My pioneer receiver sx-319v is not turning on, suddenly stopped working. What could be the possible reason? Fuse changing required?
  • Baharak Raoufi Jan 22, 2013
    Thanks a lot guys..I am going to try with turn ON and OFF solution! Although I have a doubt..I did couple of times, after found the fuse and noticed its ok..its bugs me off to spend 70 to 90 box on it when I see someone is selling whole package including speakers for 120 box on ebay !!! but what to do !!
    Thanks a lot guys. I will bump in the result of your solutions..cheers
SOURCE: the remote to my pioneer
HI;
I'm having the same problem. All that is needed for a quick fix is to unplug the receiver and wait a while and plug it back in. You might have to do the unplug and plug back in a few times and you may have to wait hours but eventually each time this has happened to me I've been able to get it working again. You will find this in the Trouble Shooting guide under Other Information. the problem I'm having is it keeps doing it and can be really annoying. Even the face controls go out and no control of the receiver is possible. For the money you would think it would be a bit more robust. It's acting like a Korean Microwave I bought about 15 years ago.
Posted on Jun 27, 2008
  • 336 Answers
SOURCE: I have a Pioneer SX-1300 receiver (made about
It will need 2 output transistor replaced. They are attached to the lagre heat sink in the middle of the receiver. Printed on them will be a letter and numbers like A1302 and C3281 the part number will be 2SA1302 and 2S3281 (these are examples) you can find parts online at many sources (I like MCM electronics). This is not a difficult receiver to work on, a bottom panel is removable. The bad pair will be shorted between at least two off the legs.
If you take it in to be repaired $70-$90 would be a fair price.
Posted on Nov 29, 2009
Testimonial: "Quick response, identified the exact issue and how to diagnose. I appreciate it."
SOURCE: Pioneer DEH-P2650 installed in boat,
www.indyoga.blogspot.com
Posted on Mar 10, 2008
  • 336 Answers
SOURCE: Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Posted on Dec 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: Can I connect my pioneer SX-255R stereo receiver
Yes, but it depends on your laptop hardware and software. We'd need to know a lot more about that side.
Posted on Jan 21, 2010
1976 pioneer sx 1250 receiver has no sound from receiver to speakers
for
1976 pioneer sx 1250 receiverhas no sound from receiver to speakers
check the integrity of speaker systems,
check the receiver internal components, pay close attention to the
capacitors, possibly have dried up or swollen (age)
Check for continuity to the speaker outputs.
These may take some time, but I hope you will make it.
Sep 09, 2012 | Audio Players & Recorders
Pioneer sx315 receiver shut off after being cranked up for a while and wont turn back on checked fuse its good. power button seems to work clicks when turned on and off
If the power to the outlet is still good, then I would suspect the power amp IC or output transistors are shorted, keeping the power from coming on. It's also possible that one or more of your speakers are bad feeding back to the receivers output connectors, especially if you were running speakers with a different power rating or impedance that your set is designed for. Hope this helps.
Jul 10, 2011 | Pioneer SX-315
I have a pioneer 1080 receiver. it turns on but no sound
Could be in protect! Possibly a channel is out and won't let the unit turn on. Is this the picture of model or is it the older SX-1080?
Apr 13, 2010 | Pioneer VSX-90TXV Receiver
Blown Fuse / SX - 205 / Pioneer reciever
Check the area where the fuse was...it's usually marked on the board or next to the fuse holder. Check the size also, 2 types 5x20mm or 1/4x1 1/4 in. Usually slow blow.
Mar 30, 2010 | Pioneer SX-205 Receiver
Pioneer SX-450 Receive: Left Channel is not working. The reason is a short circuit (cable)on an Exi tof the Channel. Thank your.
Hello. Receiver is been repared. I was told that a transistor and some resistors falled aut.
Thank you for assistance.
Regards,
Vladimir
Nov 03, 2008 | Pioneer Audio Players & Recorders
Overload
Have you checked your wiring connections? Wires could possibly be touching each other making it short out and giving you that "Overload". If not that then I would say it could possibly be a fuse that has gone bad inside. ??? Just some suggestions. The reason I say that it could be the wiring is because when I hook up a system and the wires accidently touch each other it overloads the system past a certain volume. Again I would check my wires first and move on from there.
Dan Colton, Ca
Sep 24, 2008 | Pioneer SX-205 Receiver
PIONEER SX-315 (WONT TURN ON)
I had the same thing happen last year. Any help would be appreciated.
Jan 05, 2008 | Audio Players & Recorders
Pioneer SX-203
a little bit foolish thing: see if you have both the speaker channels (A and B) down. if you have both down it doesn't work - didn't for me.. and obviously make sure you have the right letter down - same outpout as your boxes
Dec 06, 2007 | Pioneer SX-205 Receiver
264 people viewed this question
 Grubhead
Grubhead
