Question about Dryers
Dont know were to put the right wires back on a heat switch on a sensordry dual heat tumble dryer
Wirering diagram
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Which switch?
Posted on Jan 20, 2013
RJTech
  • 32 Answers
SOURCE: kenwood
replace both 30 amp fuses in you fuse box and try that.
Posted on Dec 23, 2007
futureloginn
  • 734 Answers
SOURCE: Dryer runs, tumbles clothes, but does not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
beltronic205
  • 1474 Answers
SOURCE: White Knight sensordry tumble dryer which only works on low heat
Could be element or thermostats, element is twin giving two heats ie !00watt/ +1800watt, possible one side has gone, you bcan check with multimeter and compare readings..Good luck
Posted on Oct 01, 2009
heatman101
  • 43501 Answers
SOURCE: Hi. I have a maytag performa series electric
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
This also tells you where is find a diagram...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
caroldon
  • 17130 Answers
SOURCE: anyone know where I can
You can trace this out without any service manual , to only keep the logic of tracing the voltage to the circuits. Now if the tumble is not working it is the motor not working, so check if the door switch is working and then the program controller.
If there is power to motor is humming check if this has a capacitor. If so check if faulty as the motor will not start.
www.appliancerepair.net/dryer.htm
www.devicemanuals.com/guide/???dryer-manuals.html
Posted on Sep 30, 2010
Testimonial: "Thanks. This was helpful in confirming our actions to date. motor, fan, door, controller all working. How do we check and replace capacitor? "
No heat from my dryer
the first thing to check is the house wiring.if you do not have a volt -ohm meter get one and learn how to use it! if not get someone who can.you could have a bad fuse,breaker thermal fuse on the dryer ,thermostat, timer ,or motor switch, or a bad wirer always check voltage first.check where cord is connected at dryer.3 terminals check from middle to left 120v. middle to right 120v. left to right 240v.if you don't get them dryer is o. k.
Mar 15, 2014 | Inglis 65 Cu Ft 5 Cycle Electric Dryer...
Anyone know where I can obtain a copy of a service/troubleshooting manual for Sensordry WhiteKnight tumble dryer? Dryer will not tumble.
Sep 30, 2010 | Dryers
Tumbles but dont dry
74632 is not a model number. But what you have stated the dryer probably has a bad thermal switch. Cost around $6-8. Unplug dryer, remove back, with a tester test everything that has wires hooked to it. Test from one side to the other to see if power goes through, if not replace that part. They are small round or small rectangle with two wires connected to them. Check the one one the duct first, this one usually goes bad. Vacuum out all lint out of dryer and hose to exterior, excess lint will cause dryer to heat up and blow this part.
May 08, 2010 | Kenmore 74632 Gas Dryer
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
Apr 19, 2010 | Dryers
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
Feb 12, 2010 | Dryers
My white knight tumble dryer does not heat up,tried pressing the reset button but still does not heat up
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
Oct 01, 2009 | Dryers
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Heating element
Thermal fuse
Wiring
Aug 09, 2008 | Maytag SDG4606A Gas Dryer
Dryers Logo
Top Dryers Experts
