120volts. If you are sure you have no power, unplug it and try and gently pull out the switch. This is the only thing between the light and main power below.The switch only connects to one of the 2 wires and a connector may have burned or come loose.If you have power to one side of the switch to ground, and its taped closed, and have no power coming out the other side, then you have a faulty switch.You can get a socket and or switch at your local appliance parts house. Just take the model, serial, name, and product # if there is one and they can match one up for you. I'm betting its the door switch.
sincerely, shastalaker7
Posted on Oct 30, 2009
If the fan does not work does this effect the cooling system?
YES AS IT WILL NOT CIRCULATE THE COLD AIR , CHECK UR AIR FLOW DAMPER VENT AS WELL
Jul 05, 2014 | Samsung RF267ABRS Side by Side Bottom...
Freezer is not defrosting. it's a RF265ABPN model
Your defrost termination sensor has failed & needs to be replaced.(very very common problem with todays fridge's specially samsung)
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
Replaced 30 watt bulb in refrigerator section with 25 watt bulb still will not light otherwise working well, my be switch . freezer section light works
Either the door switch or the light socket is bad. Disconnect the refrigerator and pull the switch out and test it with an ohmmeter for continuity.
Jan 06, 2011 | Samsung RB2155SH Bottom Freezer...
Rf267abrs only 14 cubes of ice in 1 day
I would give it a few more days most icemakers will not cycle if the temp around the icemaker are above 15 degrees F.Leave the door closed.Open door for even one minute can take a while for freezer to cool off to temps around 10 or colder. Also if you do not have much in there it may be a problem as well it is harder for freezer to cool open space. If I can help with anything else please let me know.
Apr 08, 2010 | Samsung Refrigerators
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
Hi my samsung freezer rf267abrs is not freezing please help. Thanks
Sep 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
Interior lights not working on Samsung Refrigeration.
My samsung rf265ab did the same thing after I was cleaning it and the door was open for an extended time. I noticed the the light bulbs looked good and also notice 2 tiny black buttons between the light bulbs. They were slightly extended. I pushed both in and when I opened the fridge again the lights were working. Don't know if I fixed it or just a coincidence.
Mar 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
