Question about Epson Stylus NX515 All-In-One InkJet Printer
How to change the ink for an epson stylus nx130 printer
  • Epson Master
  • 511 Answers
Replacing procedure only available if one or more ink tank "empty" or not recognized. Follow "how to..." at epson status monitor. but if you wish to replace, just turn on printer, unplug power chord while carriage moving. The carriage released from locking position, move carriage by hand to the appropriate position.
Posted on Jan 21, 2013
SOURCE: changing ink in a epson stylus 8400
on the printer push setup, then push ink levels from there you should be able to select the change cartridge and be good to go
WW
Posted on Aug 13, 2008
  • 38 Answers
SOURCE: Epson Stylus DX7400 - Ink cartriges
Lift the scanner up to expose the inside of the printer. Thers a button "stop" top left face of printer, press and release and the print cartridge holder will move, press again and it will stop at the colour that needs replacing, press again (total four times) to show if other cartridges are ok. Press again and the cartridge carrier will return to right of the machine. Lift the lid (grey colour) to show the cartridges, remove and replace the ones that have been shown to be empty. Close the lid, it should click. Close the scanner down again. Press "start" to recharge the cartridge. ANy other problems try the epson support site. Good luck.
Posted on Dec 07, 2008
tigertail
  • 163 Answers
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Posted on Apr 14, 2009
cns assoc
  • 677 Answers
SOURCE: EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
Why won't my Epson NX130 work after replacing one ink cartridge?
you didnt hold your tongue like this :P
will need a lotta more info on this exactly
errors ,
try this reset prog from epson
Epson Ink Pads Reset Utility
May 04, 2015 | Epson Stylus Multifunction Inkjet Printer/...
Epsom NX130 wont print after replacing new ink cartridge. Have taken all out turned off power. Not working
Does it try to print, but the page is blank, or does it simply sit there?
If it tries to print, but nothing comes out, you may have a clogged print head.
If it doesn't even try, did you use a genuine Epson cart, or an after market? Epson printers won't print if even one cart is empty.
May 02, 2015 | Epson Stylus Nx130 Mfc Inkjet
How do i scan using the Epson NX130?
Lift lid and place article to be scanned in.
Then click right on printer app /shortcut or inn device and printers
folder and you will see preview scan click on that and it will come a
s preview. It's common sense from there.
May 15, 2014 | Epson Stylus Nx130 Mfc Inkjet
Epson Stylus NX130
That's the problem with Generic carts. Use either Genuine carts or Resettable Carts.
Mar 04, 2014 | Epson Stylus Multifunction Inkjet Printer/...
I lost my cd for installation for my epson stylus nx130/tx130 series printer
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
May 25, 2012 | Office Equipment & Supplies
My stylus sx 205 will not stop and let me change
After some searching (Epson doesn't make it easy), I found this documentation on how to change the cartrages for the sx200 series using the software:
http://support.epson-europe.com/onlineguides/en/sx200tx200/html/trble_2.htm#s-01200-00500-00100-00300
The support page for your printer is here: http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-SX200/Drivers-Support?supportLandingPage=true
The downloadable pdf of the manual is here:
ftp://download.epson-europe.com/pub/download/3210/epson321015eu.pdf
Apr 23, 2010 | Office Equipment & Supplies
Changing ink in a epson stylus 8400
WW
Aug 02, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
Jul 17, 2008 | Epson Stylus C46 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus NX515 All-In-One InkJet Printer Logo
227 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
