Question about Hotpoint Aquarius WF000 Front Load Washer
How to fit a belt to a wf440p washing maching
How to fit a belt
    Sniper:
  • 100 Answers
Remove the top cover and lower rear cover. loop the belt over the motor shaft and then around the drum pulley, this will probably only go round halfway as it is tight, hold the belt to the pulley by turning it rather like putting on a bicycle chain.
when it's on make sure it runs centrally round the pulley adjusting the position on the motor shaft if needed.
Posted on Jan 27, 2009
WWA5600SBLWW loud noise like a belt broke
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 23, 2013 | Washing Machines
Hoover WDM120 scraping noise heard when drum spinning with a load in washing machine.
have come across this prob before the noise you describe sounds like an underwire from a bra or the condencer on the back of the mach some had a baffle plate fitted just where it goes onto the backof your mach on some this came loose and caused it to scrape of the back of the drum hope this helps .
Jun 07, 2011 | Hoover H120M Front Load Washer / Dryer
Does anyone know where can I buy a new belt for my Tecnik tkl 9260 washing maching? Tecnik customer service won't pick up the phone and Spares2go seem to think this appliance has too different belts...
Your washing machine only has one belt. The reason for the two different part numbers is that the original part (1192J5) is no longer manufactured/available. 1185J5E is the replacement part number which is fully compatible with your machine. An appliance spares supplier should have been able to tell you this.
You can order using either part number - some suppliers will have the part listed under both numbers, others may still have stock of the original 1192J5 part.
I generally use UK Whitegoods for appliance spare parts as their prices are good, they deliver quickly and if you need any advice on ordering the correct part, you will get the right information:
Your belt: http://shop.ukwhitegoods.co.uk/Washing+Machine+Parts/White+Westinghouse/White+Westinghouse+Drive+Belts/36060200+Washing+Machine+Drive+Belt.html
Home page: http://www.ukwhitegoods.co.uk
Parts enquiry: http://shop.ukwhitegoods.co.uk/contact_us.php
Hope this helps!
Regards,
BElectric
Nov 25, 2010 | Tecnik TKL9260 Front Load Washer
Hello, trying to find a manual for a WF440P, could you help, thanks
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For user manual click on this link and go to ‘USER MANUALS’ on the heading bar, select the manufacturer needed and click on the link
Mar 07, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf440p door seal
on the wf you remove the lid and 2 screws that hold the console on at the front top.also the screws behind the soap tray front.
there are a few tabs at the bottom of the console at the back, carefully remove the console and then you will see there are 2 screws top and bottom of the front panel to remove,
pull the panel up to get it off its tabs.
you may want to unscrew the door lock 2 screws aswell.
Jan 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore sewing maching model 158.904
I bought mine at Walmrt. They are a Singer product and says it will fit most machines. There are 2 belts in the package and the small one is for bobbin winders. I have a Kenmore 158,904 and it fits perfect.
Nov 10, 2008 | Kenmore Sewing Machines
Kenmore washer elite top load
sounds like you have a bad coupler.mach does not have a belt it uses a coupling system between the motor and trans.if you fill mach and it makes the same noise in agitation,replace the coupler
Sep 21, 2008 | Kenmore 24032\24036 Top Load Washer
AEG WASHING MACHINE
fit hoses at random. put on a rinse cycle. if cold water comes in then hoses are correct. if hot water comes in, then reverse hoses
Aug 22, 2008 | AEG Lavamat 72640 Front Load Washer
Washing maching belt replacement
some machines have stretch belts and are difficult to place, if you have the right belt for the model then its just persistence, believe me we as engineers have same trouble (if we are honest)
Sep 30, 2007 | Washing Machines
Hotpoint Aquarius WF000 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
