Question about Samsung Computers & Internet
Monitor has horizontal lines on half the screen but only sometimes
At times, my monitor has started to show white flickering horizontal lines on bottom half of the screen but at some point they disappear and it's back to normal. Can be at start-up or just during normal operation. This only started about 1 month ago, Dec2012. It's a 19" Samsung monitor bought in early 2008 with my Acer Aspire M5620 - (AM5620-E5301A) (Q6600 - Intel Core2 Quad Processor 2.4GHz)--3GB Ram.
    Top Expert:
  • Samsung Master
  • 77,939 Answers
I would just replace it, the cost to troubleshoot and repair will be more than new.
Posted on Jul 13, 2017
  • 3130 Answers
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Posted on Mar 25, 2006
  • 105 Answers
SOURCE: screen goes black with bright white horizontal line
This problem of loss of vertical deflection with the line offset from center suggests a cold solder connection in the vertical sweep circuit or in the power supply to the vertical sweep circuit. Most service shops should be able to fix.
Posted on Sep 17, 2006
  • 9098 Answers
SOURCE: monitor
I would check the cable and connector pins first. Then I would suspect there's a problem with the video signal board inside the monitor. It could be the LCD panel controls, too. That would make the unit beyond economical repair unless you got a used one.
Posted on Jan 21, 2007
  • 8 Answers
SOURCE: LCD monitor problem
What you described sounds like a loose LCD cable inside. Does it flicker or have video distortion when it's moved?
Posted on Jun 28, 2007
  • 130 Answers
SOURCE: samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Posted on Jun 20, 2008
How to fix white horizontal lines on middle of screen of a PC monitor?
Need to check removing LCD ribbon cable in the monitor. but it is may be a damage of LCD screen ,need to replace the lcd.but in very first check and service the lcd.
Feb 22, 2016 | Samsung Syncmaster S20b300b - Led Monitor...
My moniter screen go's dark with a bright horizontal white line in center flickers
the driver board is bad in the monitor. Has it been in a place that is super hot like in a car? If the verticle driver chip disconnects from the matrix driver array, it will all squish into a single line in the middle of the screen like you are describing.. might try opening and blowing where the driver board connects to the LCD matrix (bunch of connectors on a plastic flat cable/bus connecting to the end of the LCD panel.. heating them could allow them to reconnect.. Its worth a try, right? It has worked for me about 60% time.
Feb 03, 2014 | Envision Computers & Internet
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
White horizontal line across screen
Upgrade the refresh rate to 100 Hz and downgrade resolution
Jun 23, 2009 | AOC CT720G 17" CRT Monitor
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
Computers & Internet Logo
44 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
