Question about Dell Computers & Internet
Blue screen appears two or three times a day - Dell Computers & Internet
  • Joe Eros Jan 22, 2013
    The solution is too complicated for me
  • Brian Sullivan
    Brian Sullivan Jan 22, 2013
    Well in basic terms you might not have enough computer ram or it might be getting hot ? Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER then you will know about it
  • Dell Master
  • 27,725 Answers
BSOD Bluescreen of death can be caused by a number of things If the PSU power supply units fan is not working the PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards A bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
A bad driver loose or faulty lead or not having enough ram or the RAM modules might be dirty. Might be getting hot Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Then reseat the modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. You might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask the seller if they guarantee the compatability of the ram before making any purchase
if you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
If eventually you can get a screen Click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver. If you computer came with a motherboard disk the drivers could be on it or you might have to download one. or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over. http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials
Hope this helps.
Posted on Jan 20, 2013
Dell inspiron 1429 would not stop restarting
just read the error on that blue screen...Its a dump error....then tell me....
ashishcgaikwad@hotmail.com or on 9665071117
Aug 27, 2009 | Dell Inspiron 1420 Notebook
IBM Travelstar 30gig harddrive refurbished paid 135 for it, clic
Hi
OOUchh! I would say the Hard drive is about to fail, back up data ASAP.
Cheers cbacer
Aug 11, 2009 | IBM TravelStar 10GT 10 GB Hard Drive
HP Pavilion PC blue screen shutdown and startup problem
the blue screen is known as the Blue Screen of death
refer to this article
http://pcpills.blogspot.com/2009/05/escape-blue-screen-of-death.html
Aug 07, 2009 | HP Pavilion tx1000z Notebook
There is just three lines that show red, green and blue.
It has been my experience with Sonys that those three colored lines indicate that the set is having trouble with the data communication lines. The hitch is that a model as complex as that one has as many as five seperate clock/data lines and if any one of them goes down the set will exhibit your symptom. It will take a professional to track down which line is causing the problem. I've seen audio output IC's as well as tuners cause the problem.
Jun 03, 2009 | Sony KP-61XBR48 61" Rear Projection...
Blue screen appears on start up and has no icons on screen cannot do anything does anyone know what this is
How many days you working in you laptop befor coming the blue screen? -- many days, 2 days. or 3 days, then comes blue screen?..
if the blue screen come few days working.. 1) check the programs anti virus.. maybe infected of virus or programs adware.. if yo always connected to the internet posseble happen this case.. or maybe you insert somthing in your system.. like usb flash, mmc. or any device.. be carefall sometime the computer making blue screen if some system error. even you didn't see error before... 2. try make restore system if can.. just go to Start, program., accessories, system tools then, system restor..
May 31, 2009 | Asus Eee Pc 701Sd Notebook
Nothing but a blue screen...ugh!
buy a cleaning cassette and play three times it will work well.
Oct 12, 2008 | JVC COMPACT VHS-C CAMCORDER
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Nov 05, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Red, blue and green vertical lines in middle of screen all functions are ok
tibs?? what are tubs?? Your problem is a convergence problem. there are two stk###-### you have to have a TV repair person relace for you . there may be some touch up alighnment needed also when IC's are replaced. Good Luck
Aug 14, 2006 | RCA P52960 52" Rear Projection Television
Open Questions:
Support - Storage Solutions - Toshiba'call +1888784-9316 Toshiba is known to be a world class innovator and high technology product leader globally with its 24x7 major subsidiaries and affiliates worldwide. Toshiba launched their first laptop computer way back in 1985 and since then they have managed a record worldwide cumulative shipment of more than 100 million Laptops at Financial Year 2010. Toshiba laptops are sought after because of its quality and superior performance. Regardless of the superior features and all the convenience, you can easily be denied support by Dell Support for any issues that could mess up with your critical data backup, recovery and security. OS crashes are one of the major reason for critical data loss. The other contributors for data loss are accidental data deletion, Virus Attack and natural disasters. Unless, you have an updated backup, you can very well assume that you may have to part away from your precious data. DataAlign takes control of such situations and helps you Toshiba Support backup your data and restore it as per your requirements. DataAlign lets you select backup schedules and it then runs automatically as per the configured schedules. With Automatic Backup protection, DataAlign gives you peace of mind when it comes to data backup and restore. DataAlign's affordable TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus computer. And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any Toshiba Customer service issue that you may face with your TOSHIBA product. Toshiba Help Desk Number 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer.
Apr 24, 2018 | Dell Computers & Internet
Computers & Internet Logo
18 people viewed this question
Alun Cox
