Question about Whirlpool Dryers
Switch dryer door - Whirlpool Dryers
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number and what problem are you having?
Posted on Jan 20, 2013
Dryer
test this steps and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#electric#ixzz2Zk5oxDiH
Jul 21, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Amana Dryer Model # NED4500VQO won't start
see the following steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-1#ixzz2Yb4M1zkU
Jul 09, 2013 | Dryers
Maytag Bravo 400 series won't start. I click the start button and it beeps but nothing happens.
Well first of all you can check door switch - If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. The door switch is a simple on / off switch to indicate whether the dryer's door is open or closed. The dryer will not operate when the door is open. If your dryer runs with the door open, the switch may shorted closed or there may be a dangerous electrical short in your dryer. If your dryer will not start when you press the start button and you hear no sounds, the door switch may be the problem.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Maytag Dryers
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
My frigidaire stackable dryer wont turn on when i turn the start switch any clues?
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
I would also check the thermal fuse as well. it is located on the vent duct or blower housing. If this fuse is damaged or tripped, it will not allow the dryer to run as well.
Jul 20, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer drum will not turn
Jul 20, 2009 | Dryers
Frigidaire Crown dryer will not start. Has power to it
Check the following to address this issue.
Jun 11, 2009 | Frigidaire Electric Dryer
Estate dryer wont engage
Check the following--
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Dryers Logo
26 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
