Question about Watches
Replaced batteries in Casio Pathfinder watch. Functions work, but alarm does not sound.
Touched contacts as noted. All funtions work, except for alarm sound. Can set alarm, alarm symbol flashes, but alarm does not sound. The hourly alarm does not sound either.
  • Watches Master
  • 18,391 Answers
There are two reasons for this while changing the battery the small coil sping that operates the alarm as fell out or you av put the back on in the wrong position
Posted on Jan 20, 2013
indays
  • 111 Answers
SOURCE: Timex Expedition alarm beep
good after noon ! maybe the problem of your watch is wrong possition of case back because the speaker or buzzer of your watch is attached on the case back , so open the watch and fix the case back at the correct possition ,!thank you ! god bless !.....
Posted on Aug 29, 2008
SOURCE: how to set alarm disney digital watch mck 367
hold reset and start at same time
Posted on May 15, 2009
SOURCE: hourly alarm keeps going off, despite no alarm symbol showing
If the 2 dots (colon) on your time display are flashing you need to press START/STOP. I have had this problem for ages and it's been driving me mad, but just re-read the instructions for the 100th time and spotted it - it's the last sentence in the SET TIME-DATE section.
Hope that helps!
Posted on Aug 27, 2009
SOURCE: how to get casio sea-pathfinder working after replacing batteries
got a sea pathfinder and just got it back after sending it away to get batteries replaced. Worked fine for a day or two but now none of the buttons work at all - it is still chugging along keeping the correct time but no buttons including the light works - is there a manual reset procedure without taking the back off?
Cheers
Daz
Posted on Sep 03, 2009
  • 2501 Answers
SOURCE: I have an Armitron 40/8125 watch. I try to set the
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Posted on Mar 18, 2010
I just changed the battery on a Casio watch A158W and now the alarm and hourly chime doesn't work.
The replacement battery may not have been installed properly. It can be a tricky operation. Also, the replacement battery could be ng.
May 31, 2013 | Casio Pathfinder PAG40B-2V wristwatch
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    I have a Casio 1470 pathfinder watch. I did not use it for several years The batteries ran down, have replaced them and now have no display or functions
    mcdevito75 here, I would see the jeweler who installed the new batteries and ask to have the battery install double checked so they are makeing proper contact with the LCD movement. In the meantime you can try to hold down the MODE button for a few seconds and see if the display appears, also if the display screen has turned very dark, your Casio may have had it, as the LCD display could have gone bad. New batteries should bring up a display even after the watch has been stored. Hopefully the display is still a grayish color and the new batteries need re-alignment.
    Aug 11, 2010 | Casio Watches
    Compass comes up with RECO, what does this mean?
    If you use the backlight of the alarm a number of times during a short period, RECOV appears on the display. After some time, battery power will recover and RECOV will disappear, indicating that the above functions are enable again.
    Mar 20, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
    Sound not working for any alarms after replacing battery on Casio 526. All other functions work.
    The sound board is the touchiest part of watches with sound. This can be subject to all sorts of problems during battery replacement. You can sometimes get all the functions back by "AC"ing the watch but in many cases once it is fried it will have to be replaced.
    To have an "AC" or reset performed you should see a watch maker or technician specializing in watch repair.
    Sep 17, 2009 | Watches
    Casio SPF 40 beeper not working after battery change
    There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
    regards,
    Pieter
    Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
    CASIO SPF40 battery replacement
    "AC" means All Clear. This terminal should be marked somehow. Use a magnifying glass to get a good look at what you are working on. My Casio had an arrow pointing to four copper leads. I used a paper clip to connect the AC terminal (I just picked one of the four) to the + side (usually the "up" side) for a couple seconds and my Casio Sea Pathfinder model 2273 powered right up. See the following link for more guidance.
    http://www.geocities.com/watch_crazy/battery/battery.htm
    Feb 24, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Casio illuminator, w-94h
    There is a tiny spring that must make contact with the back cover plate when you screw it back on. If the spring is missing, the piezoelectric buzzer will not work. The tiny spring is located toward the upper right in this photo of a Casio W-94H watch, directly underneath the "C" in CASIO that is etched in the metal. Note that the word CASIO is upside down in the picture, so if you can't see the picture for some reason, the hole for the tiny spring would be directly above the "C" in CASIO.
    Nov 25, 2007 | Casio Sea Pathfinder SPS2011V Wrist Watch
    How to get casio sea-pathfinder working after replacing batteries
    This certainly put me on the right track,but i found on my pathfinder mod 2271 that the four brass dots located down in the hole were unacessable with standard flat head tweezers so I inserted a small sewing needle and touched one of the brass dots while bridgeing the distance from the needle to the positive (+) surface of one of the four batteries with tweezer legs.
    Nov 19, 2007 | Watches
    Watches Logo
    116 people viewed this question
    Top Watches Experts
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
