I have a cricut expression 2 and after I turn it on it won't go past the Cricut screen. Any thoughts?
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 20, 2013
3 Suggested Answers
  • 9 Answers
SOURCE: need to update firm ware on cricut expression so i can use sure cuts alot could not find at cricut.com
Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
balboul@gmail.com
Posted on Jul 05, 2009
tommya300
  • 724 Answers
SOURCE: Cricut Expression flashing lights
Souns to me like the cutting slide head is binding or the material transprt has a meesed up gear train. Or the case has been fractured
Posted on Jul 24, 2009
I have 2 Cricut Expression machines. I want to keep the newest one. How can I tell which one that is
from what i can tell, the cricut expression has dials and the cricut expression 2 has a touch screen. Also, I believe the newest one is a little larger in size.
Oct 22, 2017 | Crafts & Hobbies
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    My cricut wont turn on
    Hi, My cricut expression is more then 5 years old. I used it one day and the next day I would not come on (it dose Nothing at all). I brought a new power cord from cricut and still nothing. I'm unable to buy a new one Please help if you can. Thanks!!
    Jan 26, 2014 | Cricut Expression Cutting Machine
    Why does my paper move out of place when the cricut expression is cutting? Is somethhing wrong with the roller bar?
    I would just use a new cutting mat if the mat your using isn't sticky enough your paper will move.
    Mar 25, 2012 | Cricut Expression Cutting Machine
    Cricut expression 2 has no power, will not turn on
    Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
    Nov 05, 2011 | Cricut Expression Cutting Machine
    Brand new cricut doesn't turn on, just clicks with lights blinkin
    Yes, I was just going to recommend contacting them. I see you have contacted them already. Good luck with getting it fixed~they are prompt in helping with machines. If you have any further questions about the cricut feel free to ask.
    Aug 20, 2009 | Provo Craft Cricut Disney Font Cartridge
    Dials not working
    You may want to try resetting your Cricut to see if that fixes the problem. To reset the Cricut machine, turn the unit off for five minutes. Roll all the dials all the way up and all the way down five times each. Turn the Cricut back on. This is the manufacturer's reset process. Good luck!
    Mar 13, 2009 | Provo Craft Cricut Disney Font Cartridge
    Computers & Internet Logo
    140 people viewed this question
    David Payne
    David Payne
