Question about Cooper Wiring Devices 6482V-K 4SPEED FAN/DIMMER CONTROL IVORY
Is the cooper 6482v compatable with a hunter fan?
We have a twenty year old fan that the switch shorted out and have to replace.. is this controller compatable with the hunter fan or is there a replacement switch that i need
  • 3,287 Answers
Hi, I'm an electrician and can answer your question.
This switch may be expected to operate your paddle fan / light correctly, when properly installed.
"Properly installed" means that the loads will not exceed the limits of the switch. For your Cooper 6482V-K this is: 300 watts of light (bulbs should be standard incandescent types - or other type such as compact fluorescent, but only if they are clearly labeled as "dimmable") and not more than 1.5 amps for the fan motor. This 1.5 amp rating of the switch is usually more than enough to handle most residential paddle fan / light fixtures. The lights must be connected to the continuously variable dimmer and the fan to the 4 speed switch - do not swap.
I hope this helps & good luck!
Posted on Jan 22, 2013
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
Hunter Ceiling fan lost medium speed, kept hi and low. Speed control capacitor melted. Replaced both capacitors (speed and start) AND switch. Still no medium speed. Is it possible part of the motor...
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
Aug 12, 2010 | Hunter Ceiling Fan Control Switch
I have a 52" hunter ceiling fan. It is 10 years old. Only the high speed works now. I small controller in which the switch is connected to seems burnt. It is puffed on one side and hard carbon on the...
mcdevito75 here, You can check with any store that carries Ceiling fans for replacement parts, and contact info, you can check online at Hunter fans.com hope this helps.
Aug 05, 2010 | Hunter (25417) Ceiling Fan
HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Sep 08, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Our Hunter fan speed controller is not working. When we press high, it goes on high speed. When we press medium, it goes off. When we press low, it goes on high speed. When we press off, it goes off. Can...
Hunter's remote systems are notorious for failures. We replaced ours before the fan was one year old, and then it did it again within a year after that. The warranty, of course was on the ORIGINAL part, not the new part, so Hunter will never help you out, even though their remote receivers (the part in the fan) are junk!
Jun 30, 2009 | Hunter Ceiling Fan Remote Receiver...
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Fan does not work, light does
Your remote uses a slightly different band of IR for one and the other functions; lamp or on/off. This IR lamp or the circuit that controls the IR lamp has failed. You will need a new remote.
Hunter is good about making replacement parts available but as you said this is five years old. You may have to look for an after market seller on Ebay and chances are very good you can find a new one there.
Try Hunter first:
From Hunter Customer Care
Email:
Use Our Contact Form
Phone:
1-888-830-1326.
Monday-Friday 7am-6pm CST
Regards,
Worldvet
Jun 03, 2008 | Hunter 27177 Remote Control
Cooper Wiring Devices  6482V-K 4SPEED FAN/DIMMER CONTROL IVORY Logo
80 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
