Question about Brother BRTPT65 PT-65 Label Maker Printer
P-Touch Model PT-65 won't turn on when pushing On Off Button
Started having to push very hard a week ago to get the power to turn on. Now it will not turn on at all. I have placed 6 new batteries in it also. Your help would be greatly appreciated. Please feel free to call me cell at 970.317.1764 Sincerely, Tiffany Marsh Maycock Insurance Agency, Inc. Durango, CO 81301
    Problem Solver:
  • 4 Answers
Brother P-Touch Home & Hobby PT-65 / BRTPT65
(PTouch, P Touch, PT65, PT 65, BRTPT65)
Answer from
Posted by Tiffany Marsh on Jan 20, 2013
http://www.fixya.com/support/t16011345-p_touch_model_pt_65_won_39_t_turn_when
Replace the "Toner Sensor PCB Assy" model # LJ9935001. It is located in the left side panel which is easily removed (2 screws).
"I have solved my own problem, I have a second identical printer that just developed the same problem, so this seems like a common problem. The solution was to replace the "toner sensor pcb assy" model # lj9935001. It is located in the left side panel which is easily removed (2 screws), I had it replaced in half an hour and that was the first time. It clips in ,the wire needs threading a little then then connector . if you take your time and think it through it is easy then turn it on and presto nothing but green status light. costs $18.50 with shipping ground. Contact Brother 901-379-1000, get customer service and ask for parts dept. Best of luck."
I found the the Toner Sensor PCB Assy" model # LJ9935001 for $9.89 just by searching through Google and Amazon, so shop around, $18.50 is expensive when you can buy a gently used PT-65 on ebay for $10 - $25.
Posted on Mar 23, 2013
SOURCE: red status light came on red and toner light --orange
Posted on Sep 21, 2008
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Posted on Dec 29, 2008
DJGray
  • 56 Answers
SOURCE: with a pt 65, how do I reduce the size of the print?
Cook,
With the unit powered up, press and hold the yellow Code button. While holding it down, press the & key and watch the pointer at the top of the screen. Note how it is moving to the various size As. That will increase and decrease your font size.
Posted on Mar 05, 2009
  • 7 Answers
SOURCE: Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Posted on Apr 09, 2009
  • 21 Answers
SOURCE: P-touch Model PT-100 not working
You could send it back to the Manufacturer but you will find that the cost of doing so would be not far less than buying a new one
Posted on Dec 03, 2009
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Why is my shifter hard to shjft from park to any gear?
your having a problem with the shift interlock cable not releasing. need to check power and ground at the solenoid near the shifter, may be a broken wire.
May 23, 2012 | 1997 Toyota Land Cruiser
I have a acer (aspire) notebook. And a couple of months ago i was playing on it and it had a blue screen. I got scared and didn't go on it for like a week. A week later i went back on it said acer on...
No bootable device means your computer is trying to boot from a storage device and it's unable to find the operating system. Check the your system BIOS to see if your computer is still detecting your harddrive. To do this:
1. Reboot your comp. While it's coming up, keep hitting "Delete". This will bring up the Set Up.
2. Using the navigation keys of your keyboard, navigate to the tab that says "Boot Preferences" and hit enter.
3. Switch the boot device to your harddrive and save your settings then reboot.
4. If your harddrive is not being detected, it's either loose or has gone bad. In which case it would be best to have a tech take a look at your notebook.
May 22, 2011 | Computers & Internet
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
Unit won't turn on -is it dead?
I had a problem in that I purchased cheap batteries. Brand new out of the box at least three were bad. Confirm your batteries are OK by using them in other electronic items. Even one battery too weak or bad will cause a problem.
>I'm also assuming that you have correctly replaced all the batteries back in the PT65. My mother always puts one battery in wrong and needs help. LOL...
Apr 26, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
The Power Button BROKE!!
Coby offers out of warranty repair/replacement, please send following:
$31 Money Order
Note with your Name, Address, Phone#, Description of the problem
Unit with all the accessories:
Send to:
Coby Electronics
ATT: Customer Service
56-65 Rust St
Maspeth, NY 11378
They will replace the unit for you with a brand new model. Turn around is about 2-3 weeks.
Jun 15, 2008 | Coby MP-C7085 MP3 Player
Brother BRTPT65 PT-65 Label Maker Printer Logo
551 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
