Question about Exercise & Fitness
My wife plugged in a different kind of charger and now we do not get any display. Is there a fuse or reset button somewhere?
    Top Expert:
  • 12,223 Answers
Yes plelase see the block diagram+wiring diagram attached.
My wife plugged in a different kind of charger and - 1_21_2013_6_20_48_pm.gif1_21_2013_6_21_06_pm.jpg
Posted on Jan 21, 2013
My invacare nutron r51lxp doesn't do anything when I push the power button. I know for certain my charger works
hi , it could be something silly like a fuse , hopefully it is otherwise it sound like a joystick controller issue ?
Check the battery fuses and reset fuses if any are fitted .
Regards
Rob
Aug 09, 2015 | Invacare Nutron R51LXP
Looking for reset button oN TDX SD power wheel chair
Hello, Invacare does not have Reset Buttons on the power for the batteries. They only use fuses. Now if the joystick has a display and it says to press a reset button and it did not used to say that then the programming has be lost or changed by the rain or battery power. You will need to have someone with an Invacare Programmer reprogram the chair or a reset switch can be purchased that will plug into the joystick and allow you to get pass the Press Reset command on the joystick.
Jun 14, 2015 | Drive Health & Beauty
Machine is dead. Is there a fuse somewhere? Krups Espresseria.
There is no easily replaceable fuse unless you are from somewhere like the UK where they have a fuse in their giant wall plug on the end of the cable. Some of those Espresserias had a switch button fault where part of the button can break and the button will no longer activate the switch.
Apr 27, 2015 | Krups Coffee Makers & Espresso Machines
Power runner car battery charger not working. display shows "Err 1"
Get a simple Batt charger from sears. Batt charger does not have to be fancy w/ all kinds of buttons. Some are automatic, some are not and need to be monitored. The simpler the more reliable.
Nov 23, 2014 | Cars & Trucks
Batteries are charged, I have checked wire plugs and all are fine, but I have no power at the on-off control. Is there a fuse block, a circuit breaker, or a reset button unseen under the rear lid?
Jerry to make sure you don't have power to the joystick get a digital voltmeter set it to 200 volts dc and plug the leads into the two outter holes of the charger port under the front of the joystick. Fully charged you should read 25-27 volts If you are getting a good voltage then the problem could be in the on/off switch on the joystick. There is a fuse located under the rear shroud somewhere near the power module in line with the cable coming from the on-board charger. If your voltage is real low then you have battery or charger problem. If you plug the charger in and keeping the meter plugged into the charger port you should read 27-34 volts indicating the charger is working and the problem could be the batteries. Try turning the on/off switch on with the charger plugged in the power should come on and flash indicating charge inhibit is working. If you still get nothing check your cable coming from the rear of the chair make sure its fully seated in the plug. Thats all I've got Hope this helps
Nov 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Is there a reset button?
you need a pro to come in and charge you a arm and a leg..
Just kidding
There is no reset button, but there is a fuse in the back of the unit after the power cord that plugs into the back of the machine. Also, you can reset the system by leaving it unplugged for about 15 minutes. But if you popped a breaker then you blew a fuse and need to replace the fuse, your owners manual should give you a schematics to where the fuse is
May 27, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
When I plug my charger in there are no bars going up and down on the display showing that it is charging. This is after I accidently plugged in the wrong charger and heard a pop. The phone shut off after...
I would suggest just using the phone until you wear the battery down and then put it back on the charger and charge it up over night and see if it charges. If that works then probably the pop you heard was the part of the display that shows the bars going up blowing out but at least the phone will work for you.
Dec 25, 2009 | Cell Phones
Display not working
The display needs to be replace. Check all the wiring also to make sure nothing over heated
Feb 14, 2009 | GE Profile 30" Self-Cleaning Freestanding...
Kenmore Dishwasher - Wife Having Meltdown
Get under the sink and pull the plug. Let it sit for a half an hour or so. While you wait make sure all the drain screens etc. are clean. Usually unplugging will reset board. Kind of like a reboot on a computer. I hope this works usually does if something else major isn't wrong.
Jan 18, 2009 | Dishwashers
Blank Upper and Lower Screens
Try plugging it into the charger and turning it on. If it still doesn't work, you probably broke the internatl port for the charger which is why it's turning on then back off right away because it's not able to charge anymore. If you stil have your warrenty, I would try to take it back.
Oct 23, 2008 | Nintendo DS Console
Exercise & Fitness Logo
29 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
