Question about eGames Mini Golf Master 2 for Windows
Mini golf master compatibility with windows
Can a download fix the compatibility problem with Mini Golf Master and windows 8
Setting up gave wrong email will not let me fix it
Barry, You may have to do a factory reset and start over, or contact manufacturer for suggestion.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apple iPad mini Retina How to master reset
Perform factory reset Apple iPad mini 2 128 GB
How to Easily Master Format APPLE IPAD MINI 2 RETINA DISPLAY with Safety...
Feb 29, 2016 | Apple iPad Mini with Retina Display
Mini 400 card reader
Unitech's website is the first place to start. There may not be a windows 8 driver yet.
Oct 21, 2013 | Unitech MSR 206-33 (msr206-33) Magnetic...
Where can I buy flags for my mini golf course?
You can buy them on eBay or at any sporting goods store.
Feb 04, 2013 | Golf
Master key won't turn off anti theft system in my
Hi there
I think it would be a good move to go to a "key-maker-person" and ask for help.
good luck
kolbrun
Apr 23, 2012 | 1999 Volkswagen Golf
My clutch is broken there is no traction at all and it is stuck to the floor. I can raise the clutch with my foot but cannot change gear when the car is running. Its an 01 VW Golf, is there a cable in this...
The Golf has a hydraulic type clutch, it works off a master cylinder and uses a slave cylinder to engage and disengage. It has a hydraulic line, hose and tubing. Have you checked the fluid level in the master cylinder? Are there any leaks under your car? Often the seals go out on the slave cylinder and the fluid bypasses not allowing any pressure to build, resulting in a soft pedal that goes to the floor. Fill the master cylinder with approved fluid and "pump" the pedal by hand, you should start feeling some pressure build. Then check for leaks. if that is not the problem, you will need to troubleshoot the clutch for pressure plate problems or possible faulty master cylinder. Good luck, i hope this helps.
Jul 12, 2011 | 2001 Volkswagen Golf
How to unlock password for a HP 2140 Mini-Note
If you are talking about the login to Windows password then here is one way to do it:
Create a bootable USB stick using this tool: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Use the image from Ophcrack to load onto the USB: http://ophcrack.sourceforge.net/download.php Choose the XP LIVE CD Option
1. Download the YUMI exe to your desktop 2.. Save the LIVE CD of Ophcrack to your desktop. 3. Plug in the usb stick you want to use (make sure it is at least 500MB. 1GB if possible) 4. Run the YUMI EXE and follow the instructions. Make sure to choose the USB Drive Letter ("D:" E:" etc) 5. Choose the Ophcrack ISO for the image. 6. Install to USB 7. Click Finished and exit the program and close any other open programs. 8. Restart the computer. Leave USB plugged in. 9. As soon as the computer restarts, tap the F10 button to enter the BIOS Menu. 10. Scroll to the Boot / Advanced Menu and change the boot order to USB first, HDD second. 11. Save and exit BIOS. Computer will restart. 12. Once booted up the computer will bypass the HDD and boot into the USB 13. elect Ophcrack from the list and hit Enter. 14. Follow the on-screen instructions to have Ophcrack force the password.
(If you're using Linux then use the Linux LIVE CD Image instead of XP)
May 03, 2011 | HP Mini 2140 Notebook
No servo assistance on master brake cylinder golf II 1991
Make sure your vacuum hose is not leaking and connected properly.
Apr 29, 2010 | 1991 Volkswagen Golf
Can't get front brakes to work
fill master cylinder, slowly close of brake lines to be sure you have pressure from master cylinder, pump brakes to check master, check that calipers were seated in housing properly
Aug 08, 2009 | 1997 Volkswagen Golf
Software
To learn about the new and free version of Olympus Master 2 software go to: http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version. This software replaces all previous versions of Camedia Master 4.x, Olympus Master 1.x and is XP and Vista compatible.
Aug 02, 2008 | Olympus Stylus Verve / ?-mini Digital...
eGames Mini Golf Master 2 for Windows Logo
54 people viewed this question
Top eGames Video Game Consoles & Games Experts
James Wishart
EnergeeUK
Level 1 Expert
Bill Boyd
Are you an eGames Video Game Console and Game Expert? Answer questions, earn points and help others
