Question about Moen 3867 Four Function Hand Shower With Slide Bar
Disassemble moen hand held shower head - Moen 3867 Four Function Hand Shower With Slide Bar
4 Suggested Answers
  • 185 Answers
SOURCE: Just installed a Moen 3867 hand held shower. There
Usually whenever you do any repairs on plumbing, you dislodge calcium from the inner surfaces of teh plumbing. Check to see if ther is a mesh filter in the inlet side of the head. and remove and clean it. otherwise you could remove it and use a vacuum yo try and remove any deposit that may be in it. If that is unsuccessful,
you can always return it, but always remember to open the fawcett and run it before installing the head.
This is an essential part of any plumbing job. Good luck
. If your local store refuse to replace it Moen will gladly do so with no problem.
They are good like that.
Posted on Mar 04, 2010
  • 81 Answers
SOURCE: Moen Hand Shower repair
I don't ever remember seeing a parts breakdown for any Moen hand held shower head. They are like light bulbs and when they go out they are done. Try calling 1-800-BUY-MOEN (1-800-289-6636) for the definitive answer.
Posted on May 29, 2010
  • 82 Answers
SOURCE: Moen model 3867 has a
recheck all the washers and try a little teflon tape if necessary
Posted on Dec 09, 2010
What could be rattling inside the hand held shower head
It sounds like the flow restrictor may have come loose and be rattling around in their. There is no way to open that shower head that I am aware of. If it really bothers you, buy new one.
Oct 28, 2015 | Moen Home
How do I take apart a moen shower head?
You can remove the head from the shower arm by taking a crescent wrench. Put it on the flat sides of the nut on the showerhead and unscrew it counterclockwise. There is no way to take apart the Moen showerhead. If the reason you want to disassemble the showerhead is to clean it because it is clogged, disassembly is not needed. Just fill a Ziploc bag with a 50-50 solution of vinegar and warm water. Place the bag onto your shower head so it is fully immersed in the solution. Use a rubber band to hold it in place. Let it soak overnight and then take a toothbrush to any of the white scaly matter that might remain.
Aug 10, 2015 | Moen Home
How do I disassemble a Moen shower head nozzle?
Cont Moen for help they are great!
Mar 28, 2015 | Moen Home
How to disassemble of moen shower head,where i can start the dismantling?
U don't remove the plastic u stick them hole shower head down in vinegar and let it sit for a while, that will clean it out
Feb 24, 2015 | Moen 6302 flo Deluxe Shower Head Shower...
My grohe 5 spray plus hand held shower is locked in the hand held position and I can't get the top shower head to turn on. The control used to switch easily from top spray to hand held but is now locked...
The control may be clogged with mineral deposits and consequenly unable to function. You can try disassembling the shower to remove the deposits but it may be necessary to replace the complete unit.
Feb 13, 2014 | Grohe 28.444.AV0 Movario 5 Spray Hand...
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
  2. start unthreading centre of head. I used a paint scraper to leverage at first. The threads get loose soon to hand loosen.0588438c-31ce-4428-9378-28140fa37adb.jpg
  3. loosen the spray ring using a lever to get threads started. Hand loosen after that.It's got right hand thread so the outer ring will be turning counter clockwise.3e2cc1ab-35f5-4521-a05f-e1167596fb04.jpg
  4. Take flat rubber gasket out of centre of head and take screw out, then pry white nylon part out with tool. I used tweezer.a1f4f121-e0e1-450a-a9b8-8777342a3262.jpg
  5. Clean scraped parts in hot CLR solution or any vinegar will work as well. Reassemble with lubricant so it works like new. Most likely need for disassembly is clogging or a broken "o"-ring.6fff7106-1b7b-4330-a3c6-089ea42233cf.jpg
Apr 13, 2010 | Moen 3867 Four Function Hand Shower With...
Just installed a Moen 3867 hand held shower. There is no water coming out of the head. Water flows just fine from the hose without the head attached. Is there a restrictor plate or something I can...
Mar 04, 2010 | Moen 3867 Four Function Hand Shower With...
Our shower has not been used for a while. Now when we turn it on
Do you have good flow if you remove the shower head, y/n if not how old is house,galvinized plumbing?? or copper plumbing. Sounds like you have a clogged valve and if so this link will be good.
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Apr 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3867 Four Function Hand Shower With Slide Bar  Logo
118 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
