Need to replace keyboard on toshiba laptop Att300
P775-S7320
  • 27,725 Answers
Laptops are a great line of computers that offer their users portability. However, one drawback of laptops being so portable is that all of their components are internally attached. Replacing things on a desktop computer can be as easy as unplugging a cord. With laptops, simple things like changing a laptop's keyboard becomes slightly more complicated.
Unplug the laptop's power cord from the wall outlet and remove the internal battery pack. To remove the internal battery pack, simply locate the release button on the bottom of the laptop. This button needs to be held in while the battery pack is slid free from the computer. This button locks the battery in place, so if it is not held in the battery pack will not be able to be removed. Unscrew all of the screws from the bottom of the laptop. All laptops have different amounts of screws holding the external case together; however, there is usually one screw at each corner, and then one or two screws in the center of the laptop. Once all the screws are removed, slide the laptop's hard drive from the computer. The computer's hard drive will generally be located on the left or right side of the laptop; there will be a small symbol engraved into the laptop to denote its location. Remove the screen from the body of the laptop. To do this, remove the two screws from the back of the computer that hold the screen's hinges in place. Once the screws are removed, pull up gently on the screen until the two pegs that held the screen up have cleared the holes in the laptop's body from which they rested. There will be two wires that lead away from the laptop screen so make sure not to pull up so far that they become disconnected. Separate the two plastic halves of the laptop's external case to expose the computer's internal components. Lift up on the keyboard pad and flip it on its face. You will notice a film-like strip that leads away from the keyboard and into the heart of the laptop. Before you can remove the keyboard, you must unscrew the metal piece that covers the computer's motherboard. This piece takes up the majority of the inside of the computer, so it will be very obvious to you when you are looking inside the laptop. Disconnect the keyboard connection after the metal covering from Step 4 has been removed. To remove the keyboard, follow the film-like strip back to where it connects to the computer's motherboard. The end of the connection will be held down by a small plastic tab. Pull up on this tab to release the keyboard connector and simply lift the old keyboard out of the laptop. Connect the new keyboard to the laptop. To do this, simply stick the end of the new keyboard's film-like connector inside the plastic tab that you released to remove the old keyboard. Push the tab back down so that it holds the end of the new keyboard's connector in place. Reassemble the computer by putting the components back in the exact spot you removed them from.
http://www.laptop-repair.info/laptop_keyboard_repair.html
Posted on Jan 20, 2013
2 Suggested Answers
apark109
  • 107 Answers
SOURCE: How do I lower mute
This model Toshiba laptop indicates you have Windows 7 installed as your operation system
Please look at the bottom right of your taskbar, there should be a little white speaker facing right, or put your mouse pointer over it and it will tell your what is is.
By left clicking on that icon a popup will show up with a slider bar for volume control up or down as well as a little speaker icon to click and mute the volume.
If you cannot find the icon to perform this task, right click on any open area of your bottm taskbar and then click on properties to go to the properties of the taskbar. Click on the "blue" box to go to a list on icons and options to be displayed on your taskbar. Select the features you would like and then click OK. You then can perform the adjustments as directed above.
Good Luck
Posted on Aug 27, 2011
Keyboad does not work after formating C drive, need to take out solder in Cmos battery, or reset cmos password Mother board #s PHRA REV:1.0 2011-01-31, also Hann Star MV-4 94V-0
Formatting the drive will not stop the keyboard from working. If the keyboard won't respond with the dos notes after pressing F8 at start up, I would replace the keyboard.
Jul 17, 2015 | Toshiba Satellite P775-S7100 17.3" Laptop...
How do I replace or repair the hole that the AC cord is plugged into on my laptop?
Have to take laptop apart, pull connector out of bottom section of case, could connect it with jack hanging out of laptop or you must purchase a new bottom case and have the way its suppose to be.
Jul 04, 2015 | Toshiba Satellite P775-S7320
How do you replace the hole that the electric cord plugs into? I can't keep my computer charging.
if your skilled enough, you can replace the dc jack on the laptop motherboard, but i dont recommend unless you have some experience stripping down laptops and soldering
Jul 04, 2015 | Toshiba Satellite P775-S7320 Core...
How do I turn back on the optical drive power on my Toshiba satellite p775-s7320 laptop ? Thank You.
You might want to enter BIOS on your computer and check if it's enabled from there. To get to BIOS you usually have to press either F1 or F2 on boot screen.
Jan 03, 2015 | Toshiba Satellite Computers & Internet
My Toshiba satellite P775-S7320 will not power on.
Remove the battery and power unit. Ensure there is no USB or cables connected. Insert battery and power unit. The power/battery light should illuminate. If it doesn't, the battery may be flat and the power supply not working,
Nov 05, 2013 | Acer Aspire 5100 Notebook
My screen on my toshiba laptop P775 comes on but looks broken
If you mean broken as in it has a crack, it has liquid effect leak or dark then yes you have a broken lcd
Replacing is not a difficult as it seems, mainly by removing a few screws around the frame hidding under the rubber pads, then sometime you also need to remove the keyboard/power control panel, then its jsut a case of removing the broken lcd and buying a replacement panel and fitting it.
heres me taking a panel out on another laptop but gives you the idea.
If your in London, then I can do the repair for, cost of parts + 20pounds + return delivery costs.
Feb 03, 2013 | Toshiba Satellite P775S7236 Notebook
After my Toshiba laptop wakes up from hibernation, I get Error F3-F100-0010. Can any one help?
What is on the title bar of the error message?
What programs were you running before hibernating?
Were you browsing before you quickly hibernate your machine?
Elaborate.....
Oct 08, 2012 | Toshiba 17.3 Satellite P775-S7320 Laptop -...
Camtasia Won't Audibly Record on new Toshiba Laptop
I suggest you to check your system audio setting and reinstall Camtasia. If such problem persists, you may try another free web-based tool which may work on your computer.
Jul 03, 2012 | Computers & Internet
I am looking for an onlineTutorial for my new laptop P775-S7215. Where canI findit??
Hi sibosf
You can download a user manual for free at this site, but you have to answer a few quick questions about the laptop.
Please take time to rate me
http://safemanuals.com/314159.php?k=56a1173718da0926fc965b055fca6cc4&ID=3883393&q=TOSHIBA SATELLITE P775
Aug 18, 2011 | Toshiba Computers & Internet
How to download user's guide for satellite laptop
Well, you need a PDF viwer like Adobe Acrobat reader, if you you already have it then please visit the following link to download your laptop's user guide.
Links :
Shortened : http://bit.ly/qifPrj
Actual Link : http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su3025174/GMAD00274010_Sat-SatProP700_11Mar31.pdf
Jul 18, 2011 | Toshiba Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
