Question about HP PSC 2210 All-In-One InkJet Printer
Would not print from computer - HP PSC 2210 All-In-One InkJet Printer
There are many possible issues that could cause a printer to not print.
First, did your printer come with an installation disk? If so, have you used it? If not, pop that disk into your computer and click "Install". Next, make sure you have the printer in question selected on the print screen.
Also, be sure that your printer is hooked up properly. All cables should be plugged into printer and computer.
Posted on Jan 20, 2013
My printer keeps saying I am out of paper and I am not it is a hpdeskjet1000
Posted on Jan 29, 2013
How can I get text message print out
Well, you need to transfer them out of your phone and save them as printable formats.
if it is an android phone, you can have a look at this guide,
How to Print out Text Messages from Android Mobile Phones
Dec 12, 2016 | Cell Phones
I have a cannon ir3300i printer is not taken print..computer says out of paper printing..but paper is available in printing..how to resolve this query mail id internetstation2012@gmail.com
try turning off both devices - start you computer first, then start your printer and see if that fixes your issue. if not try again this time leaving out the plug that connects the computer to the printer and then when the computer is turned on turn on the printer then plug it into the computer
Aug 08, 2012 | Canon (6981A002AA) for imagerunner 2200,...
WON'T PRINT TO MAXIMUM PRINT AREA
You should change the margins in the word document before you print to 0.5 mm on all sides and remove header and footer.
May 02, 2012 | HP Officejet 6500 Wireless All-in-One...
Unable to print documents from computer. Computer
good day, sir try to uninstall your driver and re install again and re start your computer and see what happening. tnx....
Nov 09, 2009 | Canon imageRUNNER 1023iF Black and White...
The segement of the print server you select is different from your computer" on Vista,
Meaning that the IP Address of the print server is different from the computer's IP Address.
If you're computer has a static IP Address, you need to assign a static IP Address for your Print Server. To assign a static IP for the print server, you need to open the PSAdmin utility on your computer, locate the TCP/IP and click the plus (+) sign. Double-click the IP Address and you may change it from there.
Make sure that the IP Address of your computer, router and print server are in the same IP range. And make sure that you could ping the IP of the print server.
Then configure the printer port settings and you should be able to print.
Have a great day!
Jul 03, 2009 | IOGear GPSU21 Print Server
HP 1020 LaserJet Problem I can only print one job and then have to restart the computer before it will print again. The jobs are in the print que, they just won't print. When I restart the computer a...
Change the USB cable. The cable you are using isn't sending data BACK to the computer that tells the computer that the printer is ready, and you have to reset, Change the USB cable for a NEW one, and then your computer will talk to your printer and vice-versa.
Feb 16, 2009 | HP LaserJet 1020 Printer
Printer will not print, I have downloaded the driver for this modle
Try to print on a self test, all printers can print without using the computer please check your manual on how to self test the printer without using the computer.
If your using a cable plugged in directly to the computer use another port then test to print. If still same you might have print in queue on your computer you have to restart the spooler on your computer so you can print.
You can check on this website so you have an idea.
http://www.videojug.com/interview/computer-tips-and-tricks
Oct 10, 2008 | Office Equipment & Supplies
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Docments
Every printer has a unique print driver on computer, and each and every printer uses a different one, so there goes it cant be my computer. The way to tell if it is a printer or computer problem on your machine is to Turn off, unplug from computer, ensure your printer has paper, power it on, wait for ready/online lamp, then press the "go" button 5 times super FAST. Status page should print if it does, then your problem is in fact the computer or the print driver not installed correctly on your computer, as I suspect may be the case.
Post back once you have verified if you have a printer or a computer problem.
Jan 08, 2008 | Brother HL-2040 Laser Printer
HP PSC 2210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
